Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 08, 2015 12:34AM |
markts
@therippa - what settings did you use to design/print the LCD holder? I tried a couple with different infill settings and percentages, but I never know what to pick. One turned out ok (honeycomb, 70%? 80%?), the other crumbled when I tried to install it (recitilinear, 70%) Should they be 100%?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 08, 2015 07:31AM |
wderoxas
therippa
ejnelson
markts
ejnelson
Anyone have trouble getting the reprapdiscount smart controller to work? mine only lights up when the computer is connected via USB. the point of the controller is to be able to use the machine when the USB is NOT connected. what the heck.
I had the same trouble, but apparently others got it to work out of the box. Check my post on page 5. I had to upgrade to the latest version of the firmware (Marlin) to get it to work.
Hey thanks for the quick response. I actually just flashed the marlin fork from therippa because i plan on doing inductive sensing too. I also, just tried using "#define KILL_PIN -1", no change. It seems that my LCD panel works, I can use it to control things on the machine, but it only lights up when I have a USB connection to my computer. As soon as i disconnect, the LCD shuts down.
That's weird, it works me fine when not plugged in to USB power.
Yeah, it should work as long as the psu is on. How about manually triggering any endstop while your not connected to usb and psu is on. Does the led on the endstop lits up?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 08, 2015 08:46AM |
go_gn
So I fixed my X axis problem by moving the endstop pins to Xmax on the RAMPS board. Only to run into another strange problem that didn't happen before.
I'm having a problem with the extruder.It worked fine before. The temperature display on Repetier is behaving strangely. I don't know what the heck is going on.
It starts off at 12degC , which is strange, because that's not the room temperature. Then after I turn it on, nothing happens for almost 10 seconds. it just stays at same temperature. I touched the extruder with a piece of paper to see if it was heating and apparently it was , as the paper started to blacken. Then I check the temperature on the screen again and by now, it shows 88 deg C. but rising very slowly, even going back sometimes. Then it kind of tops out at 105 - 106 , sometime 110degC and stays there fluctuating up and down . Command still shows heating extruder. I checked the thermistor and heater wires, no loose contact or anything.
What is going on??? And how do I diagnose and fix this?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 08, 2015 02:29PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 08, 2015 04:19PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 08, 2015 04:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 08, 2015 07:54PM |
ejnelson
wderoxas
therippa
ejnelson
markts
ejnelson
When not connected to USB power, only from the power supply, the end stop triggers do not light up any LEDs when activated....
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 09:29AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 01:17PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 02:18PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 03:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 03:38PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 05:45PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 06:30PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 07:10PM |
awmyhr
@mel0n: is there a guide for how you are using Octoprint with the Folger? Did you replace the Mega?
@all: Hi, been lurking a few weeks; just got my kit today! Now my boy and I gotta put it together...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 08:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 08:44PM |
Mine was also warped when i got it. To ensure that the glass and heater will get a better/larger contact area, i sandwiched two 5mm cork boards between the heater and the aluminum plate. Cut out the areas where the heater and thermistor cord will pass through as well as for the head of the bolts for the bearing pillow block.Quote
JimF2799
Hi folks - Just started putting together my kit and the heater for the bed is warped. Will this go away once it is used or do I need to get it replaced? It would seem IMHO that I would have heating issues if the glass plate isn't making contact across the area of the heater. How much will the glass clamps mitigate this issue? Thanks - Jim
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 09:55PM |
awmyhr
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 10:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 10:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 10:26PM |
hobbes
Finally got my printer today. I'm checking all the parts. Noticed through the bag that some parts on this board were bent. Could an expert set of eyes tell me if i should request for a new part or will this work just fine?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 10:29PM |
If you aren't up for tinkering haproxy on the pi, then port forwarding on your router might be easier. Forward a port of your choice to pi's ip:80.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 10:46PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 10:54PM |
tadawson
Meh . . . 128 bit encrypted OpenVPN tunnel into the network, call it good . . . and don't have to screw with anything on the host side . . .
- Tim
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 11:00PM |
tadawson
hobbes
If it bugs you, bend 'em back vertical, but from an electrical standpoint, unless the tabs are touching, it's irrelevant.
In this day and age of cheap and Chinese, consider yourself lucky that the parts are *ON* the board at all . . .
- Tim
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 11:04PM |
Garben
tadawson
hobbes
- Tim
Agree, the bent parts in most cases are not going to hurt you. I would be looking at the other side of the board for bad and bridged solder joints. Like this
[attachment 57809 image.jpg]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 11:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2015 11:38PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 10, 2015 08:30AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 10, 2015 08:45AM |
wderoxas
animoose
Today's tweak. Now I can see things as I print (brightness adjustment to follow).
ejnelson
Has anyone added a 2nd fan to be used as a PLA print cooling fan? I know someone designed a fan diverter to divert some of the air that blows on the heat sink for the hot end, but would it be possible to just add another fan so that you don't have to take off the diverter every time you want to print ABS?
