Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2016 06:04PM |
Wes78
An alternative to the factory sensor, especially for those that want to print on glass. I have this sensor on my other printers and it works Flawlessly.
It's a plug and play. The only thing will probably have to do is invert the in endstop signal.
[www.dropbox.com]
[www.filastruder.com]
Re: Migbot Prusa i3 Unofficial Support Thread December 08, 2016 08:58PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 08, 2016 09:18PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 08, 2016 10:32PM |
jazzbassNick
When this happened to me, I found that some of the threads of the heater block had actually disintegrated and fell out. I think I ended up getting a set of 5 heater blocks on Amazon.
Re: Migbot Prusa i3 Unofficial Support Thread December 09, 2016 01:37PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 09, 2016 02:39PM |
uberjay
Thanks... don't suppose you still have the links to the blocks you bought?
Also... did you replace the threaded tube as well or just the block?
Thanks,
J
Re: Migbot Prusa i3 Unofficial Support Thread December 09, 2016 02:42PM |
jazzbassNick
I had replaced the threaded tube prior.
The heater blocks I ordered aren't available - I'm not sure I'd recommend anyway since it didn't have a grub screw to hold the thermistor in, had to use kapton tape.
Here's the links to both the tubes and the blocks:
[www.amazon.com]
[www.amazon.com]
Looks like there's some similar available though.
Re: Migbot Prusa i3 Unofficial Support Thread December 09, 2016 02:49PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 12, 2016 11:13AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 12, 2016 11:18AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 12, 2016 11:25AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 12, 2016 11:44AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 12, 2016 11:58AM |
Wes78
....actually let me get straight to the point, when you have leaking heater block . More often then not means you nozzle isn't fully seated against the heat brake. There should not ever be a gap between the nozzle and the heat brake. This will not only cause a leaking heater block but also increase your chances of a jam.
My suggested procedure would be screwing in the tip to the heater block once at bottom back it off roughly half of turn then screw in the heat break until it bottoms out on top of the nozzle.
Then putting a wrench on the heater block and one on the nozzle tighten them firmly just be careful not to over tightened and stripped the heater block.
Re: Migbot Prusa i3 Unofficial Support Thread December 12, 2016 12:03PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 16, 2016 05:19AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 01, 2017 10:05PM |
IBaz
Wes78
[www.dropbox.com]
Thanks Wes. I found a local company that supplies a similar sensor based off that one. Going to give it a go.
Re: Migbot Prusa i3 Unofficial Support Thread January 01, 2017 10:23PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 01, 2017 10:50PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 01, 2017 11:00PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 01, 2017 11:14PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 01, 2017 11:20PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 01, 2017 11:23PM |
IBaz
No glass. Just the heatbed under the aluminium build plate as per the OEM setup. I've just added a PEI sheet to the top of this originally thinking the original probe would have enough distance to read through the PEI but it didn't. This is why I went for this probe but it just doesn't seem to sense correctly.
Re: Migbot Prusa i3 Unofficial Support Thread January 02, 2017 04:43AM |
Re: Migbot Prusa i3 Unofficial Support Thread February 21, 2017 04:42PM |
Re: Migbot Prusa i3 Unofficial Support Thread April 27, 2017 05:16PM |
Re: Migbot Prusa i3 Unofficial Support Thread April 27, 2017 06:05PM |
sdw_nj
Does anyone know what the proper name for the connectors that plug the end stop wiring in to the board? I'd like to replace the wiring on my y axis end stop. I was able to identify a compatible switch for the end stop but am still trying to figure out what the compatible part would be for the wiring connector.
Re: Migbot Prusa i3 Unofficial Support Thread April 14, 2018 01:17PM |
Re: Migbot Prusa i3 Unofficial Support Thread July 19, 2018 02:01PM |
Re: Migbot Prusa i3 Unofficial Support Thread October 11, 2018 07:04AM |
