Re: Migbot Prusa i3 Unofficial Support Thread June 07, 2015 07:21PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 07, 2015 07:22PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 08, 2015 02:15AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 08, 2015 08:55AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 08, 2015 10:13AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 08, 2015 10:56PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 08, 2015 11:05PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 08, 2015 11:55PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 08, 2015 11:57PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 09, 2015 06:58AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 09, 2015 11:34AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 09, 2015 11:50AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 09, 2015 12:23PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 09, 2015 01:51PM |
jgschmidt
The Marlin firmware as currently loaded has many features disabled that I want to turn on, the extruder is not centered, and there are other adjustments I want to make. I saw the post for saving and restoring the original firmware. How do I load a new version of Marlin from my Windows-hosted Arduino IDE? I do have an unused AVR Pocket Programmer and FTDI Basic from Sparkfun in my tool box, if that helps.
Re: Migbot Prusa i3 Unofficial Support Thread June 09, 2015 02:03PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 09, 2015 05:40PM |
magiske
@Ukemaxxer I belive that dumping the FW is a bit overkill since it's = Marlin. And as long as you keep an updated Configuration.h, you should always be good.
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 05:54AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 06:02AM |
Ukemaxxer
magiske
It was more just to keep a backup of the original in case I needed to reinstall it. I've been sent some later code from a migbot contact in Canada.
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 06:42AM |
tkin
1) The bed takes a verrrry long time to heat up to 100 or 110 for printing ABS. Will a 24V power supply fix this?
What is very long(15 minutes or over an hour). The heat bed should heat up as fast as you supply enough Watts (Watts= Volt x Amps; a 12v 20amp PSU has same power output as a 24v 10 amp PSU).....until your heat bed fails.
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 09:00AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 10:51AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 10:57AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 02:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 06:12PM |
steaneb
Ukemaxxer
magiske
Uke, are you able to upload the new version? Would be interesting to see the changes
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 10:35PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 11:14PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 10, 2015 11:26PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 11, 2015 12:21AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 11, 2015 05:05AM |
wallygator801
Hey guys,
First of all, I am new to actually owning a 3D Printer but have been reading up on them for a while now so I understand most of the lingo. I have fully assembled the Migbot and using the LCD controls everything seems to be working. The problem I am having is getting the driver installed. No matter what I try it will not install. I tried the one provided on the SD card and the one posted on these forums with no success. Has anyone had these problems and could lead me in the right direction. I am running Windows 7 64-bit.
Thanks.
Re: Migbot Prusa i3 Unofficial Support Thread June 11, 2015 08:09PM |
