Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 11:53AM |
therippa
Mach
What has to be changed to the up-to-date marlin version in order to make it work with this printer. when I transfer the config.h setting and the pins.h settings from the version that FT provided to a newer version, the printer does not function properly. Could someone post a link to a newer version that works with the printer, or maybe attach a newer version that is known to work. Thanks.
Latest Marlin with Folgertech settings merged in: [www.github.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 01:51PM |
zarnold16
This Kit is starting to make me regret buying it. I have a new 5mm threaded rod on the way because it wouldn't allow a nut to pass over in a certain spot and oiling it didn't help. The extruder won't work. Then lastly I just fried my Arduino and Ramps board.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 01:56PM |
I could hear the extruder rotate just filament wouldn't come out.Quote
mel0n
zarnold16
Other than the rod, these seem like user error...... nobody said building a 3d printer was the easiest thing in the world....
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 02:30PM |
zarnold16
mel0n
zarnold16
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 02:36PM |
mel0n
zarnold16
mel0n
zarnold16
So take it apart, and figure out whats going on! Is the hot end hot? If I try to push filament through the hotend while its heated, does it come out like its supposed to? Is the filament stripped out by the extruder?
I am not trying to be negative here, but 3D printing isn't a "set it and forget it" kind of process still. Especially not in one of the cheapest DIY kits on the market. The high end printers have their fair share of issues as well. To be honest, it seems like you have built up frustrations at this point, and you have let them get to you. I know you are probably excited about 3d printing, but my advice would be to take a break for a couple of days and do something completely different to clear your mind and let your frustrations die down. Then come back, and before touching anything, list the problems are that your having, research them thoroughly (most issues have been resolved in the past, and we have sorted most of the design specific issues of this printer by now), and try to take a new optimistic approach to fixing them. I found pretty early on that a little patience goes a long way with 3d printing.
Best of luck with your troubles and happy printing!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 02:47PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 02:51PM |
signalcruncher
I had the same problem when I first tested my extruder - it just clicked and clicked and wouldn't pull the filament through. I found a coupld posts about the build manual being wrong for plugging in the wires for the extruder - so I tried the solution and it worked for me. I simply turned the plug around where it plugs into the Ramps board and the motor reversed its direction and the extruder works fine now. It is worth a try. Also, when you put the filament in, there is the spring-loaded 'grabber' on the extruder - push it down, insert filament so it grabs.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 03:04PM |
Okay ill try that when I get my new ramps and arduino tonight.Quote
mike3
signalcruncher
Same here plugged the wrong way..it can get frustrating when the manuals are wrong..
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 03:12PM |
brian0
animoose
Try changing the Repetier home to X max. That will set home to the position with the print head over the front right hand corner of the bed and all three limit switches activated. I have mine set up the same way. You might also need #define INVERT_X_DIR false, and #define X_HOME_DIR 1. That's "1" not "-1".
Unfortunately, that's how everything's already configured.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 06:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 08:33PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 08:44PM |
[email protected]
So the things I learned tonight:
That odd problem with my x-carriage was due to the fact when I was looking for the firmware I ASSUMED the copy on the google drive link was the current tuned one WRONG I grabbed the copy that therippa linked on the github moved my end stop back to the right flipped my extruder back and tried the "tuned" version. Well first thing is my X would not move again then I remembered I did not flip the wires back around so for some insane reason I went into the firmware and changed the X direction instead of moving the wires. And now my X-home works!!!!!! Maybe it's a good thing though I'm learning my way around the firmware instead of flipping wires it's safer!!!
My bed takes FOREVER to heat I thought I saw a suggestion to slide cardboard between the aluminum plate and the heater. Is that safe? By the way my bed keeps climbing and stops at 130 I have it set for 100 in repetier maybe another dive into the firmware is in order.
Also I have some strings when printing most noticeable when it it printing open holes. Maybe 220 is to hot for ABS?
I turned my stepper drivers down even lower tonight cooler and still no skipping. Also notice my lower X-carriage rod slides a little side to side since my endstop is on this rod I can not see this being a good thing though I have not seen X-home change..
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 08:49PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 08:54PM |
[email protected]
Will make the X-carriage changes in next day or two. Printing some better filament guides right now. I have a 1/4 inch piece of 8x8 glass on my bed. I have been using hairspray. So far love it. My bed takes 10-15 minutes so not to bad then? and should the bed stay around 130 or lower it in the firmware?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 09:04PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 09:05PM |
[email protected]
I have not been changing my layer temps so will learn that. Do you think the string is from my extruder being to cold? I have 2 rolls of ABS I am learning with I also have a few rolls of PAL but do not want to try switching back and forth I have heard some horror stories. Would a picture of my prints help or do you know what I mean by stringy?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 09:29PM |
therippa
Mach
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 09:32PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 09:48PM |
RedneckGeek
therippa
Mach
I downloaded this version and loaded it on my printer and the bed won't heat beyond 87C. Weird. I put the old one back on and I can get to 101 again no problem.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 10:00PM |
[email protected]
[jasonsaffle13.imgur.com]
Collections of pictures of build and my recent prints.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 10:03PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 29, 2015 10:40PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 30, 2015 01:52AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 30, 2015 06:39AM |
therippa
Well, I got my new E3D V6 Bowden setup up and running today, and just printed a test cube. I can't believe how much better the print quality is compared to the stock hotend. The difference is like using sidewalk chalk vs a fine tip mechanical pencil.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 30, 2015 08:45AM |
[email protected]
therippa
Pictures (and if you would STL files for the mount, bowden setup etc.). Would like to replace my hotend with a better one. Have heard of short life and other issues with the stock one. wish to as someone put it "walk away" from those problems.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 30, 2015 11:42AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 30, 2015 01:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 30, 2015 01:28PM |
therippa
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 30, 2015 01:46PM |
markts
therippa
I'm going to ask a dumb question here. What did you buy for this, vs what did you print? How much work was it to convert?
