Re: Folger Prusa i3 Kit from ebay
October 25, 2014 10:08AM
Did you adjust your vref. on each of the stepper motor driver modules? You dont mention it, so I thought I would ask smiling smiley
Did you read through this thread, we discuss reference voltages we have tried, the ones Folgertech recommends, etc. smiling smiley
There is also some discussion on motor wires, the kit came with a jst connector on one end, and lose wires on the other end to put in the RAMPS motor jumpers,
could it be the wiring is not consistent? I'm guessing Vref. issue...
October 25, 2014 12:08PM
Just a few questions.
Does this kit contain the rework version of the I3? Or the original?
Is there a summary of suggestions for this specific machine? I noticed a comment asking if someone actually used the original bearings. Is there a reason to not?
What extruder and hot end come in the kit? I don't see it listed on eBay or in this thread.
I'm really interested in this machine as the low price point and great prints you guys are getting. But just want to make sure I know what I'm getting into.
Thanks to everyone on here walking through their issues.
Edited 2 time(s). Last edit at 10/25/2014 02:42PM by BgHurt.
October 25, 2014 12:48PM
Waltermixx
Yes it's a great kit. smiling smiley
did you give the lcd more thought? I only print from the sd card via the lcd...
I'm trying to learn custom gcodes to add to gcode that is generated,
something to set the bed, then the fan on the extruder, then the hot end...
smiling smiley keeps the extruder cooler... smiling smiley
I asked the Folger guys what they had their Vref set to for their printers, and this is what they sent back:
"The larger bed motor I set it to 0.55V, the Z's are .35V, X is 0.33V, Extruder 0.35V
Thanks!
John"
man of few words... but then again most folks are compared to me smiling smiley
I set the vref to these amounts. I was able to get the X and Z axis to work. I changed the infeed values to something lower in pronterface, then I went and changed the vref and it all got a lot smoother. However the Y axis still is having problems. It just keeps jittering instead of moving to a direction. I know the ramps board cam with a bunch of jumpers and I used none of them(was i suppose to put them somewhere?) I havn't checked the wire yet. That is the next step. Anymore ideas tho?
Thank you for your help so far.
October 25, 2014 01:46PM
The jumpers go under each driver on the RAMPS board. There should be 3 jumpers under each driver. This sets the drive to 1/16 micro stepping I believe.
October 25, 2014 03:10PM
NukedWorker
I ordered my i3 a few weeks ago (around 60 had been purchased I think), but because real life kept getting in the way, amongst the difficulties I had getting it together, I'm only now getting close. However, I'm a little baffled at the difficulty I'm having with my X carriage. I've finally got my Y and Z moving, but when the X motor picks up (i.e. if I hit the home button) the motor vibrates like anything without moving the carriage anywhere, and then, just before it stops, it moves back and forth about 1/2 cm each direction, without having any results. Until I hit "motors off" the motor is still tight. I started using the different v-ref settings different people have posted here, then gave up and started at 0.07 V (where it vibrated, but didn't dance at the end) moving up by around 0.03 V until I got to 0.47 V where it seemed to dance a little more during the cycle, but I always ended up in the same place. I figured v-ref was the issue because my Z reacted kind of similar until I used Mr.Folger's settings, and away she went. My X still doesn't like me (for the record, I'm still married to my first wife of almost 17 years, I'm not giving up).
Am I barking up the wrong tree, or is it most likely that the v-ref is the problem, and I need to start over at the bottom and work my way up again? I am so close to getting somewhere, and yet so far.
I had the exact same issue with my X motor. I played with the v-ref for a while and got nowhere. I then connected the X motor to the Y plug on the RAMPS and the motor worked fine. So my fix was to swap the A4988 for the X axis with the extra that was in the kit. Everything was fin after that.
October 25, 2014 07:56PM
BgHurt
There are plenty of pictures of the kit in my flickr feed, including pictures of the printer from many angles. There are also detailed pictures of the extruder as well. A makerbot style of extruder I think would best describe the type of extruder....
Like the ones found in the replicator and clones... Single extruder, but 12volts, and with a termister not a thermocouple.
One additional note, is that the extruder is not spring loaded, but seems to do a very good job...
There are links to my pics in the thread at various points.
Cheers hope thy his helps...
Edited 1 time(s). Last edit at 10/25/2014 09:56PM by Waltermixx.
October 25, 2014 09:59PM
Here is the link to pictures, but I do encourage folks to read through the thread as there are a good learning points in it...
(Thanks again folks for your help in getting me up and running and sharing your experiences while building this very cool and inexpensive kit.)
[www.flickr.com]
October 25, 2014 11:42PM
zorg1179
NukedWorker
I've finally got my Y and Z moving, but when the X motor picks up (i.e. if I hit the home button) the motor vibrates like anything without moving the carriage anywhere, and then, just before it stops, it moves back and forth about 1/2 cm each direction, without having any results. Until I hit "motors off" the motor is still tight. I started using the different v-ref settings different people have posted here, then gave up and tried to find a v-ref on my own, but I always ended up in the same place. I figured v-ref was the issue because my Z reacted kind of similar until I used Mr.Folger's settings, and away she went. My X still doesn't like me (for the record, I'm still married to my first wife of almost 17 years, I'm not giving up).
I had the exact same issue with my X motor. I played with the v-ref for a while and got nowhere. I then connected the X motor to the Y plug on the RAMPS and the motor worked fine. So my fix was to swap the A4988 for the X axis with the extra that was in the kit. Everything was fine after that.
Well zorg, it appears you are correct - or so it seems at least. However, this is not good news in the least. I did the test as you suggested, and bammo, X drove smoothly! So I promptly, and excitedly swapped in the spare thinking I FINALLY HAVE IT! and nothing angry smiley; no movement at all this time, not even a twitch. So just to ensure, I then swapped the connections back, and swapped the X and Y A4988 instead. Apparently, I have not 1, but 2 bad chips in my kit - the X now worked, and the Y did not. I'm thinking someone doesn't like me somewhere.
Thanks muchly for the assistance. Now for the painful process of waiting to get my hands on some new chips, as if the waiting hasn't been painful already.
October 26, 2014 02:07AM
Haven't posted in a bit seems there are several newcomers. Awesome.
Curious. Has anyone used this kit with one of the 3d printing streaming systems such as Authentise?
October 26, 2014 02:04PM
NukedWorker
zorg1179
NukedWorker
I'm sure you already checked this but just in case. If you are using the small heat sinks that came with the stepper drivers (recommended) then make sure that they are not shorting any of the other components on the drivers. Also, it sounds like you may have eliminated this but when I first put my kit together one of my stepper motor wires was not terminated properly at the motor side connector. (Wire was not crimped properly). This gave very similar behavior and took a bit to figure out. I wound up removing the crimp from the connector and soldering the wire onto it and then putting it back.
When you switched to your spare did you try adjusting the vref on the spare when it wouldn't work?
October 26, 2014 02:10PM
czmorris
Second mod to the bearing holder. When I got a chance to look at it closely it looked like there would be clearance issues. I Modified it to work with zip ties instead as suggested. Instead of making it such that the ties have to go through the bed I added a channel in the back of the part that connects to the bed for the tip tie to rest in. I have no plans to change mine currently as it isn't giving me any issues. Again if someone tries it out and it works let me know and I will see what I can do about posting it on Thingiverse. I'm sure the source files are under an open source license but I'm not sure of the original source. If anyone knows if Folger got these from somewhere that I can source please let me know.
Here is the link
I have now also experienced the problem with one of the Y carriage bearings popping out of the holder. I'm running with a piece of reflective firewall insulation under the heated bed plate, so I'm not convinced this is a heat issue - I wonder if it is just vibration that is shaking the bearing slowly free?
What is your latest and greatest design for an upgraded holder? I'll print out a set and replace mine.
October 26, 2014 02:23PM
jjbunn
czmorris
Here is the link
I haven't done anything else with it since the pictures except uploading to thingiverse. Here is the thingiverse link. It shows around 40 downloads so far but no feed back. I haven't needed them so I am not using them myself. Let me know how it goes.
October 26, 2014 05:42PM
czmorris
NukedWorker
I appreciate all the input people have offered. It does look most likely to be the A4988's. I had similar problems with my pins too, and had to solder at least 2 of them on the RAMPs side. Seeing as how I was able to get each stepper running with different drivers, I'm 99.999999% sure that's what it is now. After your comment I rechecked all of the drivers, and the heat sinks appear to be floating nicely without making contact. When I tested the 'spare' driver, I did alter the v-ref first, but thanks for asking. When I switched the X (not working) and Y (working) drivers, after having 2 that didn't work for X, it was a check to make sure it wasn't the RAMPs board. X worked when the driver I had put into Y was in the X spot, and Y stopped working.
Sadly now, the nearest place with these (slightly different) are about 150km away, and $13.50 (A2A Printer) for a $3 component - plus gas and time. That said, I went there for my materials, and they were very pleasant. In an attempt to be patient, albeit frustrated, I've ordered some off eBay, and will get in touch with Mr.Folger tomorrow to see if there's anything he can/will do for me.
Thanks again.
October 26, 2014 05:49PM
Just finished my first successful hollow cube and the dimensions line up exactly.
So my problem ended up being a combination between the vref not being set correctly and the connectors that you have to make yourself(the 4 prong black ones) had a few wires loose. Still not sure that the reflective tape is for.
As a side note, does anyone elses X axis motor get VERY hot. Toward the of the (20 min) long print, it was to hot to touch. The Y and Z motors were cold and the Extruder motor was warm but nothing to bad I don't think. Could this be a bad stepper motor or is the normal?
October 26, 2014 06:12PM
hey there are you in Ontario? I'm in York Region myself... smiling smiley
A2A is a nice shop I've been there, I was going to buy a Prusa i3 from them, but found the Folger one for less. smiling smiley
I'm sure they can ship the components to you within a week...
also www.creatroninc.com also in toronto [www.creatroninc.com]
[www.a2aprinter.ca]
what direction are you? there is a place in St. Catherines that sells repraps, so they must also carry these little motor drivers...
[www.eckertech.com]
smiling smiley
Edited 2 time(s). Last edit at 10/26/2014 06:15PM by Waltermixx.
October 26, 2014 10:03PM
czmorris
jjbunn
czmorris
Here is the link
I printed a couple off. Mr printer had some trouble with the overhang, but overall they looked good: new holders
However, after fitting, the new lips foul on the frame just slightly: holder against frame
Perhaps instead of the lips, there should be a ridge/edge around each end opening, which would prevent the bearing moving out of the holder laterally? The downside would be that the bearing would have to be pressed in from the top, rather than slid in from the end.
I may have a go at fabricating something like that, as a test.
October 26, 2014 10:35PM
So I finally read all the way through, and I have to admit it helped during the assembly. Everything went together fairly smoothly, with the exception of the hours wasted trying to figure out why the motors only stuttered no mater the v-ref. After checking on here, I noticed my error with the wiring.
I rotated the hotend to the threaded boss and spaced it with some spacers, seems to keep the extruder motor a little cooler. Just wondering for those of you that have been happy with there prints, what are your go to settings in repitier host or what ever software you use?
By the way Waltermixx, where in York Region? I am not too far from A2A.
Thanks for logging all of your discussion on this forum! I found it was a huge help!
October 26, 2014 10:49PM
I've been very happy with my prints. If I notice something in the layers, that usually means I have to tighten a screw here or there...
the screws on the Y belt holder are the ones that usually loosen after a few hours of printing... I have lock nuts on them and used some
Lock Tight, and it's helped a great deal...
I use Repetier host, and Slic3r i created a few profiles for 15% fill, 20% fill, 40%fill etc. all at .200mm printing layer resolution.
I print with a 100 degree heated build plate and 220 on the nozzle.
I'm not sure if those settings are saved in a file somewhere on my mac, but if I find them I would be happy to post them.
I am in Woodbridge. smiling smiley
my favorite print is also most likely my most useless print... a chest buster from the Alien Movies. smiling smiley i like it because it was an 8 hour print that printed without issue. it was pretty smooth as well,
but not as smooth as the active cooling nozzle i just printed last night. smiling smiley not sure how to mount it yet, or weather or not i will smiling smiley but it was a very nice print. smiling smiley
[www.flickr.com]
Edited 1 time(s). Last edit at 10/26/2014 10:51PM by Waltermixx.
October 27, 2014 12:55PM
jjbunn
czmorris
jjbunn
czmorris
Here is the link
Interesting that the lips ran into clearance issues still. I made them smaller than the gap and as short as possible just for that reason. In theory you can likely get by without the lips at all so long as there is clearance enough for the zip tie that you are using. (Either cut them off or slice them off in software and reprint).
Personally I would hesitate to cap the ends and press it on. Just seems like that is asking to break or weaken something. However... Along the same thought. It might be a good idea to cut off half of the cylinder on the bottom and cap the ends. Then all you would have to do is set the bearing holder on top of the bearing and zip tie it into place. Then you have something to hold it in place from the ends and you do not have to force snap it into to place. That should leave plenty of room for clearance as well. If I have time this evening when I get home I may give it a try.
October 27, 2014 01:51PM
Does anyone know if any of the other iterations of the i3 have a similiar issue with these mounts?
I'm wondering if a better solution would be to fill in the point where the circle meets the flat mount so that the stress on that area from the press fit of the bearing would be spread out a bit more. You would still need a zip tie for backup.
October 27, 2014 02:14PM
Before I saw your last post I modified the bearing mount during my lunch hour for the half cylinder idea I was talking about. Added the update as another file on Thingiverse. I will do a test print just to confirm the model when I get home.
http://www.thingiverse.com/thing:513656
October 27, 2014 02:59PM
I have the Aurora Prusa i3. Worst instructions ever but does come with video instructions and a full set of STL kit parts. If you guys would like manual or stl files just let me know. Email me at rb3d@msn.com. I hope it's ok to list email address. If not, sorry. Brian.
October 27, 2014 03:05PM
The kit stl files I have are for parts with holes for feed rods and a 2 piece shell for x axis feed rods. No zip ties used except for belts. Much more solid.
Edited 1 time(s). Last edit at 10/27/2014 03:06PM by elwood127.
October 27, 2014 03:23PM
czmorris
i have zip ties on the original clips, i just drilled holes through them and the acrylic bed... (ok a bit barbarian, but I did not want to take it all appart,)
so I can confirm that zip ties on bearing holders with no "lips" will work fine and pass through the Acrylic frame smiling smiley
i like your design, however i would move the zip tie holes tight up against the curve of the bearing holder. smiling smiley
smiling smiley that is where I drilled the holes and it seemed to work out well smiling smiley
Edited 2 time(s). Last edit at 10/27/2014 04:24PM by Waltermixx.
October 27, 2014 03:42PM
I lied, I just checked the stl kit part files and they are not even the same parts as my kit. They are the earlier version. I told you this company was #%&* up. If you want them you gottem. Brian.
October 27, 2014 04:35PM
Thanks waltermixx. I was thinking about moving those in a bit more. I am not sure that it is necessary but it couldn't hurt. One of the things I was going for is to remove the need to drill the bed acrylic. Sure it is a simple task to do but it also adds another place someone might make a mistake. I suppose if it helps someone out it is worth it. One less tool needed.
One of the things I like about the half cylinder idea if it works out is that it makes itis little easier to remove the bed if needed without having to remove screws or slide out bearings.
I like the idea about filling in between the cylinder and the flat for more strength. Seems like a simple enough mod. if I have time I will try it out. It may require increasing the bearing hole diameter a bit to keep from breaking things with that stretching gone.
October 27, 2014 07:58PM
"Thanks waltermixx. I was thinking about moving those in a bit more. I am not sure that it is necessary but it couldn't hurt. One of the things I was going for is to remove the need to drill the bed acrylic."
you are absolutely right Mr. Morris, i was just being lazy smiling smiley I think anyone building the kit who has access to a printer before hand would do well to print your version of the clips smiling smiley
Cheers. smiling smiley
October 27, 2014 08:42PM
Waltermixx
Haha, I don't know that I would say lazy. Your pictures and extruder research is some of the best stuff here. Nothing wrong with using a simple solution especially when it works well. I haven't even bothered messing with mine as it hasn't given me this particular issue as of yet. Anyway, hopefully some of the ideas we come up with here can make their way back into the kit to make life a bit easier for folks in the future.
Curious, About how much clearance do you have between the zip ties and the frame on your setup?
A bit of irony: As I was writing this post I was running a test print of the latest bearing holder. One of my bearings just started slipping out. spinning smiley sticking its tongue out Looks like I get to try out the new design after all.
October 27, 2014 10:05PM
as you can see it's pretty tight. smiling smiley
i hope some of the Idea's make it to the next kit too.
the Y belt holder with the 3 screw holes that match this kit, ( I sent them the .stl for that, so they should have what they need if they choose to include it, saves drilling a hole smiling smiley )
Edited 1 time(s). Last edit at 10/27/2014 10:07PM by Waltermixx.
October 27, 2014 11:06PM
"I sent them the .stl for that, so they should have what they need if they choose to include it, saves drilling a hole"
Awesome, that was one of the things I had on my list. Easy fix but useful. I am thinking about trying to do something with the Z-axis nuts as well when I get a chance. A few folks have complained about that and someone suggested modding them to prevent it from moving.
I am currently testing the "half" style bearing holders. They clicked in place very tight so I decided to try them first without any zip ties at all just to see how it goes. So far so good. Fairly quick and easy swap. If I did not already have this thing put together I think I would reprint the plastic parts in color. That orange looks awesome. I was thinking about using some fluorescent green that I like to use. No practical purpose I suppose but it adds to what my wife calls the "nerdtasticness" of my work area. lol.
