Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 05:12AM |
CheopisIV
I was almost able to put a sheet of paper in there so 2mm should do the trick
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 07:40AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 08:24AM |
sk8
mike3
Looks good sk8 I'm still working on my printer,, It was missing a lot of nut and bolts being metric I'm having problems located them.... but strangely it has extras of others? Its frustrating waiting for your printer then not being able to complete it because of missing such small parts..going to harbor freight later,, I think they sell metric nut and bolt kits..
Mine was also missing some, but I just winged it. Use the extras that you got, the only things i needed that weren't in the kit was some wider washers than they have provided. The ones they give you aren't great for securing the corner brackets that holds the y axis belt. And in the instructions that they had some of the wiring is wrong on the board, I can post a picture later if you want of the correct wiring.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 08:27AM |
[email protected]
[imgur.com]
[imgur.com]
[imgur.com]
Checked this morning the socket head screws are the only ones I got to fit the larger T-nuts. When I went to try the pan head ones I found I had not noticed the diameter of them.
Wow sorry about the size will figure how to make pictures smaller. Ok that's better at least it's not messing up the forums with 4 pages of scrolling.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 08:36AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 09:27AM |
zarnold16
I was wondering where I could find a BOM for this printer I didn't seem to see on on the website or the G-Drive? My printer will be arriving Saturday if USPS doesn't mess up and before I start building I wanted to make a checklist for the parts to see what I'm missing.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 10:22AM |
mike3
zarnold16
A BOM would have been nice.. I havn't seen any except what's printed on the separate packs of parts you receive in the kit
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 10:56AM |
wderoxas
Got some free time..
Here's how long from the original:
[attachment 58651 comparison.jpg]
If you notice from the photo (encircled), i removed the slot along the line between the bearing holder and the nut holder. I cant find any reason for it to be there except probably when the original design was made.
Here is the STL file (no slot):
[attachment 58650 1xx-end-motor_2mm_longer.stl]
With Slot:
[attachment 58652 1xx-end-motor_2mm_longer_with_slot.stl]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 12:00PM |
mike3
Got the metric stuff.. you were right you need the larger washers.. I also had to use the socket head screws on the larger T-nuts as nothing else would fit... other pan heads were too long for there purpose.. anyway got the thing together,,, And since you are up and running .. some pictures would be great .. I am at the wiring stage.. On the where the steppers plug into the Ramps.. in the pictures it shows the wiring colors looking at the board right to left green on the left except on the third its reversed .. is that correct.. thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 01:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 01:51PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 02:28PM |
Neverdone
I just purchased my Prusa about 2 weeks ago! Started assembling it Tuesday and am having a lot of fun so far putting it together. I have also been reading some of the posts on this thread but wanted to ask, are there any modifications you guys recommend right off the bat? I am planning on replacing some of the hardware because I am not too excited about how it fits, ground down a couple pieces for again a better fit.
I just downloaded the file for the Z-Axis standoff cause that seems like a REALLY good idea.
Thanks for all your help!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 02:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 04:07PM |
animoose
cvanclev
Well, got all the hardware assembled and just finished configuration. Officially up and running! Well, sort of. Did the first manual tests in Repetier, and was able to move the X,Y, and extruder steppers. However, there is absolutely no response from the Z axis motors. I've noticed that the manual communication is glitchy at best, but I'm hesitant to start a full print without at least getting the Z to respond manually first. I tuned my driver to 0.35 volts, based on a recommendation early in this thread. Absolutely zero response. Going to try swapping the driver with the extra that was provided later tonight. Until then, anyone experience a similar issue? Pictures to follow soon!
Have you tried homing the Z motor first in Repetier? As I recall, the manual control won't drive it until you do this. If you are worried about not having the position right, click home and manually press the end stop switch so it thinks it's homed.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 04:20PM |
cvanclev
animoose
cvanclev
Turns out my polulu driver was not functional. Switched for the spare one and fixed the problem. Bigger issue now though While tuning the drivers, got through three before I barely slipped with the multimeter probe and bumped the pin next to it.. small pop and loads of smoke, looks like I fried a component on the Arduino board. Has anyone experienced this before? Do i just need a new Mega, or a new ramps/driver setup as well? Mega is fried for sure. Component is visibly torched. Really wish there was a better way to tune these, unless I overlooked something.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 04:36PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 04:53PM |
cvanclev
Huh. Might try just the Arduino as the budget is tight and the RAMPS board appears okay. Is there a better way to tune the drivers? Considering putting a dab of hot glue on the pins right next to it if they're that crazy close to a short.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 05:11PM |
animoose
cvanclev
I was just really, really careful the second time, and didn't obsess about getting the voltages exactly right, just in the ballpark. You'll know if they are really out - either the motor will skip or it will get too hot. I also stuck Kapton tape on the USB housing of the Mega board, as it's very close to the RAMPS board and I worried it could have been the source of the short (probably not, but I decided to play safe).
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 05:23PM |
cvanclev
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 05:28PM |
mel0n
I am super happy with my E3D V6 so far. The hot end temp curve is insanely smooth now. It used to drop/overshoot by +-5 to 7 degrees while printing. I think that was due to the 40W heater, and horrible thermistor placement. The E3D has a 25W so it can heat more frequently without overshooting, and since the heater-block is smaller the whole thing comes to temp faster even though its 15W less!
I will say that the fiberglass sleeves for the thermistor are pretty crap, but one you get it in there really good, having direct contact with the heat block is MUCH better than that crappy metal sleeve crimped on the stock thermistor. The thermistor is also placed as close as possible to the nossel so the temps are really accurate. I have been able to print down to 0.05mm layer height with the E3D and the print quality is AMAZING. At that layer height you can't really even distinguish any of the layers from each other.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 07:20PM |
tadawson
Had you run a PID tune on the 40w, you would have been in the same place . . . the PID values in Marlin aren't correct for much. Mine was all over with 40w as per defaults, but was a straight, flat line after tuning. I am on an E3D as well now, and actually wish I still had the 40w . . if I agressively cool bridging, the 25w can't keep up, a problem I never had with 40w . . .
- Tim
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 07:41PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 23, 2015 09:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 24, 2015 12:32AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 24, 2015 01:11AM |
therippa
Does anyone know what might be causing this waviness? I can't find it documented anywhere online...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 24, 2015 02:27AM |
arxidon
therippa
Therippa try using Cura instead of Slic3r. I had similar results in Slic3r but it went away when I switched to Cura. Also Cura seems to get overhangs better I'm not sure why.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 24, 2015 09:51AM |
arxidon
therippa
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 24, 2015 10:09AM |
therippa
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 24, 2015 11:49AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 24, 2015 02:41PM |
