Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 11:32AM |
Wes78
well what you do is..... watch this. it helped me ALOT!
[www.youtube.com]
if you have auto-lvl watch this one too
[www.youtube.com]
Tom has good videos... watch them ....ALL...
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 12:12PM |
AccidentalWisdom
Wes78
[www.youtube.com]
[www.youtube.com]
Thanks, Wes78, I will try this out tonight! I got a little closer with my own methods last night but hopefully this video will help me finalize it.
The auto-leveler video is interesting, I need to get one of those sometime soon! I will likely check out Tom's videos as I get more acclimated to the machine and to printing in general.
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 01:23PM |
Wes78
AccidentalWisdom
Wes78
[www.youtube.com]
[www.youtube.com]
No problem at all!
Auto leveling is the only way to go makes life so much easier,
I would defiantly try to make time to see some of his videos this play list here has a lot of good info for someone starting out and setting up a 3D printer
[www.youtube.com]
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 01:26PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 05:09PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 05:13PM |
Wes78
spinracing
Heya all,
Have a few pics of the larger bed I made up, with the much stiffer carriage.
Also a quick end stop for the y axis, as the switch being on the carriage, it never seemed to have the right distance. SO I measured, and whipped up a quick block with a hole and zip tied it to my Y axis Motor.
Y Axis End stop. Dropbox
Original Table, "Large size" of the electron Migbot.
The number one problem... when the auto leveler tries to run it goes off the back of the table. SO you cant use it all. Dropbox
This is the size difference between tables. The new table is around .5 inches longer on the near end. And as you can see a few inches longer on the far end. Allowing the autolevel sensor to function, AND to be able to use all of the available table. (250mm by 200mm usable print area now) Dropbox
End view of the table and carriage. The table was 5/8 T-6 6061. Milled out to the channel to keep rigidity lengthwise. Carriage was 1/2 inch, but I machined it down a decent amount. It is also 6061. Dropbox
Two pics of the carriage.
I left the thicker edges not only for rigidity, but if I decided to go with larger rails, and or a second bearing on the right side, I wanted to have material to mount wherever needed.
Also the original plan was to add a ballscrew, but I think I will go to a much larger y axis travel so may so something different (but still ballscrew)
Dropbox
Dropbox
I made an Y Axis End stop bracket as well, It fits on the back side of the printer over the top of the y axis smooth rod hole.
when its homed its hit the switch on the edge of the black carriage (or alum if you have it)
Anyway it might work better for you as Its bolted to the printer, when i get home ill post pic.
If you or anyone else interested in it ill post the stl file on thingiverse
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 10:25PM |
Wes78
get you something like this [www.ebay.com]
and print you off a holder, something like this [www.thingiverse.com]
not sure where to get the green one from, ill have to look at the numbers on it and see if i can find one
Re: Migbot Prusa i3 Unofficial Support Thread January 19, 2016 12:01AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 19, 2016 08:32AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 19, 2016 09:51AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 20, 2016 07:52PM |
3DST
AccidentalWisdom,
Looks like
1. Your Z-Gap is way too high. The reason your first layer seems to coming out fine is probably due to the "First Layer Height" is "squishing" the print a lot. However, on the second and subsequent layers, it goes back to 100%... and there is too much separation between your layers.
2. You are printing relatively slow. Which, in general would not be a terrible thing. Unless your cooling fan is set at a high speed (like 80% to 100%"). This would "over-cool" your filament and not allow it to "stick".
Try adjusting your Gap a bit tighter... but set the "First Layer Height" at somewhere between 80% and 90%.
We tend to print at around 4,800 mm/min (80 mm/sec)... with the first layer height at 80% and first layer speed of 40%.
Good luck!
Jacob
3DSysTech / 3DMAGINE
Re: Migbot Prusa i3 Unofficial Support Thread January 20, 2016 09:51PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 12:23AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 03:54AM |
evetanlm
any one out there know migbot z axis gear ratio? please kindly let me know, anyone that willing to help? please appreciate anyone that can help!
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 06:56AM |
AccidentalWisdom
3DST
AccidentalWisdom,
Looks like
Good luck!
Jacob
Hi Jacob and all,
Thanks for the suggestions, they make sense. In #1, I think you are saying that my Z "Home" is off, right? Even if that wasn't what you were saying, it was true, haha. I fixed the Z Limit Switch on the machine so that the initial layer is no longer squished. To do this, I used Cura to send the Z Axis to "Home" position and noticed it jammed into the bed by .1 or .2 mm. So I kept raising it, playing with the position of the Z Limit Switch, then sending it "Home" again until I got it to a point where it was just ever so slightly pressing against a single sheet of standard printer paper. Good? If this isn't what you meant, can you let me know what you mean by Z-Gap?
I also reduced my fan speed from 100% to 60%. Now, the initial layer prints ok, but for each line of filament there is an equal width of empty space between (see picture attached). In addition, the subsequent layers still don't adhere well to the initial layers.
Attached is a picture of the most recent print result, along with my Cura settings for the Basic, Advanced, Fan, G-Code and Expert sections. Any suggestions on these settings? Do I have something set way off or is it possible there is an issue with the printer itself, its firmware or some defect in my assembly attempt?
Other relevant bits of info:
This is what I am trying to print, as a test piece: [fatdragongames.proboards.com]
I have the printer inside a box made of insulation foam, open at the front (for now), to keep breezes at a minimum.
I prime the printer bed with hairspray (smells pretty fantastic), my friend said that helps the filament to adhere much better than without.
The temp of my house is around 68F.
I have the filament spool on a dowel, suspended above the printer, with almost no tension so it spins very easy.
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 07:23AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 11:09AM |
Veaceonee
Attatched is my configuration.h file I use. It slows the printer way down, enables setting adjustments from the LCD, etc. and I have had great success with it. It is setup for Auto Bed Leveling awesomeness, so be aware of that. Back up your old file, and give it a try.
If you are using PLA, you don't need the enclosure or hairspray. I have found regular old blue painter tape works just fine.
All my Cura settings are exactly as Migbot said they should be.
Make sure you have the nozzle height adjusted properly, and bed leveled.
Just trying to help.
EDIT: Something I noticed while looking at your settings. Under Advanced > Speed, I noticed all your speeds are set to 0.0. Mine are: Travel Speed 100.0, bottom Layer 20, Infill 80, Outer Shell 20, Inner shell 40. Put those in and see what happens.
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 04:41PM |
AccidentalWisdom
Veaceonee
Thank you for the info. I did set those values in your Edit section after my post, but no change to the print quality.
Here's what I think might be the (or at least a) problem. It slipped my mind until last night, but when we were putting this printer together, the right X Axis tensioner was cracked. So on my friend's printer we printed this out: [www.thingiverse.com] as a replacement (we also printed a corresponding tensioner for the left side). This piece uses a different rod - an Acme Threaded rod, so both of the Z Axis rods are Acme. I believe this is the one we bought for each X Axis but I can confirm if needed:
[www.amazon.com]
So, since the threading is different on Acme vs standard, and the Migbot's firmware was programmed for standard threading, my guess is that when the firmware is telling the printer to move Z stepper up/down .10 mm, it is actually moving .? mm, instead. Does this make sense? If so, the fact that this printer part exists means someone has solved the issue with firmware edits, hopefully someone here is one of those people?
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 09:03PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 21, 2016 09:08PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 22, 2016 02:53PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 22, 2016 03:06PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 22, 2016 06:29PM |
Wes78
A heads up to those thinking about running or about to run an alum plate in place to the plastic one,
after doing so i started skipping steps when printing, i thought maybe it would become an issue and it did.
I had to slow the acceleration down a bit (in the FW) and i up'ed the amps via the pot screw going to the motor, im pretty sure im over amping the motor now, witch i think im going to change out to the next size up motor, as i will prob end up burring up the motor or the drive or both at some point if i dont.
Re: Migbot Prusa i3 Unofficial Support Thread January 22, 2016 06:52PM |
veaceonee
Wes78
what is the weight difference between the aluminum and the acrylic? just out of curiosity. The aluminum plate might be to heavy for the drive setup.
Re: Migbot Prusa i3 Unofficial Support Thread January 22, 2016 07:31PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 22, 2016 11:53PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 23, 2016 12:00AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 23, 2016 12:08AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 23, 2016 12:12AM |
Wes78
I would try replacing the thermistor first.
In cura. Are you able to connect? If so dose it register a temperature for the hotend? It should be something other then 0. You'll lest see what Ambient temperature is.
Just a thought
Re: Migbot Prusa i3 Unofficial Support Thread January 23, 2016 12:15AM |
AccidentalWisdom
Wes78
Just a thought
Cura won't connect and ambient temp reads at 0 degrees on the LCD. I already ordered a replacement 2 days ago, just in case, but it still hasn't shipped. So I am literally at a standstill, then? That sucks. My own fault for delaying on proper wire management. I would love to print out one of those nice chainlink style wire systems but I sort of need the printer to work, first, haha.
