Re: Folger Prusa i3 Kit from ebay October 11, 2014 10:18PM |
Then I just removed the line completely and let the z axis home normally rather than me forcing it to hover and let the print go. Other than it not sticking completely at one corner it was able to finish the print so now I have a hollow cube with a crushed bottom corner!!!!!!!!!!!!|
Re: Folger Prusa i3 Kit from ebay October 11, 2014 11:31PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 11:36PM |
dooms101
Waltermixx
Dooms101 good to see you online again
love to see a post of your printer in action printing the skull, and of course once it's done
Cheers.
Well things still didn't work out. I started getting an air print about 2 hours in... Seems like the issue is still there. I'm starting to suspect it has something to do with the cold end getting too hot. That would somewhat explain why the filament keeps getting flattened. I'm taking the extruder apart now to try and see what the issue is. I might also try removing the two nuts. They don't really seem to have any functionality other than adding a little bit of mass.
Re: Folger Prusa i3 Kit from ebay October 11, 2014 11:43PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 11:55PM |
coldfront
umm am I doing something wrong here??? My current config is the one posted in this forum topic, I checked my vref's and they are as follows z: .34, y:.56,x:.34,e:.32. But when i load up repetier-host and try to jog with any axis with the manual control it makes a high pitched noise using 10m jog, and if i use 0.1m jog it jumps a little then stops. Would could be the problem, I have tried the Ramps 1.4 test file and everything runs smoothly going back and fourth. Someone even recommend sending command g1 x10 f300, and that works too. Anyone one have an idea what could be the problem?
Re: Folger Prusa i3 Kit from ebay October 12, 2014 12:54AM |
Re: Folger Prusa i3 Kit from ebay October 12, 2014 04:07PM |
Re: Folger Prusa i3 Kit from ebay October 12, 2014 09:32PM |
Re: Folger Prusa i3 Kit from ebay October 12, 2014 09:57PM |
Re: Folger Prusa i3 Kit from ebay October 12, 2014 10:31PM |
found it and attached it.|
Re: Folger Prusa i3 Kit from ebay October 13, 2014 12:02AM |
Waltermixx
Good notes...
the thermister for the heat bed, is actually soldered to the heat bed.
if you got a PCB Heatbed R1 Dual Power, it has the thermistor soldered to the center of the board, so all you have to do is solder leads to the edge of the pcboard, they are beside the 1,2,3 connectors for the heat bed. they should be labeled, mine are facing down, or I would tell you how they were labeled... i think i posted a picture of it earlier...found it and attached it.
I have my y-end stop at the front of my Prusa i3 mounted beside the y-idler. I'm using a different kind of mount... i posted the stl file for it in the thread above somewhere...
i found it on thingiverse.
Re: Folger Prusa i3 Kit from ebay October 13, 2014 12:24AM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 01:46AM |
Waltermixx
The printer likes to home before printing. You could wire it, and press the button when the carriage gets close to the mounting spot.
The end stops are not used during printing. Only just before so it knows where 0,0,0 is.
P.s. I am 1 hour into a 2 hour vase print... So far so good.
Re: Folger Prusa i3 Kit from ebay October 13, 2014 08:30AM |
Waltermixx
Well I did a 90 minute print, and wouldn't you know it, at about 75 minutes I got air printing again. Unfortunately I forgot to feel the stepper and cooling block to see if they were super warm. I will try another print and see if it does it again... If it does I may look into a spring loaded extruder.... Or try the threaded hole on the cold end... :0)
Cheers!
Re: Folger Prusa i3 Kit from ebay October 13, 2014 08:39AM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 08:50AM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 09:27AM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 09:30AM |
Waltermixx
Dooms101 that is a great looking print! Very nice...smooth!
I was wondering if you could raise your x carriage high enough to get a better picture of the bottom of the cooling block and hot end area.
It looks like you have no nut between the cool end and hot end, and just one on the top side of the cooling block, that is what the earlier post said.
I think your setup appears to be the best, so I would like to match it as close as possible.
That is one great print!
Re: Folger Prusa i3 Kit from ebay October 13, 2014 09:37AM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 11:32AM |
konto89
Hello guys, I ordered mine on thursday and since then I am reading and watching as much I can so I will be ready for the build.
I was very happy to find this thread as there is not much available documentation for the specific kit!
It is my first 3d printer and I am very excited!!!!
I would like to ask you how many days after you placed your order was the kit shipped? Until now mine is not marked as shipped.
P.S.: Sorry for my english, I am from Greece and it's not my native language!
Re: Folger Prusa i3 Kit from ebay October 13, 2014 12:39PM |
Waltermixx
Thanks Dooms I think a few pictures will help, it sounds as if the nut you are using is up against the bottom of the cooling block, and not at the top.
it also sounds like you threaded the hot end tube only half way up the cooling block. ( so the nut could not be on the top of the cooling block. ).
Today is Thanksgiving in Canada so I am off all day, so this may be a good time to rebuild it again, and apply the Kapton tape around the heatsink
to direct cooling to the extruder gear...
going to give it a shot.
Re: Folger Prusa i3 Kit from ebay October 13, 2014 12:57PM |
I think everyone with this printer may wish to adopt that way to go.
if it was not a holiday in canada, i would head to home depot right now and get a bunch of nylon spacers and attack this now....|
Re: Folger Prusa i3 Kit from ebay October 13, 2014 02:13PM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 04:36PM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 05:46PM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 06:14PM |
czmorris
goldenPSP,
This kit is fairly easy to assemble but in my opinion there are a few issues to consider. As long as you are patient (from your project list seems like it) you likely won't have any issues. You don't seem to be but if you are more of the type that says "I just want it to work" I wouldn't suggest getting a kit at all. Otherwise this is a fairly nice kit to get for a beginner as it will teach you a good deal but not break the bank.
Cons First
- There are no instructions. If you are looking for an "IKEA" style kit this isn't it.
- You will likely have to drill out some extra holes in places they are missing.
- You should do some research on RAMPS and Marlin (or firmware of your choice). Don't just plug it in and assume it will work.
- If you wire something wrong it is possible to cause damage. Do your homework on the electronics before trying to power up and print.
Pros.
- The components in the kit are fairly cheap and easily to replace if you break something.
- It works with well known firmware and software so there is lots of information and help available.
- The specs on this kit in my opinion are really good for the price point.
- You only need basic tools.
- There are several people who have purchased this kit. Many of them are on this forum so there is plenty of help.
- The rods now come pre-cut. This is really good news if you live in an apartment or something and don't have access to tools or a workshop.
- Due to the open nature the kit is easy to add onto and upgrade.
Re: Folger Prusa i3 Kit from ebay October 13, 2014 10:19PM |
goldenPSP
czmorris
goldenPSP,
Cons First
Pros.
Yes I like to tinker. I also like things to work sometimes. But in this case the kit route is beneficial both due to learning (it helps to maintain your device when you have built it) and budget (a commercial printers cost will likely cause my wife to make me sleep with the printer on the couch).
I have plenty of workspace. I have a full woodworking shop as well as a place in the basement dedicated for my RC planes and stuff.
Re: Folger Prusa i3 Kit from ebay October 13, 2014 10:30PM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 10:31PM |
Re: Folger Prusa i3 Kit from ebay October 13, 2014 10:36PM |
czmorris
goldenPSP, Don't get me wrong the machine works well. and it is certainly fun to tinker with.![]()
I did a reprint of the elephant. Unfortunately I couldn't find my previous one to do a side by side comparison.
