Re: Migbot Prusa i3 Unofficial Support Thread September 27, 2015 12:23AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 27, 2015 12:57AM |
Glass bed September 27, 2015 12:36PM |
Re: Glass bed September 27, 2015 12:51PM |
Canadian Geek
For those of you with a heat plate under the aluminum bed and added a glass bed to it, did you remove the aluminum one and place the glass right on top of the heat plate or did you put the glass on top of the aluminum?
Thanks in advance,
Jeff
Re: Migbot Prusa i3 Unofficial Support Thread September 27, 2015 08:23PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 28, 2015 09:17AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 28, 2015 03:48PM |
Re: Glass bed September 29, 2015 05:55AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 29, 2015 12:46PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 29, 2015 03:50PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 30, 2015 09:10AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 30, 2015 02:35PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 30, 2015 03:36PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 30, 2015 04:21PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 01, 2015 05:45PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 01, 2015 06:30PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 01, 2015 07:03PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 01, 2015 07:05PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 01, 2015 07:51PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 01, 2015 10:42PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 02, 2015 12:16AM |
Re: Migbot Prusa i3 Unofficial Support Thread October 02, 2015 02:19AM |
Reprapmarc
Hi fellow migbot users,
My et0 stepper pinout of the mks base v1.2 stopped working.
Now my plan is to use the et1 stepper pinout for the extruder but I need to change the marlin firmware for this.
I already have the migbot marlin firmware ready in arduino but would like to know which lines I need to change to get this plan working.
Thanks in advance,
Marc
Re: Migbot Prusa i3 Unofficial Support Thread October 02, 2015 05:12AM |
Re: Migbot Prusa i3 Unofficial Support Thread October 03, 2015 06:02AM |
Re: Migbot Prusa i3 Unofficial Support Thread October 03, 2015 12:28PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 03, 2015 02:34PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 04, 2015 12:02AM |
Re: Migbot Prusa i3 Unofficial Support Thread October 04, 2015 04:53AM |
Re: Migbot Prusa i3 Unofficial Support Thread October 04, 2015 06:45AM |
Re: Migbot Prusa i3 Unofficial Support Thread October 06, 2015 07:40AM |
gwc2795
It will be easier to use the following [www.aliexpress.com]. The Migbot extruder frame is not wide enough for the thumb depression to fit. I ordered the positive direction short and had to grind about 3/8" off for it to fit. It is very hard to depress because you have to press on the top of the tension screw - very fatiguing for the finger. Also this will not fit the holes in the bottom of the Migbot extruder frame. I drilled an extra hole in the extruder frame (right side of the aluminum frame) and put 2 washers and an M6 nut on the nozzle, then tighten the M6 nut. I have to retighten the nut sometimes. The threaded hole for the nozzle does not have a grub screw so it vibrates loose without the nut and washers. It works, not very elegant.
