Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 09:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 09:19PM |
wderoxas
mike3
mike3
therippa
mike3
Well after several days of great printing.. my extruder stopped heating up... has anyone else had this problem.. I can still home and move x,y,z manually.. when I check the contacts on the ramps board there is no voltage... Can anyone help,, can I hook up the Extruder heater wires directly to 12v to see if it is working ..and how can you check the thermistor.. and if these both check working .. what could be the problem? thanks mike
Have you recently started using your heatbed as well? I was printing PLA fine without the bed turned on, and decided try with it on. Repetier would report "Extruder Heating", but the temp wasn't rising on the hotend. Turns out your heatbed needs to come to temperature before the hotend starts heating up, and I wasn't being patient enough to realize this.
no i have been using the bed all along... it didn't matter if the bed was up to temp... as soon as the extruder was ... it would start printing now the bed temp will go past its set value but the extruder never heats at all.. and printing never starts
I reflashed the Arduino Board .. but it still dosn't heat up
Did you physically check if the hot end is heating? If it does, yet its reporting it doesn't then likely your thermistor is the problem.
If it doesnt heat up, and there's a voltage on the hotend terminal at ramps, then your cartridge have a problem.
If it doesnt heat up, and there's no voltage on terminal at ramps yet repetier reports its heating up extruder, then its somewhere on the extruder fet or even at its gate pin that arduino is supposed to drive.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 09:45PM |
[email protected]
So I have yet to figure out my X-home issue but decided to try some prints anyways. I printed out a 20x20x20 cube and ended up with 20.5x20.5x18.5 was not alarmed since I suspected my bed leveling sucked looks like my first layer is just getting smeared and not extruded plus I would get clicks from my extruder as it tried to pull more filament in while unable to push any out against the glass.
I had to keep pulling filament from the roll since it is not well routed yet. I went to print some guides I could bolt on to help guide it better thinking the 1.5 mm error on the Z would not matter for them. It was a 90 minute print (4 pieces off thingiverse) well 45 minutes into the print my print just stopped responding. Had to kill Repetier with task manager and cut power to the printer to get it to restart. In the error log I had an error for command block reset. I checked the Temps of my steppers while it was running and found my X stepper to be running at over 105 F (41 C). Could this explain my lock up?
Though they only hit %50 print completion they are thick enough to help guide the filament until I print better ones.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 09:48PM |
Where can I find information on how to attatch the LCD?|
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 09:53PM |
cvanclev
Hey all, really need some advice here. Pretty discouraged.
I shorted my stepper driver in the initial build out and severely damaged the Arduino Mega. I ordered a new Mega, which I then installed and instantly smoked as well. Two Megas down. I then ordered an all new RAMPS/Mega combo, went to install today, checked EVERYTHING with a multimeter before powering on, even assembled with an ESD bracelet. Loaded Marlin, everything worked great. Then I powered down and installed my 4 "good" drivers. Blew the Mega on powerup. F*CK. Three Megas down. Looks like my drivers were actually the problem. I got rid of the driver I blew initially as soon as it happened, and used the spare in my kit. So, what do I do now? 4 new drivers, a second new RAMPS, and a fourth new Mega? Or four new drivers, and a FOURTH new Mega? Hard to tell if my new Ramps is damaged. animoose.. bought the same RAMPS you did on Amazon. Much cleaner and color coded. Do I get Folgertech on the line and have them send me 4 new drivers and a new Mega? I'm in the hole here pretty deep. As an electrical/robotics engineer, I understand the problem with the initial short, but am very upset that this last round occurred, I took all the preventative steps and the drivers damaged my equipment.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 09:55PM |
mike3
wderoxas
mike3
mike3
therippa
mike3
No the hot end is not heating and it dosn't report its is heating.. no voltage at the hotend terminals .. also the heat bed goes past its set value..
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 09:56PM |
brian0
I'm having one helluva time getting my new machine to work properly, specifically getting everything set to home. Everything assembled relatively well. Where exactly is home on this machine? I would imagine the far back right corner, but I'm not sure. I've followed some of the steps previous in this thread, but I still can't figure out what's going on.
My setup:
-Standard build according to the FT-provided instructions
-X endstop at the far right (when looking at the printer)
-Y endstop at the far back (triggered by one of the bed bearing mounts)
-Z endstop under the 3d printed mount on the right
My Repetier-Host is setup with:
Printer shape tab
Home X: Min
Home Y: Min
Home Z: Min
X min: 0
X max: 200
Y min: 0
Y Max: 200
Bed Left: 0
Bed Front: 0
Print area width: 200
Print area depth: 200
Print area height: 185
Basically, everything is configured as in the config guide.
I've trimmed my X/Y/E stepper pots to 0.35, and Z to 0.55
All that to say, I'm /not/ running the FT-provided firmware, but rather the Marlin firmware linked previously in this thread.
When a print job is started (I'm trying to do little 10mm cubes at first), everything looks good until the point where it draws the loop around the base of the object. Then it runs off far to the X left and pretends it's printing in empty space, with no bed underneath. Fortunately (?) the extruder doesn't pull any filament when it is in fact doing what would be printing.
I'd like to get this thing working today. What do?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 10:13PM |
[email protected]
I have the LCD and card reader had not installed them yet. And uhm ye about the lock up on the lap top "MAYBE" I was also watching archer during this lock up event. So yea what'd we learn?Where can I find information on how to attatch the LCD?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 10:56PM |
animoose
Try changing the Repetier home to X max. That will set home to the position with the print head over the front right hand corner of the bed and all three limit switches activated. I have mine set up the same way. You might also need #define INVERT_X_DIR false, and #define X_HOME_DIR 1. That's "1" not "-1".
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 10:58PM |
animoose
brian0
My setup:
Printer shape tab
Home X: Min
Home Y: Min
Home Z: Min
X min: 0
X max: 200
Y min: 0
Y Max: 200
Bed Left: 0
Bed Front: 0
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 11:21PM |
wderoxas
animoose
brian0
My setup:
Printer shape tab
Home X: Min
Home Y: Min
Home Z: Min
X min: 0
X max: 200
Y min: 0
Y Max: 200
Bed Left: 0
Bed Front: 0
In addition, setting your x to home at x max ( endstop location to the right as in your setup), requires that
1) your x endstop connector is plugged in at xmax on ramps board
2) //#define DISABLE_MAX_ENDSTOPS and //#define DISABLE _MIN_ENDSTOPS. This ought to be commented.
3) #define X_HOME_DIR 1. This sets firmware home at x max as what animoose mentioned.
#define INVERT_(insert axis here)_DIR affects the rotation direction of your motor. Without changing this setting, you can get the same effect if you flip the motor connector on the ramps board.
FT's instruction were okay except for setting the x axis. If your going to place the endstop at the right, you ought to configure to the firmware to home at x max. While you can accomplish homing to the x right, while firmwares home is at x min, x endstop connected at x min also, and motor rotation dir set appropriately, this will result in mirrored prints.
The default mins on the cartesian plane as shown by the arrows at repetiers or slic3rs platter, falls at the lower left corner of the bed. So if you want your print head to fall in the same location when homing, then,
1) all firmwares home must be set to min
2) all repetiers home must be set to min3.
3) //#define DISABLE _MIN_ENDSTOPS should be commented
4) x endstop at the left, y endstop at the back, z endstop at the bottom of the z rod.
5) endstop connectors at ramps should connect to xmin, ymin, zmin
6) motors rotation set appropriately. You can either change the #define INVERT_(insert axis here)_DIR or flip the connectors at ramps if its not moving on the correct direction. Also keep in mind that the arrows on repetier, represents how the head will move with reference to the bed. Its easy to figure out with x axis but for y axis, if you press the arrow up, your bed will move towards you, placing the head at the back edge of the bed.
If you want to retain the x endstop at the right, then,
1) firmware must home at xmax, ymin, zmin
2) repetier must home at xmax, ymin, zmin
3) //#define DISABLE _MIN_ENDSTOPS and //#define DISABLE _MAX_ENDSTOPS must be commented
4) x endstop at the right, y endstop at the back, z endstop at bottom of the z rod.
5) endstop connectors for x,y,z must connect to ramps xmax, ymin and zmin respectively.
6) motor roation set appropriately.
Its lenghty, but hope it helps the rest of the guys.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 11:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 27, 2015 11:55PM |
samaral
wderoxas
animoose
brian0
My setup:
Printer shape tab
Home X: Min
Home Y: Min
Home Z: Min
X min: 0
X max: 200
Y min: 0
Y Max: 200
Bed Left: 0
Bed Front: 0
So your x-endstop connector is in the second to last slot instead of the very last (7th) slot as presented in the instructions? I have been having this problem with my x-carriage not homing and after I switched the endstop to the 6th slot it works! Can you guys confirm that?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 06:37AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 07:45AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 09:19AM |
dbrewski
mel0n
Lagomorph
I'll look into that. How did you attach yours? Do you leave off the heatsink and attach it like the stock hot end or do you need something else to hold it?
I made one of these : [www.thingiverse.com]
It has a couple issues, and I am working on improvements, though for now, it seems to be working pretty good.
read earlier in the thread for more information. I posted a bunch in this thread about my clogging issues.
If you don't mind me asking, what issues are you having with the current design?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 11:54AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 01:14PM |
dbrewski
I never tested it with the smaller stepper motor. I designed it using a stepper motor with a lot more torque, but I know of others that have used the smaller stepper motor that came with the kit and had no problems. This might sound crazy, but try using a prefilter on the filament with a little bit of canola or olive oil to lubricate the filament.Filter I don't know if dust was getting into my hotend or if the PLA I was using needed a little lubrication to flow smoothly. I was having all kinds of jams and extruder clicking and was about to go crazy trying to figure it out. I was originally using a wade's big gear set up that had so much bite and torque that it would twist the filament in the extruder trying to push the filament through. After installing the pre filter and lubrication, I was able to drastically reduce my voltage to my stepper motor and its been running great ever since. I just finished a 13 hour print and I was astonished such a simple fix made such a huge difference.
A few other things you might want to check is if the grooved bearing is allowed to rotate freely, the idler is allowed to move freely, and if the spring is actually forcing the idler into the toothed gear. I had to clean up my print a little to get everything to move like it should. I had to go through a couple of iterations to get make sure there was enough clearance when installed and since no two printers are the same there could still be some interference.\
Let me know if that helps. I was also working on a geared design using some of the FolgerTech original equipment. I wanted something that would give me more torque because of the jams I was experiencing. Now that I have my extruder running well I put the design on the back burner.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 05:12PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 05:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 06:19PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 07:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 08:40PM |
ejnelson
Anyone tried printing any exotic filaments or know what the hot end can handle? It is the Mk7 right? I'm thinking about buying some taulman bridge, any experiences anybody?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 09:15PM |
animoose
ejnelson
No experiences yet. I bought small samples of PETG and a PLA/PHA blend (supposed to be a bit less brittle than plain PLA), and I'm going to try them out next time I change filament.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 09:20PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 10:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 10:04PM |
ejnelson
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 28, 2015 11:25PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 12:51AM |
Mach
What has to be changed to the up-to-date marlin version in order to make it work with this printer. when I transfer the config.h setting and the pins.h settings from the version that FT provided to a newer version, the printer does not function properly. Could someone post a link to a newer version that works with the printer, or maybe attach a newer version that is known to work. Thanks.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 08:35AM |
zarnold16
This Kit is starting to make me regret buying it. I have a new 5mm threaded rod on the way because it wouldn't allow a nut to pass over in a certain spot and oiling it didn't help. The extruder won't work. Then lastly I just fried my Arduino and Ramps board.
