Re: Migbot Prusa i3 Unofficial Support Thread February 25, 2016 01:55PM |
gotswrv
Does anyone know where to get a quality heating element for the extruder? Ohh, I'm in the US.
Having a lot of issues getting it tuned in. Autotune returns wildly different values from day to day. When everything looks good I cannot make it through a print without a thermal fault. Seems like spending a few extra dollars on the element might be worth the hassle saved.
Re: Migbot Prusa i3 Unofficial Support Thread February 25, 2016 10:40PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 25, 2016 11:03PM |
Taisiya
hello,
Yes, I saw this depository, but shouldn't there be an images instructions?
Did you receive a separate instructions sent with the Kit?
May I ask if you could email me photos/ scans of you instructions and wiring pics please?
my email is mag8891@gmail.com
many thanks.
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 12:57AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 03:00AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 03:37AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 03:39AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 08:46AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 08:51AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 09:37AM |
Ax
Wes78
gotswrv
@Wes78, Thanks for that!
but that place is dangerous... Ended up deciding to swap out everything to 24v.
Fill me in please, dangerous how? I haven't had a problem one with them or there stuff
Think he means dangerous to his wallet..
Re: Migbot Prusa i3 Unofficial Support Thread February 26, 2016 09:40AM |
gotswrv
Ax
Wes78
gotswrv
Exactly!
Went there to spend $5 left $50 lighter...
Good share!
Re: Migbot Prusa i3 Unofficial Support Thread February 29, 2016 12:48PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 29, 2016 01:10PM |
Boggy22
Hi again guys. I did find a while ago that the cause for my filament being stuck was the un-chamfered throat in the extruder. I "dremeled" a nice cone shape at the top where the filament comes in and it went smoothly afterwards. After having a clogged nozzle I decided to dip the hot end in acetone because the aluminum block was dirty too. Stupid thing, because I think the teflon lining inside the throat was damaged in the process. Even after changing the nozzle, I have problems with filament feeding through. I want to order new ones, but I don't know exactly what the length is(I don't want to unscrew it again before a replacement because I'm going to screw up the thread in the aluminum block).
Do you have any idea if they're M6x26 or M6x30mm? These are the main sizes I found on the internet.
Also, some people are NOT using teflon liners inside for ABS printing... They do polish the inside of the throat properly, but I'm having doubts about doing this myself. Any tips for smoother feeding?
Thanks!
Re: Migbot Prusa i3 Unofficial Support Thread February 29, 2016 01:32PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 29, 2016 05:13PM |
Re: Migbot Prusa i3 Unofficial Support Thread February 29, 2016 07:15PM |
gotswrv
Do you guy keep the feeder on the X carriage or remote feed with the v6?
Also wanting to know if a G10 frame is really an upgrade?
Tired of the frame coming loose and loosing shape.
If the G10 frame is metal, it's a definite upgrade..
Re: Migbot Prusa i3 Unofficial Support Thread March 01, 2016 03:39AM |
Re: Migbot Prusa i3 Unofficial Support Thread March 07, 2016 11:58PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 04:24AM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 11:13AM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 03:56PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 04:00PM |
uberjay
Hi folks,
I'm in the midst of getting my i3 to work. It's all assembled, Ax's Marlin 1.1 firmware loaded, large size bed all setup and leveled, setup using autolevel (using Ax's large bed & auto level configuration.h). I did the auto PID tuning as well on the extruder.
Here's my problem.... if I print PLA at 205 degrees it prints fine, but if I print at 210 I get Thermal Runaway issues. Usually by around 94% of this particular print; however, I just got one at 28% through the print.
I have not touched the thermal runaway settings in the firmware/config.
I have checked the thermistor's set screw (backed it off and then gently snugged it up).
After that I measured the resistance of the bed thermistor and hot end's thermistor and they were identical.
I've searched through this awesome thread and found most of the answers to all the other hurdles I've hit up to this point. But I'm stumped on this one - maybe I missed it in this thread, but if someone could point me in the right direction I could stop beating my head against the wall. ;-)
Here's my setup:
- this printer with the MK8 Pro extruder + large bed + auto leveling platform
https://www.3dprintersonlinestore.com/electron-3d-prusa-i3-kit
- configuration.h file attached
- printing PLA (eSun and the stock white that came with the printer)
- stock aluminum bed with tape and glue (for now, have glass, etc. planned for later)
- printing temps of 205 and 210 with bed at 50
- layer fan to 50% after first layer (I believe- just defaulted) and 80% at max (tried dropping this from default of 100% in case it was cooling the hot end)
- using Repetier Host to generate gcode then printing via SDCard (actually printing via USB does the same thing)
- firmware: Ax's Marlin 1.1 using the large bed, auto level configuration.h (adjusted for auto PID tune, etc.)
Thanks in advance for any / all assistance.
Jason.
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 04:02PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 04:28PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 04:31PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 04:44PM |
uberjay
Ax
Are you running the stock wire from the PSU to the MKS motherboard?
Yup. I think the resistance I measured (at the plug end) was ~ 125 k.
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 04:50PM |
spinracing
Ahhhh the Fun!!!
SO been doing some upgrades.. (At work so no pics)
SO was printing in ABS.. I had gone through two spools of PLA getting some designs sorted.
Smelled burning plastic.. thought it was the ABS... No it was the connector to the heat bed on my motherboard.
A couple hours later I cleaned up and rebuilt the connectors, re-soldered it, and it was much happier.. but I decoded to stop using the factory board to power the heatbed.
Ordered a switching power supply, and one of the relays... which turned int TWO relays.. one 25 and one 100. Plus heat sinks for them both and heat sink compound.
Then ordered a new silicone heater for the heat bed. (since it sticks under the aluminum)
Then before installing all that.. ordered a set of longer 8mm rails, and a leadscrew to compliment them.. along with associated sliders etc. SO I can lengthen my y axis to appx 16" of print area. (STILL waiting for the rails to arrive from china.. I think they got lost in NY)
Go to print parts for the leadscrew conversion.. BLAMMO spaghetti. My y axis stops working and spits out its belt.
Needless to say.. I am going to have to repair the belt holder, and make it functional until I can get the leadscrew parts. But hope to have pics sooner rather than later.
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 08:54PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 09:00PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 08, 2016 09:43PM |
Ax
Change it to 14 AWG, It's under gauge. Had something similar with the 4th Migbot's bed until I changed out the wire. Made a huge difference. I'm betting the wire's warm when the printer is running.
