Migbot Prusa i3 Unofficial Support Thread
Posted by jcabrer
Re: Migbot Prusa i3 Unofficial Support Thread
April 17, 2016 09:34PM
Ax
Adam304
jazzbassNick
My guess would be you've got your limit switches in the "+" instead of the "-" slots. If you look closely at the board, they're labeled.
I don't remember more than one driver, but it's been awhile. I'm sure one of the experts will chime in. winking smiley
Appreciated the quick reply, thank you. I checked and even reversed the endstop connections, still the same. The bed crashes front, x to the right, z straight up.
The driver i was was questioning is ftdiport from CDM v2.08.
Doesn't hurt to install both. It can only help if you're getting com errors. If you take a look at my Marlin 1.1 firmware, and can get it uploaded it should work. Sounds like the directions are set wrong in the firmware and should be as follows:
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_Z_DIR true
Thanks for your time in replying, again its truly appreciated. I took a guess installed the ftdiport driver to the COM3 device under device manager. I was able to upload the firmware through the arduino console, albiet with some red text in the logs. I still can't get any software to play nice though.
The motors still rotate in the wrong direction when homing. The extruder seems fine. Should I try to rewire the stepper motors? How? Link to your firmware?
April 24, 2016 12:55AM
Has anyone tried this PEI/Ultem as a build surface yet?
I have only seen good reviews on it and am considering giving it a go. The only problem I see is that I'm using the proximity sensor for bed leveling and wondering if this will still sense through the PEI sheet. I believe the sensor only has a 2mm range so with a 1mm PEI sheet and approximately another 1mm in 3M adhesive this could contact the build plate before sensing.
I have searched and found a plethora of similar sensors on eBay up to 5mm range which in theory should work. However they list all different specs that I'm not entirely familiar with.
My question is, what 5mm proximity sensor would be compatible with the Migbot and would it just be plug and play, only requiring level adjustment to dial in the nozzle height or would one also need to adjust something in the firmware?
April 24, 2016 03:57PM
The surface has been great for adhesion. Look back a little, not more than a few pages I posted with links.
Found that the PiBot sensor works well with pei-glass, light weight too.
Ax
April 25, 2016 12:27PM
Adam304
Ax
Adam304
jazzbassNick
Apologies, been a little on the busy side - Firmware's on github at [github.com]
Take the 1.1 firmware, it works a hell of a lot better. I'm currently testing the 1.1 RC5 build on my home Migbot, I'll have it converted over to all the configs soon.
For the rest of you all, I did a quick knock up of an overhead spool holder, that doubles as a LCD screen stand-off. It's basically a remix of my filament guide and an overhead spool holder I used to use. It'll happily hold 2 spools and just works. Find it here
April 26, 2016 02:34AM
Thanks you for the sharing. Appreciate your effort. smiling smiley
May 02, 2016 09:03AM
Hello everyone,
I have a problem with the Z axis of my Migbot Prusa I3 (the 3D Electron sold by 3D Printers Online Store).
I opened a new thread : [forums.reprap.org]
Any help would greatly appreciated. Thank you in advance smiling smiley
May 05, 2016 11:22AM
Could anyone tell me how to increase the extruder motor torque by increasing voltage/amperage through Marlin? Is it possible? Kinda lost since there isn't a physical driver attached. The motor isn't holding and is skipping some. Or could someone tell me a good replacement for the motor? Thanks to everyone for the assistance.
Ax
May 05, 2016 07:39PM
Adam304
It's not done through Marlin, there's small potentiometers near the stepper drivers.
May 05, 2016 08:06PM
this is also one of the possibility which haven't the loud sound because of too high voltage.
open | download - MkS_Base1.0.jpg (222 KB)
May 05, 2016 08:12PM
this is also one of the possibility which haven't the loud sound because of too high voltage. and i feel if your stepper is too hot also may due to voltage too high, try turning the silver screw and remember there must be no sound when not moving.,
May 05, 2016 09:19PM
it's been an hour for this upload to google drive as this is the hardship of these 1 year collection not complete as there is no complete stuff, 3d is learn and play and never ending, i don't like to lost promise but this uploading really take time: [drive.google.com]
May 05, 2016 11:20PM
Ax
Adam304
Appreciate the pic so much, thank you. Originally when looking at it, I thought it some weird capacitor or led. You rock.
May 09, 2016 01:24AM
If you adjust those pots, make sure you use a NON-CONDUCTIVE screwdriver. Otherwise it makes interesting noises, probably not to good for it.
Ax
May 09, 2016 03:40AM
veaceonee
Just make sure the Steppers are off by sending an M18 via the console of your preferred software, you can then use a standard screwdriver.
May 09, 2016 09:43PM
Hello all,
I am under the Marlin Version 1.1.0-RC3. (https://github.com/AxMod3DPrint/Migbot-Firmware)
I installed the sensor LJC18A3 H Z / BX for auto leveling.
But I have a little problem. When I run printing, the G28 is going very well (the Z is detected), he moved to G29 and there, it is as if the sensor is not triggered, continuous nozzle right into the tray.
The weird thing, I unplug the power supply, reconnect and recovery printing, and then everything works. I did the test with 3 differents impressions and every time I got the same result.
Any idea what's happening?
Ax
May 09, 2016 11:40PM
Sounds like the wiring. That sensor needs a Voltage divider circuit as per the circuit in Tom's Video, it's sounding like it's not reliably getting a signal, which would suggest the output voltage is too high.
May 10, 2016 12:04AM
I tried with the voltage divider, but in this case, the sensor no longer goes into "TRIGGERED" it remains "OPEN" even after detecting the bed.
But I do not understand why detection is well with the G28 and the G29 not to.
I'll try to compile with Arduino 1.0.5, currently I use Arduino 1.5.8
And also can be put more distance on Z_RAISE_BEFORE_PROBING and Z_RAISE_BETWEEN_PROBINGS
Maybe this will change anything.
Edited 1 time(s). Last edit at 05/10/2016 12:56AM by Ceax.
May 10, 2016 04:21AM
I recompiled the firmware with Arduino 1.0.5 (before I had 1.5.8), I also increased Z_RAISE_BEFORE_PROBING and Z_RAISE_BETWEEN_PROBINGS of 2 to 5.
I just made 2 trials and the problem did not appear.
Fingers crossed that it lasts over time.
Ax
May 10, 2016 02:01PM
Good to know it's sorted. Sounds more like the Arduino version. Marin 1.1-RC3 worked better with the old version, however, shortly, I'm going to be pushing RC6 to the github, auto levelling has been totally overhauled, Get your probe at the right height and you don't need to set an offset. I have it running on my home Migbot now and it's working fine.
May 10, 2016 04:17PM
Before changing version, I will take to print.
I try to improve little by little printer. Next step E3D a V6 head.
May 26, 2016 08:56PM
I have noticed that I am changing throats more often because the liner thing is coming out and jamming the nozzle. Maybe its because I use cheap Chinesium throats. Anyways, I am curious as to what will happen if I just pull that liner tube out and run without it?
May 26, 2016 10:14PM
veaceonee , have you put PTFE inside the throat? as there are many different factor, like no PTFE, filament not pure, or maybe the throat inside have some small metal chip which the manufacturer didn't do a nice job. if because of last one, do check these point which is common issue.
May 26, 2016 10:59PM
whenever I change the throats after a jam the PTFE tube is hanging out the bottom all burned up.
May 26, 2016 11:23PM
veaceonee , can you take a photo and also are you using filament that include metal or wood or glow in dark? by the way what brand you using?
May 27, 2016 03:04AM
i will upload a pic when I get it tore down and swapped out. I use 3D Solutech, Hatchbox, Foxsmart, Esun brands. I do have a spool of wood, but I use it very rarely. i don not have any glow in the dark or metal filaments. Could the throat be sticking out to far, thereby not getting cooled down enough?
May 27, 2016 11:34AM
veaceonee, one things about wood filament it very easy to get stuck on the tube and whenever i print using wood i would use ABS filament and heat the nozzle up to 245 to clean the throat before print (spent a little time and you may save the future trouble) and nozzle. as attach is the throat should be 0.8-2mm distance the max. please upload the picture so will be easier for me to guide you! smiling smiley
open | download - C_v6-1.75-U-3-500x500_grande.jpg (32.3 KB)
May 27, 2016 11:52AM
Forgot to say one more things for throat replica there are too many type, always remember different supplier, different quality, different size. So it's really hard to get the right one. Please measure and let me know the size. So at least have a better idea.
May 27, 2016 07:42PM
Took the printer apart, filament all jammed in the throat. Went into Cura, and noticed my retract was set to 4.5mm at 40 mm/sec. Changed it to 1.0mm at 40 mm/sec (as I read somewhere that I cant remember), gonna see if that helps. I havent done any wood in well over a couple weeks.
Did you want a picture of the extruder setup or the old throat?
*edit: I read on a Geeetech website (here) that a guy had good results when he drilled a hole in the heatsink that is right in front of the feeder, hence blowing cool air inside that area. Gave that a try.
Edited 1 time(s). Last edit at 05/27/2016 07:46PM by veaceonee.
May 28, 2016 04:56AM
veaceonee , the retract only can be max at 2.5mm-3.5mm why i don't go lower or hight because if i lower the print will have alot of spider web which i don't like. if too much it's will jam at throat as for the retraction speed, please only 20-30 not more as it will cause too much issue, let have an example if the heat up the filament will be soft and when you put in too fast it will jam. this is important and please please don't let the screw too tight, it will break the filament which is not a good things. hot melt, tight break. remember this.
open | download - 81fvr6KsHtL._SX425_.jpg (35.2 KB)
open | download - post-2-0-35359300-1440560329_thumb.jpg (47.6 KB)
Ax
May 28, 2016 06:32AM
Gonna stick my nose in here. Frankly, with the amount you'll be ending up spending on new throats to find one that actually works, you're better off getting an E3D and being done with it. The MK8 design is old and inherently flawed due to the way it transfers heat. I've had Lite6's on all my Migbots and regularly run 4-6mm retractions on them all and the same for the v6s on the 2 FB2020s I have. I've not had a full blockage in a very long time and the partials were my fault for not getting the PTFE tubing correcly into the Lite6'.
A Lite6 is £25.80 ($31.80, no Tax to the US) + postage direct from E3D and is about the same equivalent price in the US. There is absolutely NO reason to be using a crappy hot end assembly like the MK8 that comes on the Migbots as standard when you can get a well designed one cheaply like the Lite6. You will save yourself a lot of blood, sweat, tears, frustration, research and blockages if you print a mount and get an E3D. I'm speaking from experience here. I've had 4 Migbots, 1 has been converted into a FB2020+, but all my printers run either an E3D v6 or Lite6. I've not had an issue since I made the switch.
