Re: Migbot Prusa i3 Unofficial Support Thread February 06, 2016 01:40PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 06, 2016 08:40PM |
Canadian Geek
Ax
Have a super awesome, totally professional, messy bench, super shaky camera guide on tightening the Belts on a Migbot. xD
[youtu.be]
I have one of those x-axis belt tighteners from Thingiverse but I like how you tighten that axis better. I may revert and tighten the X-axis belt your way. What surprises me is, I haven't seen anyone invent a way to use a spring (other then those close line pin springs) or maybe a rubber/silicone grommet to keep constant tension on the belt without adding too much tension. Hmmm, thinking hat on time or time to scour Thingiverse.
Jeff
p.s. Yep, totally professional, messy bench, super shaky camera...sounds like my videos. Well for sure the messy bench
Re: Migbot Prusa i3 Unofficial Support Thread February 06, 2016 10:04PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 06, 2016 10:21PM |
InsaneCheese
Hi guys,
I've got one of these printers and I'm having some issues getting it to extrude (after going back to a Zstop from the auto level because the brackets to far out of whack for it to trigger)
I'm not home to take some photos, but it seems to lay down the first half of a layer ok and the it just stops extruding. Or it'll leave a dribble of plastic on the bed. And it seems to be chewing out the filament after it stops printing. But it seems to extrude fine when I tell pronterface to extrude (and doesn't chew the filament). Attemped to print at 180/200/210 and results are always similar. I'm running Ax's firmware and have PID tuned the hotend.
I am using the "PLA" it came with that says print Temps 180-230 degrees C
Re: Migbot Prusa i3 Unofficial Support Thread February 07, 2016 04:27AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 07, 2016 05:30AM |
InsaneCheese
I've relevelled the bed, and it's still doing more or less the same thing. Literally seems to stop feeding the filament after laying the perimeters.
This is the result of printing a 20mm cube.
Re: Migbot Prusa i3 Unofficial Support Thread February 07, 2016 05:38AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 07, 2016 06:22AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 07, 2016 06:42AM |
InsaneCheese
Ok, so just heating up the hot end and checking the log from Repetier-Host (seems to be the best for being able to see all of this stuff) and if I'm not extruding temps fluctuate about 0.5 of a degree. When I extrude the temperature varies by up to 5 degrees either way at least. I'll have to watch it when I get a chance to run a print, it's late and I get complaints from housemates about the noise.
I've been using Slic3r, but it had been doing the same thing using Cura. I setup Cura using the images provided on the SD card, but they all seemed to be the stock settings of the app.
M303 S180 C10
Re: Migbot Prusa i3 Unofficial Support Thread February 07, 2016 10:58AM |
Canadian Geek
Hi Wes, Is that new X carrage up on Thingiverse yet? I'm always interested in upgrades to my unit.
Jeff
Re: Migbot Prusa i3 Unofficial Support Thread February 07, 2016 12:47PM |
Ax
Ok, Marlin 1.1 firmware is up at [github.com] (note URL change) with the exception of the Small Bed with auto level, this may take a while as I need to wait for someone to get their probe in. Caveats - The Large Bed Auto-Level (and potentially the Large Bed no Auto Level as it's derived from this) will not print centrally. I've Duct Taped it so it basically probes correctly for my glass plates, if you want it to print centrally use the offset in your slicing software. Set this to X=-10, Y=20.
The Standard Bed no Auto Level, should work out of the box, PID tune and calibrate the Extruder and you'll be away.
EXTRA HUGE NOTE:You will need to use the Marlin folder from the 1.1 firmware, the 1.0 firmware Marlin will not work. Not saying you lot are dumb, just covering my arse and making sure that people know.
Wes78
Hey Jeff
No not yet I haven't had a chance to reprint it to confirm the changes I made fix the issues I had.
I'll try to get something going in the next day or so and get it posted.
It's a 6-7 hour print
Re: Migbot Prusa i3 Unofficial Support Thread February 08, 2016 11:11PM |
Ax
Re: Migbot Prusa i3 Unofficial Support Thread February 08, 2016 11:35PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 09:47AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 01:19PM |
Canadian Geek
Hey Ax, I've got a couple of questions. Do you have the large bed? If so, what size it it? And one last question/favor, could you measure your unit from the front cross beam (the one with the y-axis stepper attached to it) to the back cross beam. I'm curious as to the length of your machine as I'm sure I could add a longer bed to mine without changing anything but the bed (and of course all the settings). Your units look like they have the same screw hole dimensions, just a longer bed.
Thanks in advance,
Jeff
p.s. If I'm not mistaken, someone is printing a new probe holder for Aten. (Love the Egyptian god names. Not sure I'd have gone with Isis in today's world but a god non the less). If course, just because I typed Isis, the NSA will be monitoring me now. LOL.
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 01:25PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 01:31PM |
gotswrv
WHAT!
Can I get a picture of all this?
Also, you got a best place to get the Pi? Thinking I want to try the octoprint out.
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 03:19PM |
G0 Z+10 E-5 F5000; Lift Z Axis +10 - retractam i doing something wrong?
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 03:49PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 03:59PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 06:37PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 07:23PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 09, 2016 09:36PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 10, 2016 01:00AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 10, 2016 02:38AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 10, 2016 03:04AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 10, 2016 04:04AM |
SOLVED February 10, 2016 08:28PM |
Canadian Geek
OK, I've got a strange one. I can't print from the printer using USB (but I know why, wait for it), but I can print from an SD card. This part had me baffled at first until I looked at the temperatures being reported via the LCD and what is being told to the computer. There is a 10° difference between what is on the LCD and what the computer thinks the temperature is. For example, I set the bed to 60° and on the LCD it will display 60°. But the computer will only report it as 50° and thus won't continue with the code. I'm not stuck because I can always print from the SD card but this really has me scratching my head. I can jog from the computer etc, it just won't print. I'm a Technical Support Specialist (tier 3 or in other words, last line before throwing the computer out, LOL) I've changed computers, USB cables, unplugged and replugged everything back in, rebooted till the cows come home but always the same. What would cause the computer to see a lower temperature than the LCD screen?
Jeff
Re: SOLVED February 10, 2016 08:36PM |
Re: SOLVED February 10, 2016 11:58PM |
Ax
Glad you got it fixed. The 4th printer is on the way now and it ain't a Migbot. Hop over to the CoreXY section and look for the Fusebox thread
