how do I put this extruder together?
Posted by 3D rob
Re: how do I put this extruder together?
April 18, 2015 12:58PM
Thanks for the compliment . I just try to give back to the Reprap community as when i started it was a great help to me.
And now the real fun starts for you ...calibrating and printing spinning smiley sticking its tongue out
Good luck
April 18, 2015 10:32PM
Bigfilsing,
It's very late, perhaps better said it is very early! winking smiley
but finally:
[www.youtube.com]
little by little, step by step very slowly ......spinning smiley sticking its tongue out
I had to show it
an air printer smiling smiley
I quickly go to sleep!
Bye!
Rob.
April 18, 2015 11:21PM
Looks very good Rob
And it looks like your have your print speed at a reasonable level.
Keep it that way . One of the biggest mistakes ive seen new guys make is to set the print speeds too high and then wonder why they are having trouble with print quality.
Keep the print speeds set to where they are now while you get some experience with extrusion amounts, layer heights and temperature settings etc Then when you have quality prints you
can experiment with increasing the print speed
Good luck
April 19, 2015 09:49AM
confused smiley
unbelieveable!
tonight the printer was working,
and now,he refuses to work!!!!!!
I do not know what I've done for special something
sad smiley
manual does he still running, that's okay!
and it has to do with the temperature ( i think!)
Greetings from here!
Rob.
April 21, 2015 10:34AM
yessssssss problem found
it was the temperature sensor!
when I pulled it out of the printer began his work.
happier to because it was all a bit despondent.
okay now we continue building!
Friendly greetings all!
Rob.
May 03, 2015 12:13PM
bigfilsing,
if you come over here again?
just click on the link please:
[www.youtube.com]
as you can see he is not yet working properly,
the supply amount of the supply of the PLA is not yet well
but I do not know how and where to set it.
I have yet to figure in Pronterface.
Repetier Host will not work well with me (I think I've put a setting wrong)
and so I made myself broken.
friendly greetings!
Rob.
Edited 1 time(s). Last edit at 05/03/2015 12:23PM by 3D rob.
May 03, 2015 12:46PM
Ok Rob
mijn schritelijk Nederlands is niet so best maar ik zal het proberen.
Ten eerste heb ik gezien in je video dat er een probleem is met de fan ( of ventilator zoals je het in the video noemd) The fan op the hotend E3D moet altiid aan staan !!! Ook na het printen moet het even na laten draaien ( dus de machine niet gelijk uitzetten) tot the hotend helemaal afgekoelde is. Dus deze fan moet direct angesloten zijn op 12 volt
De bedoeling is dat dit koeling fan the aluminium gedeelte van de hotend altijd koel houdt om the voorkomen dat het PLA niet vroegtijd warm ( en dus zacht) wordt
Als mensen praten over een fan de na de eerate laag pas aan moet dan hebben ze het over een afzonderlijk koeling fan de op het werkstuk gericht is. ZO een fan kan weeleens helpen met de geprint lagen kwalitiet by snel drukken.
DIt is dus the "geschackeled regelbaar " uitgang van de ramps 1.4
Van de video lijkt het alsof de printer wel in het begin goed gewert heeft and na die tijd heel dun begon te printen. Ik zo eerst proberen je machine Z axis wat hooger af te stelen het lijkt een beetje of de nozzel to dicht by het bed zit en kan dus het PLA niet uit krijgen.
Moeilijk te zijn op de video
Om de hoeveelheid van de extrusie ( is dat Nederlands :-)) te bepalen moet je dat invullen in het config.h file en uploaden na de ramps. Het gaat om steps per mm
Als je wat meer info over je extruder kan vertellen kan ik het schaaten voor je als een begin punt. Daar na moet je het inregelen en testen
Edited 1 time(s). Last edit at 05/03/2015 12:47PM by bigfilsing.
May 03, 2015 02:39PM
ZO MAN!!!
dit is knal hart goed NEDERLANDS!!!
the important thing is to me,
where do I set the speed of the extruder motor?
the hotend is set in the following manner:
I have one (1) A4 paper folded,
and I have also taken a single A4 paper upon.
I have made sure that one (1) A4 sheet could freely pass under the hotend between the glass.
and the folded A4 piece of paper, I can get under it with a little more effort.
double gevouwn paper touches so and the glass and the nozzle.
I hoped that was the good way of tuning?
copied on another forum that I myself have created:
[www.circuitsonline.net]
in het Nederlands:
waar het mij om gaat is,
waar doe ik de snelheid instellen van de extruder motor?
take a look at the attachment?
and here I have my software from:
(not only from there though!)
[nwreprap.com]
de hotend is afgesteld op de volgende manier:
ik heb een(1) A4 papiertje dubbel gevouwen,
en ik heb ook een enkel A4 papiertje er bij genomen.
ik heb er voor gezorgd dat een(1) A4 blaadje vrij onder de hotend tussen het glas door kon.
en het dubbel gevouwen A4 papiertje kan ik er onder door halen met wat meer moeite.
het dubbel gevouwn papiertje raakt dus EN het glas EN de spuit mond.
ik hoopte dat dat de goeie manier van afstellen was?
afgekeken op een ander forum wat ik zelf aangemaakt heb:
May 03, 2015 09:07PM
Hi Rob
Your method of adjusting with a single A4 sheet sounds fine.Stay with that.
Im using Marlin on my ramps and Pronterface on my PC so i can only really advise using those.
You shouldn't be looking to adjust the speed (snelheid) of the extruder but the amount (hoeveelheid)
The speed of the extruder together with the XY&Z is set in your slicer software when you slice a model.
Ive just had a look at the Marlin version from your download link and it looks fine.
WHen you open Marlin in the Arduino software look at the config.h section , This is where all the user adjustments can be edited.
On line 282 in config.h is the adjustment for steps per mm of X,Y,Z & E , In the Marlin version downloaded from your link its set at 700 whick looks OK.
It should be that when you click Z +10 in pronterface that 10mm of PLA goes into the extruder. ( gaat in de extruder NIET komt er uit)
You can measure this by marking the PLA with a pen or piece of tape
Maybe watch this E steps calibration
Edited 1 time(s). Last edit at 05/03/2015 09:09PM by bigfilsing.
May 23, 2015 08:15PM
After many problems, my first print
[www.mijnalbum.nl]
nice right?
must say I am glad it's finally working,..... A LITTLE!!!
I first had a lockup whereby I grow things purchased again moste
also look over here:
[forums.reprap.org]
BUT!
Now it's going to be better .......... I hope smiling smiley
although I still have to improve a few things!
Friendly greetings from here!
Rob.
Edited 1 time(s). Last edit at 05/23/2015 08:18PM by 3D rob.
June 15, 2015 05:41PM
[forums.reprap.org]
Friendly greetings!
Rob.
October 12, 2015 04:55PM
busy busy busy
'm very busy (due to move out of my son, he has a new home)
also the whole family is on the move and to cultivate! :-(
My printer has stood still for long,
this was the last time:
[www.youtube.com]
and was quite a success!
I wish now I'm using a laptop and repetier host there to try,
see what comes of it, I'm curious.
just need to look at what firmware I will run this repetier.
even so far (I am called!)
VrGr Rob.
