Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 08:19AM |
[email protected]
I received a "professional ceramic alignment tool" AKA a non conductive screwdriver for adjusting my steppers. Is this not shipped with the kits normally to avoid shorting the steppers?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 09:47AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 10:02AM |
mike3
[email protected]
Yes it is.. but from reading the threads its the Multimeter probes that usually end up shorting the drivers out.. I think instead of placing the ground probe on the board itself .. I will find somewhere more safer that is connected to the ground..
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 10:08AM |
animoose
40, 40, 90% for the first three and 150 for travel speed. I have tried cranking it up quite a way from these without hurting quality in most cases.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 10:44AM |
therippa
At least I know that some day if I become the father to a very fussy baby, I'll be prepared, because I went through the experience of building a 3d printer.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 10:46AM |
[email protected]
My Z-axis bearings fall out! Thinking of pushing them up out of the way inside the holders and then running a little hot glue around the opening so they do not slide out. Any thoughts anyone?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 11:15AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 11:20AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 11:26AM |
Okay thanks i was looking all over the internet to see if they where. I was wondering why they were there.Quote
[email protected]
zarnold16
Are the little black threaded thing the 2020 L bracket set screws? I just got the kit in the mail and I have started to build it.
For the L-brackets yes wished I figured that one out sooner!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 11:28AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 11:47AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 12:01PM |
zarnold16
My M3 screws are 25mm not 20 mm, is that a problem? Nevermind my bag has 31, 25mm bolts extra. Im actually missing all 7 of my M3 8mm bolts.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 02:20PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 03:12PM |
mike3
installed Arduino and uploaded to the Arduino board successfully .. I am able to home X,Y and Z but the manual says X,Y should home in the back right corner,, but My printer homes in the front right corner is this correct? I moved the X stop to the left and set X home to max as recommended by others....all I need to do now is to set the end stops and level the bed...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 03:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 03:44PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 06:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 06:50PM |
RedneckGeek
[email protected]
I put a little dab of epoxy on each end of the openings for mine. Works fine as a little stop. Hot glue might be ok but the higher heat rising up off the head bed when printing ABS or whatever might remelt it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 09:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 09:46PM |
therippa
Chiming in - if anyone hasn't tried the glue stick method with ABS, it works really well. The pieces literally pop off as it cools (and it's loud enough that it startled me). Give it a try!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 09:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 09:58PM |
zarnold16
Okay im confused, is there a certain distance for the sk8's? And is there an exact distance for the belt for the heated bed/y carriage?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 10:06PM |
I zipped tied the plate already and the plate when moved sounds like the bearing are grinding.Quote
animoose
zarnold16
The relative position of these is set by the position where the bearing mounts and the belt mount attach to the aluminium bed. My suggestion is get them in roughly the right place until you attach the bed, and then fine tune them so that they are the right distance apart and the belt is parallel to the chrome rods. My SK8s ended up 140mm apart (measured center to center of the chrome rods), and the center of the belt is 60mm from the center of the left chrome rod.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 10:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 25, 2015 10:31PM |
RedneckGeek
therippa
I haven't been so lucky. The first time I did it I printed a 10mm test cube and it stuck perfect and popped off. A few minutes later I tried to print a part and it wouldn't stick the first layer at all. Just dragged the filament around and made a spaghetti mess until I killed the print.
Whats the secret to repeatable success with the glue?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 26, 2015 12:37AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 26, 2015 02:53AM |
RedneckGeek
therippa
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 26, 2015 08:00AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 26, 2015 10:34AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 26, 2015 10:44AM |
