Re: Migbot Prusa i3 Unofficial Support Thread May 19, 2015 05:57AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 19, 2015 08:21AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 19, 2015 10:45AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 19, 2015 01:05PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 19, 2015 05:43PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 19, 2015 06:00PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 01:15PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 01:22PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 01:44PM |
jcabrer
If you want to try glass, get Borosilicate glass 6mm thick. Thinner sheets are not great at providing stable temperature.
Also, avoid using clips to hold the glass down. Use silicone adhesive, but only on the edges, not under the glass.
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 02:15PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 04:58PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 05:01PM |
Invictus
The proximity sensor is an inductive sensor that senses the presence of the aluminum plate. The sensor included has a sensing distance of 2mm, so anything non-conductive needs to be less than that or the sensor will crash into it. You could try 1/16" glass, get a sensor with a longer range, or maybe glue a piece of metal to the corner .
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 06:46PM |
gatorNic
small squares of aluminum foil on the corners perhaps? metal, but thin enough not to cause miss detection
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 07:47PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 20, 2015 07:58PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 21, 2015 02:52PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 21, 2015 06:46PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 02:50AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 04:57AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 07:52AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 08:38AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 08:43AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 08:46AM |
evetanlm
Thanks u Invictus, as does anyone have a idea of better Sensor that can be mount on it, as while printing there will be issue using this sensor, why? Because when you are doing multi printing, the sensor will knock on the other print and it really useless to have this sensor, which i give this up.
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 11:03AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 11:09AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 07:11PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 08:31PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 10:02PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 22, 2015 10:50PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 23, 2015 03:44PM |
