Re: Migbot Prusa i3 Unofficial Support Thread June 15, 2015 12:57PM |
jcabrer
For those of you struggling with bed leveling, some advixe. Auto Bed Leveling is not a feature. It is a crutch. Better to address the root cause of the problem, and either replace the bed, or resurface it to be flat. You can do this by adding a sheet of glass of thickness between 3 and 5mm. Use silicone adhesive against the edges, but not under the glass.
Once you have a flat surface, do a three point manual leveling with the screws.
Re: Migbot Prusa i3 Unofficial Support Thread June 15, 2015 02:01PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 15, 2015 04:10PM |
Ukemaxxer
Not sure how reliable the sensor would be with a piece of glass that thick.
Re: Migbot Prusa i3 Unofficial Support Thread June 15, 2015 04:13PM |
tkin
Ukemaxxer
Glass does not have any electromagnetic properties. However if you put 5mm of glass on top with a sensor that takes readings at 4mm you may have problems. I would also assume printing on a flat surface (glass), but measure a warped one (aluminum bed), could be problematic as well. I have not tried the autobed leveling yet. I figured once I get my machined turned/level I should not have to adjust things. I am wanting to give it a try though. I plan to glue a sheet of aluminum foil to a sheet of glass and see how well that works.
Re: Migbot Prusa i3 Unofficial Support Thread June 15, 2015 04:24PM |
tkin
Ukemaxxer
Re: Migbot Prusa i3 Unofficial Support Thread June 15, 2015 07:25PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 16, 2015 02:17AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 16, 2015 03:16AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 16, 2015 08:15AM |
keitarocos
Another bad solder joint on one of the end-stop switches. This is just ridiculous, and this time both contacts came off. It's not that hard to create a solder joint, I am very annoyed, I just was to get this done but everything keeps popping out of nowhere to stop me.
Re: Migbot Prusa i3 Unofficial Support Thread June 16, 2015 02:39PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 16, 2015 04:38PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 17, 2015 01:39AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 17, 2015 09:21AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 18, 2015 05:08PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 18, 2015 06:24PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 18, 2015 09:50PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 18, 2015 11:45PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 19, 2015 03:35AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 19, 2015 04:18PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 19, 2015 08:48PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 19, 2015 09:21PM |
veaceonee
Finally got my printer in today. Was looking over things and noticed the wiring is odd for the steppers. There are 4 pin connectors and 6 pin connectors. The 4 pins are wired black green blue red. However the 6 pins are wired red green blue black. Which is correct? How can I fix it? Thanx.
Re: Migbot Prusa i3 Unofficial Support Thread June 20, 2015 05:40PM |
rejaak
Just thought i'd share some photos of my evolving build and the mods i've implemented. feel free to criticize my efforts.My migbot fotos
Re: Migbot Prusa i3 Unofficial Support Thread June 20, 2015 07:44PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 01:50AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:03AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:21AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:24AM |
veaceonee
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:26AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:30AM |
MigMic
Hope this helps a bit and good luck! (I'll let you know whether my own advice helps me at all )
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:44AM |
veaceonee
My printer is due to come in tommorrow (after nearly a month and a bunch of lies). Anyway, I have read mixed reviews on the power supply that comes with this thing. Would it be better/safer to use the PSU that comes with it or an old ATX computer power supply (the one I am planning is rated at 19A on the 12v rail)?
