Folger Tech 2020 i3 Printer Kit (Official Thread)
Posted by Dan_FolgerTech
Re: Folger Tech 2020 i3 Printer Kit (Official Thread)
May 28, 2015 12:58PM
Sorry if this has been covered already, but is there a kit from Folger to convert my Folger acrylic frame printer to the 2020 aluminum frame?
Or a parts list?
Edited 1 time(s). Last edit at 05/28/2015 01:07PM by Easy.
May 28, 2015 01:59PM
Easy
Or a parts list?
There is an upgrade kit in the works from my understanding.
Is anyone else having issues with the extruder stepper motor getting really hot? Hot enough to start pulling the screws through the X-axis slide? I've turned down the driver as far as possible, while maintaining accuracy. Turned the fan on constant. I'm running out of ideas.
Edited 1 time(s). Last edit at 05/28/2015 02:01PM by Devil Inc.
May 28, 2015 02:47PM
My acrylic frame stepper motor does get pretty hot, not that hot though.
May 28, 2015 08:52PM
animoose
It's the other way round for me: my printer kit has shipped and should arrive tomorrow, but my filament has a label and hasn't shipped. Both labels were printed on Monday (which was a holiday, so let's give Dan and John a break!).
... or not. I got the filament today, but with the tracking number for the printer kit. thumbs down
May 29, 2015 10:07AM
Devil Inc
Dan/John. I'm having issues with the side mounted spool. The extruder is 'slipping' trying to pull the filament once it gets tight with the spool. I had a jam because of it. If I can source a piece of 20/20 quickly, I'm going to relocate the spool up top similar to the OG i3 users to see if removing the side load helps. Just an observation I'm noticing. A 6" long piece and a few mounts would work, if my measurements are correct.
Did you see the updated guide? There is a small wire harness clip that we attach to the top left motor to hold the filament from doing what you described
Dan
May 29, 2015 10:09AM
animoose
Sorry bud! We are trying to get them out today we are 1 person short this week (not your problem though) and we are struggling to keep up with the printed parts while we wait for the ones from Crunch.
Dan
May 29, 2015 11:10AM
I received my 2020 i3 yesterday and have completed the build for the most part. I have a few wires left to deal with, but overall it's mostly done. Found a few spots that I would change in the manual but for the most part it went smoothly. Thanks for making a great manual Dan. A few larger printers could have helped me in a few situations but I made it.
So for the configuration aspect, should I be following the configuration guide for the original acrylic prusa i3?
May 29, 2015 11:40AM
Dan, I did see the updated guide, unless it was updated today. As for my extruder motor temps, dialing the current up or down, doesn't make a difference. It's HOT after a 6 min print.
I'm going to try the spare driver board tonight to see if that helps.
May 29, 2015 09:41PM
Alright ran into my first big problem. Looking for advice now...
I got the printer all up and running, I had yet to attempt a print. I tested all the features (heat, all axis's, etc) I set all the end switches and was working on leveling the bed. Was having some issues with the x-axis carriage/extrude (I guess is what its called) as it didn't want to stay level... it wanted to change as it was going up. Either way I was working on that and then I sent the Z to home and as it got close to home I suddenly heard a pop and my computer shut down. My computer was completely unresponsive. Wouldn't power up at all or anything. I check over everything on the computer nothing. It's a MS Surface so there really isn't much to check.
So back to the printer I look over everything and can't find any problems at all. I tried to identified where the pop was from and didn't see any problems. I check all the connections and nothing is shorted at all, I double checked all the images in the manual and everything was identical. At this point I just assume the computer crashed or something. I'll deal with that later and so I attach it to my other computer. The computer doesn't recognize the printer at all. Can't connect to it or anything. I check the cable, restart everything. Nothing at all. No usb sounds when plugging in the arduino at all. Although the lights come on and everything. If I press the reset button on the ramps it appears to reset (the green led blinks). If I press a limit switch they light up.
I decide to separate the Ramps and Arduino to look at it, see if I can get anything out of it. The lights come on, it seems to respond to the reset button just fine. Just no access to it via USB. Upon removal though I did spot a little bit of white stuff on the back of the ramps board. Like if a cap popped or something but the arudino looks perfect. Nothing to my eyes looks bad.
So curious if anyone has ideas of what happened and how to fix it? I'm considering going back to work to pick up my spare arduino mega there... just don't want to fry that one too.
May 29, 2015 09:50PM
Devil Inc
Swapped out the extrude driver and it seems to be cooler than before even after a 45min print. I have a 2nd fan that I'm going to work into the design to see if I can cool it down some more before sourcing a different extrude motor.
May 29, 2015 11:12PM
Okay, here is a few pictures of the build progression.
Day One
Day Two
I guess I didn't take any of it 'finished', but I have a few after the extruder mod and swapping the X axis endstop to the left side.
'Finished'
I'm sure there will be more to come. Working on a few things to print.
May 30, 2015 03:40AM
Alright I replaced the board with a known good authentic one I had at work... and got everything up and working.
Day 1: Arrival
Day 1: 18 hours later (yes I went to sleep, and yes I did other stuff).
First Print: Cube
Third Print: Cube
Let's not talk about that second print...
Currently facing issues with the prints not being too "clean" and the first layer really doesn't put much of a layer down.
May 30, 2015 08:50AM
As for an edit-able first post link, it's usually a good idea to expect posts to freeze after a day or so; the links you put in them can instead go to a page on your own site that you can change, without needed to change the link in the post.
May 31, 2015 12:06AM
Anyone have trouble tightening the SK8 screws to grab the rods? I cranked down on one and the rod still slid right through. Am I doing something wrong?
May 31, 2015 01:09AM
markts
How easy is it sliding?
At first I forgot to tighten mine and it moved but after that I tightened it and no movement since.
May 31, 2015 01:10AM
I just realized all my prints are backwards as far as the x-axis. I think it was designed to have the limit switch on the right (when looking towards the front of the printer) as that stepper motor wire is backwards compared to the rest. Still though all prints are backwards which presents a problem...
Not sure if I invert the x in the printer software will fix it? Don't really want to re-wire that aspect.
May 31, 2015 01:46AM
I couldn't get the software sorted out to home it to max and offset to 200. I'm new to G-code and Marlin/Arduino programming. I tried for a few days and said the heck with it and moved the limit switch to the left and flipped the stepper motor wires to match the rest.
Repetier would home it to the right(max) and set it to zero. I tried following a string of info on Github, but it kept breaking the firmware program. So i switched it the left.
Edited 1 time(s). Last edit at 05/31/2015 01:47AM by Devil Inc.
May 31, 2015 11:05AM
Tenny
markts
The screws that go through the SK8 look like they are supposed to slightly "crush" (?) the SK8 to get it to grab the chrome rods. No matter how I tighten them, the rods just slip right out. This is item 5 of step 4 in the instructions. "Be sure to tighten the tension screws on the (4) SK8's to secure the chrome rods in place."
May 31, 2015 12:29PM
Do you have a set of calipers and/or mics to take some measurements of the SK8 bore and the rod diameter?
May 31, 2015 12:53PM
Thanks - I managed to "convince" the SK8s to grab. smiling smiley
On to the next issue I'm having. I have installed the bearings on both rods and the printed guides on the aluminum plate. If I "pop" the rods into the guides, it's impossible to move the bed along the rods. It's as though the printed guides aren't lined up or accurate enough. If I pop two bearings (on one side) into the guides, it's obvious the other side doesn't line up - the rod moves as I slide the bed.
Hope critical is it the rods are "popped" into the guides? Can they sit ON them with the tie wraps holding them on?
Sigh.
Edited 2 time(s). Last edit at 05/31/2015 01:08PM by markts.
May 31, 2015 02:17PM
Tenny
Yep. Once again this is something the Folger manual gets wrong. Looks like they haven't fixed it in the manual for the new printer.
Just flip the motor cable where it plugs into the RAMPS. You can also do it in firmware but this is easier. Turn off power to the board first.
May 31, 2015 03:05PM
Vanbot
Yeah I tried this and it's still not working properly. It would just go the opposite way of the end stop.
Steps I've done thus far: So I changed the firmware and inverted the x axis: #define INVERT_X_DIR false (was true before) Then I changed it to a max-end stop versus a min end stop: #define X_HOME_DIR 1 Then I manually moved the endstop cable from the x-min to the x-max.
Now my problem is that technically (I think) when it hits the end stop it should realize that's 200 not 0? So right now in the rep host if I home the X-Axis, it hits the max end stop and then it sets the number to 0. So when I press right it increases the "x number" but it doesn't move (it just increases the x value). It will not go left unless that number is > 0 obviously.
Edited 1 time(s). Last edit at 05/31/2015 03:05PM by Tenny.
May 31, 2015 03:43PM
Tenny
Vanbot
In Repetier if you open Printer Setting and then the Printer Shape tab what values do you have for Bed Left and bed Front?
May 31, 2015 03:45PM
Vanbot
0
0
Ok I see in there I have x home as min, just changed it to max and it seems to be proper. Now I just need to figure out how to make it this way in Octoprint
Edited 1 time(s). Last edit at 05/31/2015 03:47PM by Tenny.
May 31, 2015 04:03PM
That's the same thing I couldn't figure out. As I mentioned in one of my previous posts, I attempted to follow a handful of threads on Github, but it bugged the firmware program, and I couldn't follow it to figure out a cause/fix.
May 31, 2015 04:18PM
Ok I got it fixed.
So if you keep the cables wired as they are in the manual this will fix it:
Change the following in configuration.h
  1. #define INVERT_X_DIR true to #define INVERT_X_DIR false
  2. #define X_HOME_DIR -1 to #define X_HOME_DIR 1
  3. With the printer off PHYSICALLY move the x-axis stopper to the left one set of pins (this makes it so it's the x max instead of x-min)
Now if you are using rep host, you need to go to printer settings > printer shape and change home X: from min to Max.
In Octoprint it looks like nothing is needed.
Now there are ways of changing pins.h so you don't have to do #3 but I prefer to do it this way.
EDIT: Ok, yes this fixed the problem. The error i was having after this was another change I set that I forgot about.
Edited 2 time(s). Last edit at 05/31/2015 07:56PM by Tenny.
May 31, 2015 05:01PM
I had the same problem getting the SK8s to grab the rods. I applied a tiny piece of kapton tape to each end of each rod and that helped.
Edited 1 time(s). Last edit at 05/31/2015 05:02PM by animoose.
May 31, 2015 05:22PM
That's good thinking. I opted for vice grips to compress it slightly.
How well do your bearings slide down those chrome rods when it's all connected to the aluminum bed?
May 31, 2015 05:33PM
markts
I haven't attached the bed yet. I'm savoring each step of the construction process smiling smiley. When I first put the bearings on the rods in step 4 they felt graunchy. They are a little smoother after manually moving them back and foward. I've read about this in other forums, so I'm not worried by it.
May 31, 2015 06:11PM
I'm so glad you said that! What forum did you see that in?? Mine are also crunchy, but when I installed then into the holder they get very difficult to move.
