Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2015 10:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2015 10:33PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 01:35AM |
JoeH
I was toying around with lower temps for PLA last night. I had a somewhat complex part to print as a "how fine can I get" test, and I was having issues printing it. It had lots small details and needed lots of supports that were not supporting! I started with 0.05mm layer thickness, and went up to 0.1 with the same results. ...
Anyone else have this issue?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 02:42AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 12:03PM |
Devil Inc
Ordered my E3D V6 hot end last night. Not to decide what style of extruder do I want to build it into. Bowden/Wades? I kind of like the Airtripper drives as they are direct drive so they are compatible with most of the parts in my MK7 extruder. I'm open to options and opinions.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 12:31PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 12:57PM |
Tenny
Devil Inc
Curious why you didn't go with the lite version? I was looking at doing the lite version with this mount ( [www.thingiverse.com] ). I do not plan to print anything other than ABS so I don't need the extra heat.
My biggest concern with the full E3D V6 is dealing with the extruder as mine is working well and I tend to screw things up when I try to fix them.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 07:13PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 07:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 07:34PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 07:56PM |
markts
That's interesting - I was looking for something to print to tension up the Y-axis belt. Mine is definitely looser than I'd like - I can move the bed back and forth without moving the motor. I don't see any impact on the print, so maybe I shouldn't worry?
How did you add tension springs?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 07:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 10:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 10:39PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 10:48PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 11:20PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 11:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 11:25PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 11:35PM |
hockey9999
Devil, try this x tensioner, I didn't lose any room on the x axis on my acrylic Folgertech with it.
I only used the part the bearings go in to, the other half is specific to the rework idler end. The one you already printed for the outside of the idler should work fine.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2015 11:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2015 01:59AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2015 08:29AM |
Tenny
Uncertainty
Hello all,
Got it working!
How long does it take you guys to heat your glass bed?
Mine take >25minutes from 20c to 100c.
Ouch, mine takes about 10 minutes max to get to 100c. Are you sure you wired yoursk right?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2015 12:15PM |
markts
Tenny
Uncertainty
Hello all,
Got it working!
Details? Do you insulate the bed? Plain glass or something else? In an enclosure?
I just laid a piece of cardboard on it while heating and it helped immensely.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2015 07:59PM |
Tenny
Uncertainty
Hello all,
Got it working!
Ouch, mine takes about 10 minutes max to get to 100c. Are you sure you wired yours right?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2015 10:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2015 10:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 09:49AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 12:43PM |
markts
After witnessing some "play" in the Y belt, I installed a spring tensioner. It seems much better, so I started a 2 hour print. About 20 minutes in I heard a strange sound and found the bed had shifted. I thought the belt slipped because it started printing basically off the bed (on the side away from the endstop). Something must have bound up, so I tried removing the tensioner, but now the belt is stretched so that's not an option.
I'll have to do a smaller print to see what's going on. I'm hoping it's something simple.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 01:16PM |
