Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:48AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 01:14PM |
MigMic
veaceonee
My printer is due to come in tommorrow (after nearly a month and a bunch of lies). Anyway, I have read mixed reviews on the power supply that comes with this thing. Would it be better/safer to use the PSU that comes with it or an old ATX computer power supply (the one I am planning is rated at 19A on the 12v rail)?
Suggest you try the PSU you get with the Migbot as you may get lucky. I wasn't (when I turned it on it tripped the circuit breaker in the house) so I decided to go for a new ATX PSU which I reckon is safer (no 240V exposed terminals, reliable protection) and better (higher power rating, more versatile). I'm making up a junction box which allows me to use it as a generic bench power supply, with banana plug sockets, a voltmeter/ammeter display, access to the different voltages (12/5/3.3) and additional switches/fuses.
From what I've read here, the 19A supply you're planning to use will be under-rated.
Cheers,
M.
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:34PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 03:48PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 21, 2015 05:30PM |
try again i downloaded it and sliced the files fine.Quote
rejaak
Yakuza, here is the z probe mount i remixed. the y tensioner is supposed to be in 2 parts. i also tried to download your fixed files from google drive but when i tried to unzip them, winzip said they were corrupted.
Re: Migbot Prusa i3 Unofficial Support Thread June 22, 2015 05:49PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 22, 2015 07:48PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 22, 2015 08:31PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 22, 2015 09:36PM |
jcabrer
Ultimately, the direction that a motor spins is determined in firmware. The Configure.h file contains the settings for this.
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 01:37AM |
gatorNic
jcabrer
Just posted this question, but probably should of asked here first. Is there a way to read the current configuration that is loaded on the board?
[forums.reprap.org]
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 03:33AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 03:35AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 04:18AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 04:31AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 12:28PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 12:31PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 04:23PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 04:52PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 05:27PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 05:36PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 05:40PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 05:51PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 06:00PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 08:21PM |
G28 ;home all axes G29 ;detailed z-probe G92 X-15 Y130 ;adjust position so 100,100 is center of bed
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 08:29PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 23, 2015 09:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 24, 2015 02:27AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 24, 2015 04:28AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 24, 2015 04:47AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 24, 2015 10:07AM |
