Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 11, 2015 11:10PM |
therippa
...To deal with ooze during hotend heatup, use this gcode:
G1 X0 Y0 Z.35 F900;
G1 X25 Y0 Z.15 E5 F225;
G1 X25 Y25 Z5 F3600;
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 02:31AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 02:47AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 06:04AM |
woodknack
I don't know how they package there stuff!? seems like someones is always missing something. They must hire school kids to package the stuff up for kitting.
If it were me id stock all the stuff in separate bins from start to finish. each bin would tell you how many of that item is needed. start at the first bin and go to the last loading in a cart or another bin. Bring that over to a table where they take that bin and box it as a complete set. How hard is that really? I don't mind a few extra screws, but i got a handful of screws I think were never even called for in the instructions.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 06:07AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:29AM |
Neverdone
I did get my first print done last night! I printed a 20x20 block and was drooling on myself the whole time! Simply fascinating! I do need to make some adjustments though, it appears that my belts need to be a little tighter there is some waviness on the sides of the print, also when it printed the top there is some gap between the lines. Otherwise I am ecstatic! Can't wait to print some more stuff! I think the next thing is going to be the LCD mount then on to fun stuff!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:48AM |
woodknack
Neverdone
are you using the little spring tensioner they give you in the kit for the belt?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:33AM |
woodknack
im in the same boat. Thats why I decided to take the leap and buy s3d. I didnt want to learn 3 different types of software to print when I know nothing about printing at all! I just took the plunge and I am not regretting it at all. Im having a ball printing and my machine still needs to be better calibrated.
upload pic
img host[/url
screenshot windows 7
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 04:32PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 05:55PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 06:28PM |
Neverdone
Has anyone tried anything besides ABS or PLA in their printer? I was looking at TPE..... Would I need a different extruder or anything for that?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:29PM |
if you home your y axis does the bed go to the rear until it hits the limit switch?Quote
canny
Hi i am having trouble calibrating my 2020 does anyone know where i can learn how to calibrate or maybe even tell me on here? Im having an issue where i sent it to print and it send the printer bed all the way to the front away from the extruder, im guess thats due to calibration correct?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:35PM |
woodknack
canny
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:40PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:41PM |
What is the source of the firmware you flashed to RAMPs? If it was FT or therippa, then the end stops and motor directions (with the exception of X and maybe E) should be configured correctly. Try flipping the plug for the Y motor, which will receive it's direction. I didn't need to do this for Y but did for X and E.Quote
canny
woodknack
canny
No it goes all the way to the front and the belt jumps ...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:47PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:52PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 09:57PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:00PM |
woodknack
check your belt and connections where you ran it into the front of the machine? if everything is unplugged main power and usb power your should be able to manually move your bed . if not check the belt , tentioners , anything mechanical.Quote
canny
still jammed
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:03PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:07PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:18PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2015 10:22PM |
