Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 01:16PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 01:47PM |
platinum16
Ya I got tools and licenced auto machanic I just don't know if I should be drilling recesses n wat not but all good I grabbed some m5x10mm from my works supplier and it was perfect
I guess I'm just not as confident with this printer as I am with other people's cars lmao
Jk
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 02:03PM |
TimJC
Mach
So, I am trying to setup a full graphic lcd controller, but I cannot get the screen to show anything other than the blue backlight. I have downloaded and included the u8glib library in config.h, uncommented
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER, #define ULTRA_LCD, #define DOGLCD, and #define SDSUPPORT. The contrast pot is set to a proper amount and I am using the latest version of marlin. The selector knob does beep when I press it, but nothing else seem to work. I know a few people on this thread have hooked up this controller, so I was wondering what you had to do to get it to work? Thanks
Are you using TheRippa's configured version of the firmware? If so, check out my post on page 45. Also take a look at Tom's LCD episode on Youtube.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 02:29PM |
Bert3D
Mach
Comment out ULTRA_LCD and DOGLCD and SDSUPPORT around lines 535 to 537. These will get defined automatically later in the config, if appropriate, just from setting REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER.
Make sure none of the other LCD options are set that might conflict, like G3D_PANEL, or MAKRPANEL.
This may not fix your issue. I don't think the ones you selected would conflict, but it is worth a try.
The only thing you should have to do is uncomment REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER, and comment out whatever display was selected previously. That and include the u8glib library.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 02:48PM |
Mach
Bert3D
Mach
I tried uncommenting these, but the screen is still blank Is there a certain way that the u8glib library is supposes to be included. Do you have to drag and drop the extracted zip file into the marlin file with the other libraries? After I downloaded it, it came up under "contributed libraries". Does that mean that the library has been included?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 03:43PM |
TimJC
Mach
Bert3D
Mach
Try commenting out //#define REPRAP_DISCOUNT_SMART_CONTROLLER. It may not be necessary, but I did this on mine and the full graphic LCD is working. Also, uncomment #define EEPROM_SETTINGS from configuration.h so that you can save settings to EEPROM from the LCD. Otherwise, Marlin will revert back to the configuration.h defined settings after the printer is power cycled.
The include flag for u8glib.h is located in Marlin.ino, so action should be needed after adding the library via sketch>include library>add .zip library.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 04:19PM |
Mach
TimJC
Mach
Bert3D
Mach
I commented out #define REPRAP_DISCOUNT_SMART_CONTROLLER, but the screen is still blank. Do you think that maybe I have a bad lcd controller, and do you know of a way to test it?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 04:52PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 05:06PM |
woodknack
I'm having the x axis issue to and have read the other pages but I'm still confused. I have downloaded therippa latest marlin and installed that. Should I move my x end stop over one set of pins and go back into marlin and change the pin #?
Or is it already changed in therippa firmware update? I'm confused?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 05:08PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 05:14PM |
zarnold16
Mach
TimJC
Mach
Bert3D
Mach
I had that problem with my LCD. To fix it unplug the printer and switch the 2 lcd ribbon cables on the ramps board and it should work.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 05:16PM |
woodknack
Hmmm I'm at work now. But I'm pretty sure I tried that and got the same results. Just a small move to the left when trying to home.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 05:20PM |
Yes, My red lines are on the side near the power connector. What brand and where did you get your LCD Controller? Also does yours have a jumper on the back?Quote
Mach
zarnold16
Mach
TimJC
Mach
Bert3D
Mach
I tried, but nothing shows I do wonder though, do you have a red line going down one side of both cables? If you do, on what side of the cable is the line on when you are facing the screen?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 05:29PM |
therippa
woodknack
I just double-checked the firmware I merged vs the original folgertech, pins and axis settings are the same, so it should just be moving that x endstop to the min pins (last set of pins). You might also have to flip the wire plugged into the x-axis motor to invert it (be ready to hit emergency stop if it goes in the wrong direction). To be honest, my printer is so far modified from the stock version I can't really test it and let you know (for instance, my x-axis homes to 0 on the left now, as it was originally intended). Also, in your host, make sure the x endstop is set to MAX.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 05:37PM |
zarnold16
Mach
zarnold16
Mach
TimJC
Mach
Bert3D
Mach
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 06:44PM |
Can you send a picture of your blank screen?Quote
Mach
zarnold16
Mach
zarnold16
Mach
TimJC
Mach
Bert3D
Mach
It does not have a jumper on the back. Not quite sure if it has a particular brand, but I think it is made by a company called Bigtree-tech, as it has the name printed on the front. I got my controller on ebay from here Full Graphics LCD Display
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 03, 2015 10:06PM |
zarnold16
Mach
zarnold16
Mach
zarnold16
Mach
TimJC
Mach
Bert3D
Mach
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 04, 2015 01:37AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 04, 2015 09:12AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 12:09AM |
therippa
I finished the induction autolevel sensor this weekend. The hardest part was getting it dialed in initially, and then having to do some serious changes in the configuration since Folgertech makes the X endstop max, which doesn't work with autolevel. Also, animoose and others using E3D's, I would HIGHLY recommend getting this thermistor...
[www.amazon.com]
I learned this weekend taking apart the head to fix a clog that the thermistor/insulation is only good for one screw tightening, after that the insulation falls apart and the thermistor shorts, showing a temp of 999F.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 03:48AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 07:20AM |
therippa
[www.amazon.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 12:03PM |
woodknack
therippa
[www.amazon.com]
Will this work with the extruder that came with the folger kit?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 12:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 01:06PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 06:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 06:33PM |
tjnamtiw
I'm moving right along on my assembly of my 2020. I'm up to mounting the X carriage onto the vertical frame. I just don't like the feel and sound of these bearings on the chrome rods! Herky Jerky best describes it.. The Y carriage moves easily now that I have the one bearing side 'semi-floating' but still very noisy, probably because of the metal plate vibrating and nothing to dampen it. The X carriage moves more quietly but if you try to push it lightly, it resists a little and then jerks one ball over (thinking of the bearings). I'm seriously considering taking the bearings back off and enlarging the semi-circles that the bearing fit into to allow them to float slightly also. I was disappointed that the width of the openings for the bearings were no where near the length of the bearings. Some time with my Dremel provided relief for them. Using printed parts for such precision alignment is questionable but then again, if they were injection molded parts, we wouldn't be getting a $269 kit!
Is what I'm describing the same thing others have seen?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2015 06:45PM |
animoose
tjnamtiw
Yep, all this sounds familiar In spite of this, many of us have found that the printer works remarkably well.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 06, 2015 02:36PM |
tjnamtiw
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 06, 2015 05:38PM |
therippa
The bearings that Folgertech provides are crap, my x carriage made so much noise the neighbor below me complained about it. I bought some new bearings here - [www.ebay.com] . Conveniently they come with some other bearings I've used for upgrades (like my bowden extruder), and are quieter. I also printed a new x carriage that uses 4 bearings - [www.thingiverse.com] . The company I bought the bearings from, Leap 3d, sells good stuff (I've purchased a bunch of other things from them). Another good company to buy from is Matter Hackers.
Another tip to get your x carriage moving more smoothly is to clip one of the zip ties on each of the bearing holders, that will let it have a little more play when moving back and forth (but remember, you don't want too much play or the prints won't come out well).
