Re: Migbot Prusa i3 Unofficial Support Thread November 01, 2015 07:04PM |
CrackinX
Hey guys, I have got my migbot all set up and printing pretty good at this point, bed centered in firmware, auto-leveling running properly. Just one issue everything is printing mirror image from what it should be, if I print something with text on it it comes out completely backwards. Any ideas what the issue might be? I can say that all my stepper plug wires are in the same order, all plugs on the board are black, green, blue. red. all plugs on the steppers are black, blue, green, red. so I'm kinda lost
Re: Migbot Prusa i3 Unofficial Support Thread November 01, 2015 08:07PM |
gwc2795
CrackinX
CrackinX did you get this problem resolved?
Re: Migbot Prusa i3 Unofficial Support Thread November 01, 2015 08:57PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 01, 2015 11:35PM |
CrackinX
gwc2795
CrackinX
No I have not, I have just been circumventing it by mirroring in the slicer, but I would not like to rely on this and actually get it resolved for real.
Re: Migbot Prusa i3 Unofficial Support Thread November 02, 2015 02:34AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 02, 2015 05:12AM |
evetanlm
Anyone can help me this? I have change my migbot extruder to wade's type but the extruder never move and keep making noise. See, stuck but when i use hand turn it's fine. Any advise from any one?
Re: Migbot Prusa i3 Unofficial Support Thread November 02, 2015 05:43AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 02, 2015 08:14PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 03, 2015 11:06AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 03, 2015 10:19PM |
gwc2795
I would appreciate input about the bed leveling problem I am having (or think I am having). After bed leveling today the first layer in the middle of the bed was OK. The 1st layer on the right side of the bed was so tight that the extruder motor started clicking. I killed the print and issued a G28, it was OK. I checked the distance between the Y-axis rods and the X-axis rods and they were different from side to side. I adjusted them to be the same distance. Issued G28 and adjusted the nozzle tip to be 0.1mm above the bed. Restated the print and after the bed leveling was complete the 1st layer is spot on. The X-axis was out of level about 5mm from side to side.
Does this mean that bed leveling will not compensate for an X-axis that is not parallel to the Y-axis?
Has anyone else observed this behavior?
Any suggestions on preventing this? The printer had just finished a 17 hour print job which went without a hitch.
I have wired the Z-axis stepper motors in series because I had problems with missing steps when they were wired in parallel.
Re: Migbot Prusa i3 Unofficial Support Thread November 04, 2015 11:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 05, 2015 12:30AM |
Bymp
Hello All,
I have the Prusa I3 kit and after a few set backs (Missing Hardware - Bad SD Card) .... I finally have everything together except 1 thing
I purchase the Auto Leveling kit sensor with this kit but I do not know where to wire it to?
Can someone advise the correct slot to install the OMKQN Sensor to?
Thank you,
J
Re: Migbot Prusa i3 Unofficial Support Thread November 05, 2015 11:07PM |
CrackinX
Bymp
Hello All,
Thank you,
J
It plugs into your z- endstop. Also replaces said endstop.
Re: Migbot Prusa i3 Unofficial Support Thread November 06, 2015 02:00AM |
, but I have made a few useful house objects as well. Just thought I'd share my experiences so far, hopefully it will help someone!|
Re: Migbot Prusa i3 Unofficial Support Thread November 06, 2015 09:45AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 06, 2015 12:09PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 06, 2015 02:45PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 07, 2015 03:18AM |
Ironsights
Alittle loss here. I think I am on the last step of getting my printer to work (been busy with work so couldnt touch it)
I have the sensor package. I havent leveled the bed yet with it. I mean, when I level the bed, do I need to set any offsets? How do I know what they are?
Wish there was a more simplified step by step for the whole thing. And maybe I am just flustered too.
Re: Migbot Prusa i3 Unofficial Support Thread November 07, 2015 06:04AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 07, 2015 08:57PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 12:07AM |
gwc2795
I am having a recurring problem with the hot end. The Throat continues to become loose. I have replaced the grub screw. I tighten it and use medium thread lock compound but it still gets loose. When it gets loose it starts hitting the object being printed and will knock it off, or the nozzle will hang inside an object and the printer skips steps on the X Y axis. The entire hot end has fallen out and made a big mess, it was hanging by the wires.
How are you keeping the grub screw tight?
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 05:11AM |
CrackinX
gwc2795
I replaced the whole setup with [www.ebay.com] The hotend screws right into it.
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 07:31AM |
gwc2795
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 10:05AM |
gwc2795
CrackinX
gwc2795
How did you secure it in the extruder frame?
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 04:14PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 05:14PM |
MigMic
Hi All,
Just wondering what lubricant you are using on the slides and Z-axis threaded rods?
Thanks,
Michael
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 06:24PM |
gwc2795
For the Z-axis I use this [www.amazon.com]
For the X and Y I use 3-in-1 oil. One drop and then move the bearings over that, Then take a towel and remove the remaining oil from the rods.
Use a toothpick to apply the Moly Plate. Lower the Z-axis and apply a touch above the Z-axis bearing and raise and lower the axis several times to spread it on the threaded rod. Once that is spread move the axis up midway and repeat. raise the axis fully and wipe any excess off the threaded rod. The Moly Plate goes a long way. The threaded rod will be black from the Moly Plate. I like Moly Plate because it does not attract dust.
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 06:32PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 06:46PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 08, 2015 08:06PM |
MigMic
gwc2795
Thanks. We're in a dusty environment so I need something which doesn't attract the dust. I can get 3-in-1 locally, but not Moly Plate. By the looks of it, it's a regular molybdenum disulfide grease so I should be able to find a local equivalent. What sort of consistency does it have? (I can't find an NLGI rating for it in their datasheet; see [en.wikipedia.org] for equivalent consistencies) Cheers, M.
