Re: Migbot Prusa i3 Unofficial Support Thread April 17, 2016 09:34PM |
Ax
Adam304
jazzbassNick
My guess would be you've got your limit switches in the "+" instead of the "-" slots. If you look closely at the board, they're labeled.
I don't remember more than one driver, but it's been awhile. I'm sure one of the experts will chime in.
Appreciated the quick reply, thank you. I checked and even reversed the endstop connections, still the same. The bed crashes front, x to the right, z straight up.
The driver i was was questioning is ftdiport from CDM v2.08.
Doesn't hurt to install both. It can only help if you're getting com errors. If you take a look at my Marlin 1.1 firmware, and can get it uploaded it should work. Sounds like the directions are set wrong in the firmware and should be as follows:
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way. #define INVERT_X_DIR true #define INVERT_Y_DIR true #define INVERT_Z_DIR true
Re: Migbot Prusa i3 Unofficial Support Thread April 24, 2016 12:55AM |
Re: Migbot Prusa i3 Unofficial Support Thread April 24, 2016 03:57PM |
Re: Migbot Prusa i3 Unofficial Support Thread April 25, 2016 12:27PM |
Adam304
Ax
Adam304
jazzbassNick
Thanks for your time in replying, again its truly appreciated. I took a guess installed the ftdiport driver to the COM3 device under device manager. I was able to upload the firmware through the arduino console, albiet with some red text in the logs. I still can't get any software to play nice though.
The motors still rotate in the wrong direction when homing. The extruder seems fine. Should I try to rewire the stepper motors? How? Link to your firmware?
Re: Migbot Prusa i3 Unofficial Support Thread April 26, 2016 02:34AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 02, 2016 09:03AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 05, 2016 11:22AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 05, 2016 07:39PM |
Adam304
Could anyone tell me how to increase the extruder motor torque by increasing voltage/amperage through Marlin? Is it possible? Kinda lost since there isn't a physical driver attached. The motor isn't holding and is skipping some. Or could someone tell me a good replacement for the motor? Thanks to everyone for the assistance.
Re: Migbot Prusa i3 Unofficial Support Thread May 05, 2016 08:06PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 05, 2016 08:12PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 05, 2016 09:19PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 05, 2016 11:20PM |
Ax
Adam304
It's not done through Marlin, there's small potentiometers near the stepper drivers.
Re: Migbot Prusa i3 Unofficial Support Thread May 09, 2016 01:24AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 09, 2016 03:40AM |
veaceonee
If you adjust those pots, make sure you use a NON-CONDUCTIVE screwdriver. Otherwise it makes interesting noises, probably not to good for it.
Re: Migbot Prusa i3 Unofficial Support Thread May 09, 2016 09:43PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 09, 2016 11:40PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 10, 2016 12:04AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 10, 2016 04:21AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 10, 2016 02:01PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 10, 2016 04:17PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 26, 2016 08:56PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 26, 2016 10:14PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 26, 2016 10:59PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 26, 2016 11:23PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 27, 2016 03:04AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 27, 2016 11:34AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 27, 2016 11:52AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 27, 2016 07:42PM |
Re: Migbot Prusa i3 Unofficial Support Thread May 28, 2016 04:56AM |
Re: Migbot Prusa i3 Unofficial Support Thread May 28, 2016 06:32AM |
