Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 09:34PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 09:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 09:41PM |
animoose
@unshockable, try measuring the resistance across the screw terminals. You should see a few ohms (2-4). .
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 09:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 10:01PM |
animoose
This shows a LED. Have you checked for 12V coming in? Obvious, I know, but we've all had our moments of measuring the noise. Failing that, I'd vote for a failed MOSFET on the RAMPS board.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 11:56PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 12:18AM |
219C seems too high for PLA. What brand are you using? I consistently use about 200C for Hatchbox PLA, but that can even be too high in some cases.Quote
animoose
Success!! I printed a 10mm calibration cube (http://www.thingiverse.com/thing:667281) and here it is (https://goo.gl/photos/Gv8T4RPxkmQn9TRaA). The X and Y dimensions are quite accurate, at about 10.5mm. The top collapsed, and I could see from when it was about 80% done that the sides were becoming uneven. Could this be due to running it too hot? The Folger setting use 219C for PLA, but Devil Inc said a few posts back that this is too high.
Anyway, no time for more tonight, but this is a big step forward. It's alive!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 12:19AM |
animoose
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 12:26AM |
widespreaddeadhead
animoose
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 03:13AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 09:42AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 09:59AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 10:03AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 12:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 12:23PM |
The7ank
I'm not sure if this has been asked before, but I have been having problems with my Z axis binding on one side and going uneven. My X whenever I hit the home button in repetier moves a little bit to the right and stops, it will also just keep ramming the endstop (the light on the endstop turns on) I have to keep hitting home to get it all the way over and then it wont accept any more commands. With all that going on... my Y axis works fine at least.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 01:31PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 01:38PM |
The7ank
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 02:52PM |
widespreaddeadhead
The aluminum block should be easy to find on eBay. I just my e3d6Lite hotend in the mail yesterday. Can't wait to install it. Many people complain about the stock hotend in the acrylic thread, but I've gotten some great prints with it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 04:05PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 05:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 09:16PM |
animoose
I really think the MOSFETs on the RAMPS board could be the problem. You've proved the extruder and the wires that go to it are good. Here's a couple of ideas but please not that this is pure speculation. I guess from previous posts that you are pretty engineering-savvy...
animoose
1. Attach the extruder to the middle set of connectors on the connector block, and figure out something in configuration.h or one of the other firmware files that will make it use this for the extruder.
2. Replace the RAMPS board. I don't remember if you've already tried this.
3. Stare hard at your RAMPS board. Maybe there is a dry joint on it. Touch each solder joint briefly with a hot iron and some fresh solder, especially the MOSFETs.
4. Desolder the MOSFET that drives the extruder and solder in a replacement, or swap it with the one that the middle set of connectors uses. Or at least put the MOSFET on a transistor tester and see if its alive.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 09:41PM |
Unshockable
You found me out! I'm an electrical engineer.
Unshockable
I'll try them in this order: 1, 3, 4, 2. I don't have a spare RAMPS board, and the lousy ones are $30 on Amazon. I'm in Canada, so there's a lower selection of parts.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 09:45PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 09:55PM |
animoose
Unshockable
Me too, before I found that software involved less risk of things going bang.
Unshockable
I really recommend the one I mentioned a few posts back. It was very nicely made on a visual inspection. The link is [www.amazon.com] and in the US at least you can get it on fast delivery. Good luck!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 11:48PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 16, 2015 11:55PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 17, 2015 12:27AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 17, 2015 08:25AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 17, 2015 09:56AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 17, 2015 10:10AM |
markts
Anyone find a good fan duct to print to let you blow air onto the part being printed? I see a bunch, but I don't see how they attach to the head.
