Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 17, 2015 08:13PM |
[email protected]
kn4ud
ejnelson
while we're asking questions for the lead screw upgraders... anyone have a good US source? I feel like the folgertech ones are overpriced. Looks like openbuilds has them for 10$ but with no nut.
I ordered 2 last night from banggood USA warehouse (so it said) with nuts and 400mm long for a little over $26 with shipping.
I also got the 400mm ones. So now going to try to cut them down to 300-ish to even fit in the printer!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 17, 2015 08:41PM |
awmyhr
[email protected]
kn4ud
ejnelson
Is there a reason to buy the 400mm ones rather then the ones which are already 300mm?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 17, 2015 08:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 03:44AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 12:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 01:28PM |
[email protected]
awmyhr
[email protected]
kn4ud
ejnelson
Not that I know of. I have the lame excuse that I guessed while sitting on the beach 4 states away from my printer!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 02:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 06:34PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 07:12PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 07:43PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 08:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 09:02PM |
meeuuch
I'm new to all of this. I'm trying to tune my stepper motor. Does anyone know what they should be reading on the multimeter?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2015 09:27PM |
Mach
So, I am in the process of upgrading my printer to a bowden setup, and was going to turn my X axis horizontal in the process. But recently, I have wondered whether or not there is any benefit of doing that, since the weight of the extruder is no longer going to be a problem with the bowden setup. So is there really any benefits to having a horizontal X axis instead of a vertical one when using a bowden configuration?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2015 10:45AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2015 12:14PM |
Danmst3k
Thanks widespread. My X and extruder motors seem to be slightly hot. The X did get cooler when I tweaked the pot to make it quieter. I'm thinking maybe the extruder stepper is also vibrating, could explain the why I'm still getting ripples. I really need to throw a meter on these to check whats up.
I haven't tried any large prints yet. Don't know if I can handel a mistake halfway through lol.
Fans always seem like a good idea. I haven't checked my Ramps board to see how hot it gets. Another thing to check on the list. I'm thinking of getting a fan to blow on the print to cool it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 10:52AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 11:09AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 11:35AM |
Bert3D
Ok, my printer has been working fine for over a week, and now suddenly the Z axis will only go up. It is not inverted. When you send a command to go down, it goes up. When you send the command to go up, it goes up.
I rebooted everything, multiple times, reflashed the arduino, checked connections. Tried it from the LCD and from manual control inside Repetier. What can cause this? Bad RAMPS board, bad driver?
The only thing I fiddled with before this happened was to relocate the LCD. This involved unplugging the cables from the LCD end, and plugging them back in after I moved it. It was done with the power off. Don't really see how that could have caused it.
Anyone have any seen this before, or have any ideas or suggestions?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 03:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 03:37PM |
I run OctoPi and I love it. I sounds to me like the printer settings might be off, I'd check those first on OctoPrint and make sure they all look correct.Quote
RedneckGeek
Anyone use OctoPrint on a Raspberry Pi? I hooked mine up and it seemed to work ok for a few days then went nuts. I use it basically as a web interface to drop my gcode files into that are exported from Repetier/Cura. Same files work fine I drop on the SD card and print from the panel. When I drop them into Octoprint its like it prints too high off the bed and just sprays a big glob of plastic all over. Same file from SD prints fine. Weird eh?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 04:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 05:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 06:12PM |
kn4ud
Very nice print therippa, what filament did you use?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 07:44PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2015 08:04PM |
kn4ud
You certainly do have your unit dialed in, great job. For the past 4 days I have been playing with some esun PETG and I think I have about got it dialed in, still have some cat hair strings but it is getting better. I got my 8mm threaded rods today but my bearings have not got here yet.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2015 02:40AM |
therippa
kn4ud
Hatchbox ABS.
Here is another one, I really feel like I have this thing damn near perfectly calibrated...
Now I need to figure out what left the "scar" on his face and forehead
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2015 07:41AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2015 08:57AM |
therippa
kn4ud
Hatchbox ABS.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2015 12:00PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2015 04:43PM |
