Re: Migbot Prusa i3 Unofficial Support Thread March 19, 2016 09:32PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 19, 2016 09:44PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 19, 2016 10:41PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 20, 2016 10:41AM |
Re: Migbot Prusa i3 Unofficial Support Thread March 21, 2016 08:46PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 22, 2016 11:17AM |
IBaz
As I'm getting sick of waiting over 20 minutes for my heat bed to get to 90 degrees has anyone successfully added a relay to the bed getting power straight from the power supply?
I see that people are using solid state relays but having absolutely no experience can anyone suggest what to look for and how to wire this in?
Re: Migbot Prusa i3 Unofficial Support Thread March 22, 2016 05:52PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 22, 2016 06:57PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 22, 2016 10:01PM |
Wes78
Did all 3 bed's ohm out the same?
You will lose some power going thru the ssr tho.
The only reason I would run an ssr off the same power supply as the rest of the printer is IF the bed will require more amps Then the board can handle putting out. (200watt silicone mat) I think its about 20amps max. -for everything-
I too have dumped the alum plate with all my printers. With the glass right on the pcb. Printting on glass is the only way to go.
As far as the auto lvling, my self I went to a retractable end stop switch ran with a servo.
Works beautifully once set up.
Re: Migbot Prusa i3 Unofficial Support Thread March 22, 2016 10:12PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 23, 2016 11:47PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 23, 2016 11:59PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 24, 2016 04:54PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 24, 2016 05:13PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 24, 2016 05:31PM |
Taisiya
Hi, guys
I got a Migbot Large Bed printer that came without a proximity switch.
I now thinking of buying and installing a proximity switch.
The question I got is where to find or what is called the white 3 wire connector that connect the proximity switch to the MK Base?
All the switches I saw on sale come without this connector.
Many thanks.
Cheers
Ta
Re: Migbot Prusa i3 Unofficial Support Thread March 25, 2016 05:56AM |
Wes78
IBaz
yup same here. i run my beds with 24v 2-3mins to hit 110c almost as fast as the hotend.
The main thing to be careful with is making sure the 24v power supply has enough amps to push the bad, and all that amounts to is what the bed ohm's at.
(ohm's law) I am even running 24v thru the 12v side. my 12v side ohmed at 1.6ohm so at 24v it needs 15amps. but dont get a 15amp power supply tho.. youll want 20-25amp I have a hard time finding anything over 25amp cause the price seems to go way up once you hit 30amp 24v
Oh and you can run 24v on the 24v side, it is faster heating then 12v on the 12v side but its still takes 10 mins or so... again that all depends on what your bed ohms at. they are all close but different.. a .2 to .5 ohm change can make a huge difference especially when dealing with 24v
Re: Migbot Prusa i3 Unofficial Support Thread March 25, 2016 10:11AM |
Re: Migbot Prusa i3 Unofficial Support Thread March 25, 2016 10:23AM |
Re: Migbot Prusa i3 Unofficial Support Thread March 25, 2016 11:05AM |
Re: Migbot Prusa i3 Unofficial Support Thread March 25, 2016 12:42PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 25, 2016 05:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 26, 2016 09:55AM |
gotswrv
Are you storing the home position? With some versions of firmware you can do this at the machine. Other firmware a require you to put the z offset in and reflash the board.
Re: Migbot Prusa i3 Unofficial Support Thread March 26, 2016 04:06PM |
Re: Migbot Prusa i3 Unofficial Support Thread March 29, 2016 07:46AM |
Taisiya
I measured so the extruder is 1-2 mm up the board. then press on lcd screen prepare and home all axis. but when i send file to print it seems to adjust z axis like 5 mm above the board, which doesn't make sence
where I can check this settings?
Many thanks
Re: Migbot Prusa i3 Unofficial Support Thread March 29, 2016 10:59AM |
Re: Migbot Prusa i3 Unofficial Support Thread April 17, 2016 12:47AM |
Re: Migbot Prusa i3 Unofficial Support Thread April 17, 2016 12:53AM |
Re: Migbot Prusa i3 Unofficial Support Thread April 17, 2016 05:39AM |
Adam304
Hello! I stumbled on this thread while building my printer and it has been a great help. Thanks to those involved.
Can anyone tell me why my all my axes crash when homing? It seems like all 3 steppers are moving in the opposite direction of the endstops. All kinds of belt grinding and clicking. It is wired per the diagram.
I was able to get the Migbot connect over usb, but unable to update the firmware. I looked back through the install process noticed I had only installed 1 of the 2 drivers. Does anyone know what device to install the 2nd (port?) driver for? I have been getting a load of comm errors in the logs when trying to upload Marlin.
I truly appreciate any help getting this printer printing! Thank you all!
Re: Migbot Prusa i3 Unofficial Support Thread April 17, 2016 06:14PM |
jazzbassNick
My guess would be you've got your limit switches in the "+" instead of the "-" slots. If you look closely at the board, they're labeled.
I don't remember more than one driver, but it's been awhile. I'm sure one of the experts will chime in.
Re: Migbot Prusa i3 Unofficial Support Thread April 17, 2016 07:06PM |
Adam304
jazzbassNick
Appreciated the quick reply, thank you. I checked and even reversed the endstop connections, still the same. The bed crashes front, x to the right, z straight up.
The driver i was was questioning is ftdiport from CDM v2.08.
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way. #define INVERT_X_DIR true #define INVERT_Y_DIR true #define INVERT_Z_DIR true
