Re: Folger Prusa i3 Kit from ebay February 23, 2015 08:44PM |
widespreaddeadhead
First time poster. Little background: Familiar with Makerbot Replicator 2 and Solidoodle Workbench. I design 3d files in SketchUp, and use Repetier-Host to print on the Workbench.
I was going through the beginnings of this thread looking for a fix to my problem. I finished building the Folger Tech Prusa i3 kit this weekend. It was fairly simple and fun for someone who was practically a beginner. I can home the axis' fine, however I can't get the motors to move in the opposite direction. The z motors make a high pitched squeal and I don't quite remember what the others do, printer is at home and I'm at work. I have not adjusted the v-ref pots on the ramps yet, so would that most likely be my problem? I haven't tensioned the belts either, that was a problem on our Workbench when we first received it, our y-axis would bind trying to move one way. Thanks for any info/tips!
Re: Folger Prusa i3 Kit from ebay February 24, 2015 01:55AM |
Re: Folger Prusa i3 Kit from ebay February 24, 2015 10:06AM |
that1guy
I've had this happen once or twice, most recently yesterday. For me I retracted too much and the soft plastic got into the direct drive which couldn't grip it.
While the extruder is cool and the fan isn't running, take apart the extruder and remove the filament. If there's still some in the nozzle, cut off as much as you can and reassemble the extruder. Then heat the extruder back up completely, and feed the filament back in slowly and you should be good.
Re: Folger Prusa i3 Kit from ebay February 24, 2015 01:41PM |
Re: Folger Prusa i3 Kit from ebay February 24, 2015 01:44PM |
Sorry I'm kind of a beginner, would i test it on the two leads that I didn't use on the PSU?Quote
Zavashier
Test the fan directly on the PSU. You'll know.
Re: Folger Prusa i3 Kit from ebay February 24, 2015 02:33PM |
widespreaddeadhead
Zavashier
Also I noticed that the folger manual I was using has you wire the extruder fan to the "print fan" spot and not to the extruder fan spot, what is the reasoning behind this? Or did I just look at an older manual?
Re: Folger Prusa i3 Kit from ebay February 24, 2015 04:29PM |
Re: Folger Prusa i3 Kit from ebay February 24, 2015 05:04PM |
widespreaddeadhead
MakerFront
You can wire the fan directly to the power supply or wire it to D9 and control it in the slicer to be on 100% during printing. It's really a matter of preference.
D9 is fried
However, thanks for the tip about connecting it to the power supply, got me printing again!
Re: Folger Prusa i3 Kit from ebay February 24, 2015 05:28PM |
MakerFront
Might be a cheap fix though, you could replace the MOSFET for D9, which is probably what blew out.
Or even easier, order a new RAMPS board:
[www.ebay.com]
Re: Folger Prusa i3 Kit from ebay February 25, 2015 01:56AM |
Re: Folger Prusa i3 Kit from ebay February 25, 2015 07:16AM |
Re: Folger Prusa i3 Kit from ebay February 25, 2015 09:33AM |
MakerFront
[www.ebay.com]
Re: Folger Prusa i3 Kit from ebay February 25, 2015 09:57AM |
Re: Folger Prusa i3 Kit from ebay February 25, 2015 12:07PM |
Re: Folger Prusa i3 Kit from ebay February 25, 2015 12:23PM |
widespreaddeadhead
New problem, i sliced a calibration cube and starting printing it, however it went to the max points and just extruded in the same spot, while RH showed the model being printed. The extruder just pushed the plastic onto the same spot. Any ideas?
Re: Folger Prusa i3 Kit from ebay February 25, 2015 12:44PM |
louspinuso
I've never been able to get rh to work. Always the same results as you're experiencing but I get good results from pronterface so I just stick to that.
Re: Folger Prusa i3 Kit from ebay February 25, 2015 04:45PM |
widespreaddeadhead
louspinuso
Another strange thing I noticed is when I open an STL it almost always adds some little circle to way outside the print bed. When I slice it asks if I want to cancel because of that... I open up the STL file, which i designed anyway, and there is no little circle. We use RH on Macs at my job and it works well with our Solidoodle, but it isn't working very well for me on my Windows home machine.
Re: Folger Prusa i3 Kit from ebay February 25, 2015 04:57PM |
Re: Folger Prusa i3 Kit from ebay February 25, 2015 05:05PM |
Re: Folger Prusa i3 Kit from ebay February 25, 2015 05:17PM |
widespreaddeadhead
You were right! Thank you. Giving it another go now.
Re: Folger Prusa i3 Kit from ebay February 25, 2015 09:46PM |
Re: Folger Prusa i3 Kit from ebay February 26, 2015 03:09PM |
Re: Folger Prusa i3 Kit from ebay February 26, 2015 05:34PM |
Re: Folger Prusa i3 Kit from ebay February 27, 2015 11:53AM |
widespreaddeadhead
that1guy
Thanks, I finally accepted that I would have to take apart the extruder last night and found that the filament had jammed in the gear(direct drive?) and was all chewed up. I couldn't figure out why this happened because this was only the second time I've heated it up. Well then I remembered when I turned the printer on when I got home I smelled that ever familiar electronics burning smell but couldn't figure out where it was coming from. Well of course a few hours later I had that AH HA! moment when I remember that I didn't have any electrical tape to cover the wires extending from the extruder fan, and sure enough, the wires touched and the fan doesn't work. My question is, is the fan shorted out? Meaning could I just replaced the fan? or is the 12v from the ramps board shorted out?
Re: Folger Prusa i3 Kit from ebay February 27, 2015 02:27PM |
KeyserSoze3d
I have that problem a lot with the filament clogging. So much that its causing me to look at other extruders and hotends It's extremely frustrating when it happens in the middle of a 3 hour print.
Re: Folger Prusa i3 Kit from ebay March 01, 2015 09:32PM |
Re: Folger Prusa i3 Kit from ebay March 01, 2015 09:52PM |
Re: Folger Prusa i3 Kit from ebay March 02, 2015 10:51AM |
Re: Folger Prusa i3 Kit from ebay March 02, 2015 04:13PM |
Re: Folger Prusa i3 Kit from ebay March 02, 2015 06:56PM |
