Migbot Prusa i3 Unofficial Support Thread
Posted by jcabrer
Re: Migbot Prusa i3 Unofficial Support Thread
October 26, 2015 07:47AM
gwc2795
kaffemustasj
gwc2795
kaffemustasj
So I measured the voltage coming of the voltage regulator and it was 2.33V, this was no good, so I changed it out with a voltage divider. The sensor now reads 3.2V.
However, how I've ran into another problem.
When I try to home the Z axis, the sensor lights up and triggers, but the Z axis keeps on lowering. This means the sensor and printhead slams into the printbed and keeps on trying to lower.
So I've tested with M119. The problem is that the sensor is always open, it never shows as triggered. This is although the voltage drops from 3.3V to 0 when a metal object is placed under the probe.
I had the exact problem when I added the sensor to my Migbot. I disconnected the sensor from the pin and measured the pin voltage on the pin the sensor connects to and found it was supplying 5V. I tested various resistance values to find one that took the pin voltage to <0.2V when I connected it to ground. In my case that value was 680 ohm. I used that as the resistor that connects to the pin and ground in the voltage divider. A 1K resistor allows the voltage to rise to ~4V from the output of the sensor. The sensor I have is normally closed and opens when the bed is sensed. Before the changes to the voltage divider resistance values mine tried to go through the bed.
Yeah, I'm guessing that's my problem. I measured 5V coming from the motherboard pins without the sensor connected.
When the sensor is connected to the board I'm reading 4.7V with a drop to 2.3V when the probe is triggered.
I've used a 15k ohm and a 10k ohm resistor in the voltage divider.
Could you draw your circuit in paint or whatever, so I'm sure I understand how to duplicate your connections?
Best I can draw. Hope it helps
The drawing is great.
So the ground and output pin from the sensor are connected before they go together into only one Z-min endstop pin?
Dosent this just ground the sensor output pin so the sensor voltage to the Z-min endstop always equals zero?
October 26, 2015 07:57AM
gwc2795
CrackinX
I'm having an issue as well with my Auto leveling in almost the same way as above, I have my sensor hooked to 12V and a V divider so the signal wire outputs about 4.5V, it is Normally closed so outputs 4.5V when NOT triggered. I have the endstop inverted in the firmware pullup disabled and all that. My issue is that when hooked up does nothing triggered or not it always reads as open. Power is hooked direct to 12V and Negative is direct to ground, 4.5V signal is hooked to the pin on the board that is not outputting 5V, hooked back up old endstop and everything is working fine there so it is something to do with the proximity sensor. Please help.
Oh for reference this is my sensor [www.amazon.com]
Measure the voltage from the shell of the USB connector and the output of the sensor when you trigger the sensor. The voltage is going to read about 12V if the sensor is working.
I think it is the other way around, it is 0V when triggered and 5v with the divider normally.
Edited 1 time(s). Last edit at 10/26/2015 07:59AM by CrackinX.
October 26, 2015 08:05AM
CrackinX
gwc2795
CrackinX
Yea, that's how it's supposed to be.
But I don't know if I understand the drawing correctly. Dosen't the circuit mean that the signal wire is always grounded, i.e. the signal wire always reads equal to zero?
October 26, 2015 08:27AM
kaffemustasj
CrackinX
gwc2795
CrackinX
I didn't provide a drawing, someone else did with a different sensor. but with a resistor in line on the signal and then another to ground it acts as a voltage divider lets 5V through the signal and the rest to ground. [drive.google.com]
October 26, 2015 09:11AM
CrackinX
kaffemustasj
CrackinX
gwc2795
CrackinX
So what you've drawn now works for you?
On the input of the Z-min on the motherboard there's to connections. Did you connect the sensor output to one of the Z-min inputs, and nothing else on the other Z-min input?
October 26, 2015 09:34AM
kaffemustasj
CrackinX
kaffemustasj
CrackinX
gwc2795
CrackinX
Yes that is the drawing of my sensor, and yes I only put the sensor output on the input line to Zmin and nothing else.
October 26, 2015 11:55AM
Okay, like typically someone would say, I have a quick question. If it was asked before, I do apologize and please direct me to the answer, or just answer it again.
Here is the situation. I bought an Electron Prusa i3 Sixth Gen which is a Migbot from the famous 3dprintersonlinestore and I am using Cura (newest version). I can print (finally) fine with the printer BUT it won't use the entire print bed, only about 50%. I have checked the firmware and the perimeters are set to the correct bed size. 3dprintersonlinestore (Gary) told me to zero out the offsets, I asked where they were, he responded just place the objects on the bed where they can print (really, F*ing genius), NO that is not a fix.
My question is, where are these offset settings in Cura that need to be zero out ?? Why is my printer thinking the bed is in a different position ? It is the standard size bed 225 x 225. The G28 and G29 is set for auto level. The firmware checks out good for the size bed. Like I said, the unit prints fine, just not utilizing the entire bed correctly. confused smiley
October 26, 2015 03:27PM
I also bought the Electron Prusa i3 Sixth Gen, I am currently assembling it and the LCD screen ONLY turns on, when plugged into my computer via USB. Any insight would be nice.
Also if there a website I can go and get replacement parts, rather then deal with these people, I would appreciate it.
Edited 1 time(s). Last edit at 10/26/2015 03:28PM by Ironsights.
October 26, 2015 04:10PM
Ironsights
Sounds like your not getting 12 volts from the power supply. Maybe wire issue or need to check the 110/220 volt switch. I know mine was set on 220 which I needed 110 where I live. You should see the switch thru a small hole on the side of the power supply.
October 26, 2015 04:21PM
dburas
Ironsights
Currently it is switched to 110V, I live in the US. Rather then dealing with these people, is there one I can just go buy and get here, rather then trying to explain to them and they tell me "No no, its the screen, screen bad, we send again"
October 26, 2015 06:08PM
Ironsights
dburas
Ironsights
So, I'm going to assume that you metered the output of the power supply and do not have 12 volts. I saw this Ebay and it is a US seller and pretty cheap.
October 26, 2015 06:15PM
I havent metered it yet, but highly suspicious of it. I will see about getting around to it this week to test it.
October 26, 2015 06:31PM
Good luck. I'm hoping I can get an answer for my question. I saw someone else ask the same question but they never got an answer.
D3
October 26, 2015 06:34PM
this is the power supply i replaced the crap one with. Works well. [www.amazon.com]
Does anybody happen to have any insight on my issue with the proximity sensor?
I have double, triple and even quadruple checked everything and it all seems to be right, yet will not work.
Ax
October 26, 2015 08:14PM
dburas
Personally, I'd reflash the firmware from the github I posted about a page back and start from there. Make sure all the settings are correct for the Printer under Cura too - Machine > Machine Settings. Also, I'm assuming you've got auto levelling enabled seeing you mentioned G29, if this is happening after the G29 sequence then it's the X & Y Sensor offsets that are incorrect. Check the following in the firmware:
  // these are the offsets to the probe relative to the extruder tip (Hotend - Probe)
  #define X_PROBE_OFFSET_FROM_EXTRUDER 12
  #define Y_PROBE_OFFSET_FROM_EXTRUDER 60
  #define Z_PROBE_OFFSET_FROM_EXTRUDER -0.8
These are from a random Marlin firmware on this PC, I think it was one of the ones that was sent to me by one of the guys (Jordan) who does the firmware for these printers. You want to be looking at the X & Y values. For some strange and unapparent reason, both my Migbots are 0 at X and -30 at Y, that's got them printing relatively central.
Ax
October 26, 2015 08:24PM
CrackinX
I've really no clue on this one.. I bought the 2nd Migbot without auto levelling and ended up getting this, which is the same sensor that's on my first Migbot, ie what's sent with it. No need to step-down the Voltage, just wire it up and go. It basically worked out cheaper to do it this way than adding on the sensor and printed part. Only thing I can suggest is to head over to Tom's YouTube and check the Auto Levelling video..
October 26, 2015 08:56PM
Ax
CrackinX
Thanks but I already have and according to his video I have everything hooked up right. I really have no explanation or apparent reason why it's not working...
October 26, 2015 10:33PM
CrackinX
The picture of that PSU shows 115V, assuming I should not get it?
October 26, 2015 10:57PM
Ironsights
CrackinX
That PSU will work perfect for you.
October 27, 2015 10:08AM
dburas
Ironsights
CrackinX
Not that I doubt you, or the resources, but the difference of 5V from 110V to 115V, is not going to affect the board, as far as burn it out? Correct?
Edited 1 time(s). Last edit at 10/27/2015 11:13AM by Ironsights.
October 27, 2015 11:25AM
Ironsights
dburas
Ironsights
CrackinX
You are correct, it will not burn it out. A typical US power outlet has anywhere from 110 to 122 volts (give or take). The US power supply is capable of handling up to about 130 volts before popping a fuse, some even higher. BUT if you have 130 volts (or more) coming out of your plugs throughout the house, you have an issue with your wiring in your house.
Your power supply is only outputting 12 volts (which is adjustable). So test (meter) the output to make sure it is outputting 12 volts. Typical power supplies have a voltage adjustment pot that can be adjusted, normally marked "Volt Adj".
Edited 1 time(s). Last edit at 10/27/2015 11:29AM by dburas.
October 27, 2015 03:33PM
kaffemustasj
CrackinX
gwc2795
CrackinX
Given for my Migbot:
The S pin on the Z Min pin has 5V supplied it at all times by the motherboard
The max current provided is 5ma
Given for my Inductive Sensor:
Model #SN04-P2 Normally Closed
The sensor supplies voltage when metal is sensed
Problem:
The M119 command showed Z min was always triggered even when the metal bed was detected by the sensor
This caused the head to crash into the bed and gouge the surface.
The Sensor does not sink any voltage to ground when it is detecting the bed. The Sensor output drops to 0V but the Z min S pin still has 5V on it from the motherboard the sensor does not lower this voltage.
Solution:
Install a voltage divider comprised of a 1K resistor on the sensor output wire to the Z min S pin
Install a 680 ohm resistor from the Z min S pin to ground
When the output of the sensor goes low (bed detected) the 5V being applied to the Z min S pin by the motherboard is lowered to ~0.85V which the processor sees as bed detected. The 680 ohm resistor can sink the 5ma supplied by the motherboard but can not sink the 300ma supplied by the sensor so the processor sees 5V on the Z min S pin when the sensor does not detect the bed.
Edited 1 time(s). Last edit at 10/27/2015 03:54PM by gwc2795.
October 27, 2015 04:02PM
gwc2795
kaffemustasj
CrackinX
gwc2795
CrackinX
Problem:
Solution:
Ok so if I already have a 10k resistor on the sensor output and another 10k from sensor to ground to sink the voltage from 12v to 5v you're saying I have to add another inline and and the bridge to ground.
I see what you're saying, I was assuming the S pin would detect the 5v signal but it supplies 5v and detects a voltage drop to ground... That makes more sense.
October 28, 2015 05:24AM
CrackinX
gwc2795
kaffemustasj
CrackinX
gwc2795
CrackinX
Problem:
Solution:
No you replace the 10k resistor on the sensor output with the 1K resistor and replace the 10k from sensor to ground with a 680 ohm.
October 28, 2015 09:43AM
gwc2795
CrackinX
gwc2795
kaffemustasj
CrackinX
gwc2795
CrackinX
Problem:
Solution:
Ok I'm following now, thanks a bunch.
So I can just use an fet transistor as a switch then power the gate with the sensor and connect the S pin to source and ground to drain, should effectively do the same thing.
Edited 1 time(s). Last edit at 10/28/2015 09:57AM by CrackinX.
October 28, 2015 05:10PM
That sounds correct
October 28, 2015 09:21PM
CrackinX
gwc2795
CrackinX
gwc2795
kaffemustasj
CrackinX
gwc2795
CrackinX
Problem:
Solution:
OK so I found an N-channel MOSFET laying around which worked perfect!! no resistors needed. source to ground, drain to S pin, gate to sensor wire. invert x-min in firmware. TADA working bed sensor.
October 28, 2015 10:48PM
Ugh, I am back again, and hopefully for one of the last times.
I am trying to install the drivers for a FT232R USB UART, and it seems I cannot manually install the drivers.
Anyone have instructions to point me to for this, step by step preferred. sad smiley
October 29, 2015 05:47AM
Ironsights
[www.usb-drivers.org]
I just installed the Cura supplied and it installed the drivers.
Edited 1 time(s). Last edit at 10/29/2015 06:13AM by gwc2795.
October 29, 2015 09:05AM
When I try to install them, the provided ones, it instantly tells me they cannot be installed. I will try your provided link and reply back with results. I need to unzip the drivers I download?
