Folgertech z axis problem April 26, 2015 03:34PM |
Re: Folgertech z axis problem April 26, 2015 10:20PM |
Re: Folgertech z axis problem April 27, 2015 03:41AM |
Re: Folgertech z axis problem April 27, 2015 10:33AM |
Re: Folgertech z axis problem April 27, 2015 11:19PM |
Re: Folgertech z axis problem April 27, 2015 11:27PM |
Re: Folgertech z axis problem April 27, 2015 11:59PM |
Re: Folgertech z axis problem April 28, 2015 05:33AM |
Re: Folgertech z axis problem April 28, 2015 10:46AM |
Re: Folgertech z axis problem April 28, 2015 10:20PM |
Re: Folgertech z axis problem April 29, 2015 09:20PM |
Re: Folgertech z axis problem April 30, 2015 04:05AM |
Re: Folgertech z axis problem April 30, 2015 07:59AM |
Re: Folgertech z axis problem April 30, 2015 10:42AM |
Re: Folgertech z axis problem April 30, 2015 08:52PM |
Re: Folgertech z axis problem April 30, 2015 08:55PM |
Folgertech specifies this motor drawing 0.4 Amps. So could I set the stepper driver for 0.8 Amps and be OK?Quote
itchytweed
It is entirely possible that you have a bad motor. I have not been a fan of putting two steppers on one driver. When wired in parallel, the driver has to supply the sum current of both steppers. So, if the steppers are nameplated at 1.2 amps, the stepper has to deliver 2.4 amps to supply the demand providing the steppers are the same electrical construction. In series, the current will be the same for each stepper, so the setting would be 1.2 amps but the voltage supplied is divided between the two steppers. This has its own issue with risetimes and settling, here again because of motor characteristics.
From my background in industrial electronics and automation, I would personally prefer to put each z-axis stepper on its own driver so that any minor variations in motor design can be tuned out. When I get my I3V built (get to pick it up from UPS today), I will have each z-axis stepper on its own driver.
Re: Folgertech z axis problem May 01, 2015 11:15AM |
vhoward1122
itchytweed
Re: Folgertech z axis problem May 01, 2015 08:02PM |
Re: Folgertech z axis problem May 02, 2015 05:46AM |
vhoward1122
I want to thank everyone who responded to help me. It was not a faulty motor or stepper driver. It was a faulty ramps 1.4 board. I happened to be collecting items for another project and have another ramps board along with more stepper drivers. I installed the other ramps board and made sure all the settings were correct. Did another test cube print. Let me say that the improvement is like day and night. The test cube came out 20 x 20 x 20 mm, not 20 x 20 x 40 mm. It also came out square shaped and not trapezoid shaped and the top is flat, not slanted. The layers are even, not uneven. I will post a couple of pics. Maybe some minor tweaks and it will be awesome.
I am happy I can now progress in my 3d printing journey.
Re: Folgertech z axis problem May 02, 2015 12:40PM |
Re: Folgertech z axis problem May 03, 2015 11:44AM |
Re: Folgertech z axis problem May 03, 2015 09:33PM |
Re: Folgertech z axis problem May 05, 2015 04:34AM |
I´d copy that.Quote
bigfilsing
If it indeed did come out at 40mm it would suggest that the jumpers under the Z axis stepper driver aren't working correctly and its set to 8 micro steps instead of 16 ..( which will give double the size)
Just my 2 cents
Re: Folgertech z axis problem May 05, 2015 07:22AM |
Re: Folgertech z axis problem May 05, 2015 10:40AM |
Re: Folgertech z axis problem May 10, 2015 05:52PM |
Re: Folgertech z axis problem May 10, 2015 06:57PM |
Re: Folgertech z axis problem May 10, 2015 09:02PM |
vhoward1122
In my case, it was a flakey ramps board.
Re: Folgertech z axis problem May 11, 2015 06:17PM |
Re: Folgertech z axis problem May 11, 2015 08:59PM |
