Re: Migbot Prusa i3 Unofficial Support Thread October 16, 2016 06:53PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 18, 2016 03:05PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 19, 2016 04:58AM |
veaceonee
Got the printer running, and it working awesomely. Been looking into printing with ABS and came across this video.
ABS Tutorial
At 2:47-ish he says to just use Kapton tape with window cleaner for bed adhesion. Never heard of that, does it really work? Are all his other tips sound? Just looking for clarification on this.
Thanx in advance.
Re: Migbot Prusa i3 Unofficial Support Thread October 22, 2016 01:40PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 22, 2016 04:51PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 22, 2016 11:08PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 23, 2016 05:47AM |
Zurking
Hey All,
Its fantastic to see this thread still active and filled to the brim with helpful infomation.
My MigBot has unfortuently been collecting alot of dust in the last several months (moving around) But before I moved i bought a chinese E3D V6 direct drive hotend and had started modding my hotend mount (Using a remix of Axmod's E3D v6/Lite6 Direct Drive Mount http://www.thingiverse.com/thing:1511772 ) With alot of fiddling and tweaking ive got the mount attached and sturdy as can be.
My brain has turned to mush though, so if someone can give me a helping hand, would be greatly appreciated.
With this new hot end, the hotend / probe offsets must be well off from the orginal firmware, What settings would i need to alter in the firmware? I've had a look at the config and i believe the following are the ones i need to change;
#define X_PROBE_OFFSET_FROM_EXTRUDER -25
#define Y_PROBE_OFFSET_FROM_EXTRUDER -29
#define Z_PROBE_OFFSET_FROM_EXTRUDER -12.35
Would there be other changes required? As I believe the hotend is now more centered than the orginal, and is certaintly alot lower
veaceonee
Im trying to print this chess set in ABS for someone. It prints good until it gets to the top of the piece. can anyone shed some light as to what is going on? why does it print fine, then get all melty at the top? How can I fix this?
Temps are 230 on the Hotend..110 on the bed. Infill 25%
Re: Migbot Prusa i3 Unofficial Support Thread October 23, 2016 02:33PM |
Ax
veaceonee
You have 3 choices, run cooling (Good ABS can take it) for the top, Lower the temperature at the top or slow it down. Small details can be difficult to print. Seeing you have a burnt plastic blob in it I'd start by lowering the temp 5-10c and see what happens.
Re: Migbot Prusa i3 Unofficial Support Thread October 28, 2016 02:54AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 09, 2016 11:01AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 09, 2016 11:17AM |
veaceonee
Ax
veaceonee
I raised the infill to 50% and it print perfectly. Weird.
Re: Migbot Prusa i3 Unofficial Support Thread November 09, 2016 11:34AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 11:28AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 11:42AM |
Zurking
Hey Guys,
I've bumped into a little issue, i've installed Ax's firmware 1.1 - marlin 1.1 (Standard size) onto my printer. Tweaked the Zoffet but my prints are coming out like this;
Its asif the printer has just stopped printing the layers. I've tried;
-Printing from SD card instead of USB
-Slicing the model again with Cura
-Re upload the firmware
Now this is where it gets weird, i've just uploaded the orginal firmware (Large Bed, even though my bed is a standard 220x220) to the printer after downgrading Arduino and my prints are working printing perfectly.. just not centered. I used the larget bed as the standard firmware was giving me errors when veryiying in Arduino.
Any ideas? I'd like to use Ax's as i believe its more tweaked for the printer.. an was centered.
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 12:35PM |
Zurking
Hey Guys,
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 03:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 04:29PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 04:36PM |
Zurking
Hi Ax,
thank you for your reply I really do appreciate you taken time to help.
Apologies for the confusion, I was struggling to get the orginal standard bed firmwaren(Gary N. McKinney's prusa firmware) to compile in the version of Arduino., but his large bed firmware does compile and i dont get any of these issues (its just everythings not centered)
I am still very confused - Ive just your 1.1 Standard bed (220x220) firmware again and i'm getting the same results, its misaligned.. ive only seen something like this when an object was upside down when slicing. It seems its confused to where to put the layer.
I've tried your 1.1 Standard bed - no auto level firmware aswell, where i just enabled autobed leveling, but this has the same results.
I'm going to try and find a version of arduino that will compile the orginal standard bed firmware and give that ago next
Wes78
hey Ax do you have a copy of marlin 1.1.0-rc7 edited for the migbot?
I see lots of nice improvements In RC6 and RC7
seeing as im building back my migbot just as well upgrade the firmware too
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 04:42PM |
Ax
Zurking
Hi Ax,
Looking at that image, it's definitely adhesion/Z Offset. That's the only time that I see things like that when the Z Offset is wrong or I don't have enough Hairspray on the bed. Quick question, did you PID tune the Bed and Hot End?
Wes78
The Firmware on the Githum is RC6. I have RC7 on mine, but I can't support a standard Migbot anymore due to converting them all to Bowden, which required a lot of different settings. If you're going to use my Bowden/E3D Setup, then I can throw you the firmware.
Re: Migbot Prusa i3 Unofficial Support Thread November 14, 2016 05:27PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 15, 2016 12:56PM |
Zurking
Hi Ax,
Thank you for the reply.
The orginal photos may not have given it justice, but its not a adhessive/offset issue (though the hotend could of done with going down 0.1mm more maybe) The hotend stops printing the complete layer path, i dont know how to describe it.. it cuts its self short one side and then goes over the base outline layer on the other side
I've just downgraded my arduino to 1.0.5-r2 and uploaded the orginal firmware (Page 5 of this thread - MigBot firmware Marlin 1.0.2 Large Bed) I had installed when it was all working prevsiouly (orginal hotend)
But this is a for a large bed and i need to change my probe to 2 point grid so my printer doesn't try and pretend to be a hydrolic press. Also the same issue where things font get printed centered.
I can print perfectly again( even better quality with the e3d v6 hotend) with this old firmware.. so i'm stumped! I'd really like to use your firmware as i've read its tweaked for the MigBot (less jerking, optimized for th acrylic frame.. etc)
Have you tested the standard firmware on your machines? or do you only have the largebed versons?
Re: Migbot Prusa i3 Unofficial Support Thread November 15, 2016 05:27PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 16, 2016 06:20AM |
Re: Migbot Prusa i3 Unofficial Support Thread November 18, 2016 05:40PM |
Re: Migbot Prusa i3 Unofficial Support Thread November 18, 2016 05:46PM |
Zurking
Well great news! Re-downloaded your 1.1 firmware, used Arduino 1.6.8 and its printing fan dabby dosey! none of this strange side printing malarky.
I have noticed though, i was calibrating the Esteps on the old firmware, with no hot end and the extrusion was accurate on 100mm filament (0.4mm off) the orginal e-steps were;
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,398.269957,94.4962144} // default steps per unit for ultimaker //78.7402, 78.7402,1070,865.88
#define DEFAULT_MAX_FEEDRATE {225, 225, 3, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {3000,3000,100,10000}
and the 1.1 firmwares e-steps are;
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,398.269957,101.640122273} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {225, 225, 10, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {1590,1590,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
From that i'd guess my e steps will be out, or is the above calculated with a hotend and the push back you'd get?
Also a warning to anyone who purchases a chinese knock off of the e3d-v6 - You'll have huge mounting issues, as the mounting ontop of the heater fins is completely different from the orignal e3d-v6. Also they are much shorter, my nozzle barely clears the bottom of the X-carriage (1.5 clearance)
Re: Migbot Prusa i3 Unofficial Support Thread November 20, 2016 03:05PM |
Ax
Just re-calibrate the E Steps, they were set up for my machines, yours could be slightly different. Also, frankly, don't buy Chinese E3D Clones, you can get an E3D Lite6 damn cheap. Over here in the UK it's £21 (~$25) ex Tax and shipping direct from E3D. There's no reason to not buy an original.
Re: Migbot Prusa i3 Unofficial Support Thread November 21, 2016 03:24AM |
Zurking
Ax
Thank you Ax!
Eeep. I should of done my research. The chinese clones are actually the same specification as the E3D Lite6s. I'd assumed the mounting was different, but E3D had actually made 3 different styles;
http://www.thingiverse.com/thing:341689
When i first looked for the E3D v6 I only saw the $60 dollar one on there site, which was alot of money to part with for something which i may not even seen any results with. So purchased 5 x E3D-v6 lite clones for $35-40 which includles all with nozzles, nozzle throats, blocks, fans, PTFE tubing, heater elements & thermistors. I'd imagine alot of the parts are the same, besides the heater fins.
But I'm happy with the results from my clone, so I'll more than happy support the E3D development and purchase a genuine hot end.
Re: Migbot Prusa i3 Unofficial Support Thread November 26, 2016 05:46PM |
IBaz
Sorry if this has been covered before but does anyone know if it is possible to extend the range of the proximity sensor for bed detection?
I have just covered the bed with a sheet of PEI and now that the sensor has to read beyond the print surface to the aluminium it literally has to touch the PEI to get the correct print height for the first layer. Now the sensor has to sit lower than the nozzle so other than scraping across the PEI it will now crash into the print.
Is there something in the firmware that can be changed or another sensor that will detect at a further distance?
Re: Migbot Prusa i3 Unofficial Support Thread November 29, 2016 09:07AM |
IBaz
IBaz
So I have finally received what was supposed to be a 5mm (4mm from factory?) proximity sensor to replace the original item. Unfortunately this sensor doesn't even detect the bed under the PEI and seems to have less range than the original unit.
Can anyone recommend a replacement item that will work? I'd rather keep the original style sensor as I have an adjustable mount suited to it. I just can't seem to trust the specs on these things.
Re: Migbot Prusa i3 Unofficial Support Thread November 29, 2016 09:26AM |
