Folger Tech 2020 i3 Printer Kit (Official Thread)
Posted by Dan_FolgerTech
Re: Folger Tech 2020 i3 Printer Kit (Official Thread)
December 12, 2015 02:20AM
After some trouble shooting I confirmed that theres something wrong with my z motors. Ill just repost what I wrote before:
My two z motors vibrate but don't turn. I'm guessing this is because the stepper motor coils are wired to the wrong pair of wires?
(Newbie to electronics here) So after determining which coil goes to which pair, do I just cut off the connector, re-arrange the pair, and attach crimps, and then the connector? Or would there be another way to re-arrange the pair of wires. How do I get the previous wires out of the connector? (Silly question I know)
How would I physically re-arrange the pairs? Any tutorials on this?
December 12, 2015 03:48AM
watlooazn
Going with Occam's Razor here - it seems unlikely that the two motors you used for the Z-axis have the coils wired to the wrong pair of wires, and your problem lies elsewhere.
Need help? Visit the Folgertech Wikia Page
The latest Marlin firmware with Folgertech Prusa i3 settings merged in, get it here
And check out my designs on Thingiverse, and follow me if you like what you see!
December 12, 2015 09:24AM
Having fun printer Christmas Gifts smiling smiley
December 12, 2015 11:35AM
therippa
watlooazn
What did you find during troubleshooting?
Edited 1 time(s). Last edit at 12/12/2015 04:17PM by Mach.
December 12, 2015 06:20PM
Alright guys my bad, I didn't read the previous posts, thanks for your help. Now regarding my Z motors Issues:
I found out that the Z motors work perfectly fine after connecting them to the x and y ports. Also, the reason they were vibrating and not moving before was because my threaded rods weren't installed properly.
But now I have a new issue:
It takes my z axis approx 30 seconds to move approx 1.5 inches. It is noticeably slower than the y and x axises. Im guessing that maybe there is not enough current supplied to them? Voltage? Regardless, I think I have to change some setting in the arduino code. How would I do this? How would I access the code from the IDE? (silly questions, but noob here who wants to learn smiling smiley )
December 12, 2015 06:55PM
watlooazn
Open the arduino ide, go file > open, find the folder where you are keeping marlin on your computer, keep double click on you marlin folders until you get to the folder that shows all of the various files that belong to to marlin, double click anyone of them and it will open up all of them up, find the config.h tab in the ide.
Things I would suggest checking are:
1. Does you Z axis move the amount you tell it to
2. Is you Z axis steps per MM at 4000
3. Is your Z axis feedrate in repetier at around 100mm/min
Your Z axis is going to move way slower than your X and Y axis because it is using threaded rods. This is fine. As long as the three things I outlined above checks out, you should be good smiling smiley
December 13, 2015 07:12PM
awesome I will try this, thanks!
Another question is shouldn't the Y endstop be placed near the front of the printer? The manual says to place it at the rear. But from my understanding, if we want the home position of the extruder to be at the back right of the bed, then the y endstop should be at the front so the heatbed can move foward and for the extruder to be at it's back right.
How can I change the direction of my y motor? When I press home, it moves back, I want it to move to the front.
December 13, 2015 07:14PM
Anyone order from Folger Tech recently? I placed my order about a week and a half ago and they printed the label the next day but nothing has shipped?
December 13, 2015 07:35PM
(Deleted, double post)
Edited 1 time(s). Last edit at 12/13/2015 07:36PM by animoose.
See my blog at [moosteria.blogspot.com].
marc2912
Don't worry, I think they always do that. My order showed as two shipping labels (one for the printer and one for the filament), and it arrived on two different labels.
December 13, 2015 07:58PM
animoose
marc2912
Yeah mine is like that too. The filament tracked right away and already delivered. The printer label is printed but hasn't shipped and is been over a week. I'm trying to get an idea how long their turnaround is.
December 13, 2015 08:28PM
watlooazn
Correct, if you want the home position of the bed to be up front, the endstop goes up front. If it moves in the wrong direction only when you when you press the home button, you most likely just have to change your home direction in firmware (#define Y_HOME_DIR xx), otherwise, you can change the direction the motor turns by flipping the motor's connector on the ramps.
December 14, 2015 11:29AM
therippa,
What version of firmware do i need for the E3D-v6 HotEnd? I notices there is 3 different firmware for this on your github. I'm running a stock printer with E3D-v6 direct drive hotend upgrade only.
Anyone,
Whats a good way to edit an STL file. I have one that i want to make a small change to but haven't figure out how. I'm using 123d Design with Meshmixer.
thanks for any input.
December 14, 2015 11:46AM
Mopar99
Anyone,
TinkerCad is about as simple as you can get. Just go over to the right and 'import' it.
Edited 1 time(s). Last edit at 12/14/2015 11:48AM by tjnamtiw.
December 14, 2015 12:48PM
marc2912
animoose
marc2912
Me too - I got a tracking number for the printer (or at least I assume it's the printer) last Tuesday, with no updates yet. If I don't have an update soon, I'll ask what's going on, but I'm not worried yet.
December 14, 2015 12:55PM
Mopar99
therippa,
Anyone,
I use designspark mechanical as my go to cad program. It has lots of features including STL import and export.
December 14, 2015 01:06PM
bstern
marc2912
animoose
marc2912
They shipped the 2020s this morning. The Kesslers are this afternoon.
M.
December 14, 2015 04:23PM
Mopar99
therippa,
You should just use the Release branch. The other branches I have there are specific to my setup, and they are just changes to the configuration.h file, but all use the same version of Marlin (except for the E3D_V6-1.10 branch, which is using the latest release candidate of Marlin and has a lot of changes for my very customized printed, use at your own peril)
December 14, 2015 04:37PM
therippa
Mopar99
therippa,
ok, so basic i can swap the hot end and not have to change anything if i am already running the "release" branch. smiling smiley
Edited 1 time(s). Last edit at 12/14/2015 04:38PM by Mopar99.
December 14, 2015 05:43PM
looks like tinkercad will work, was kind hoping for something to install on my mac as i dont have internet at home. life in the stick smiling smiley
December 14, 2015 06:29PM
Mopar99
Ah, you needed something that would work with a mac os. Sketchup works pretty well and it has mac compatibility. Not as good as designspark, but still pretty decent. You will need to install the sketchup stl plugin though since it does not have built in stl import/export functions.
December 14, 2015 08:28PM
Mopar99
therippa,
Anyone,
I have been using sketchup.
Newbie with Folgertech 2020 i3.
December 15, 2015 12:18AM
marc2912
bstern
marc2912
animoose
marc2912
M.
Seems par for the course. For me, there was a fairly lengthy wait between creating the shipping label and actually shipping. I'm guessing Mr. Folger makes a trip to the post office once he has enough orders to ship.
December 15, 2015 12:38AM
Anyone have any ideas on what I can do to fix me computer getting Firmware unresponsive error messages? I have replaced the USB cable already. Made sure my computer isn't turning the USB off. Really sucks when it dies mid print. Sometimes it will recover but others it just sits there and melts a hole in the print.
December 15, 2015 01:13AM
built350camaro
That is the nature of printing via usb, lots of communication errors due to electrical interference. I would suggest getting a lcd controller/sd card reader for your printer asap. I used to print via usb, but was driven crazy by the amount of communication errors I got, so I installed a lcd controller. One of the best additions to my printer.
December 15, 2015 01:25AM
built350camaro
Mine worked better on some USB ports than on others. In particular, my monitor has a USB hub built into it, and it was less reliable with that than a USB port directly on the PC.
December 15, 2015 06:25AM
animoose
built350camaro
A good quality shielded usb cable might really help, I know you said you changed it but I doubt your cables are faulty, just probably cheap.
December 15, 2015 09:36AM
Updated my Marlin firmware to 1.1.0 RC2...everything seemed to be working fine. But while running a few calibration prints I got a "HEATER FAILED" fault. Is this a thermistor issue, or has something changed in that release that could be causing it (Thermal Runaway Protection)!?!?
I'm going to put a new thermistor in when I get home today, just wondering what else could cause the fault...
Thanks,
Sonny
December 15, 2015 10:22AM
sonnylowe
Thanks,
Sonny
I'm running the same firmware, 1.1.0 RC2. HEATER FAILED is not something I've seen. I did have some problems with thermal runaway protection on the heated bed though. It is enabled on default, and has a fairly narrow deadband that caused it to trip and spoil a few prints. I ended up disabling the heated bed thermal runaway protection. Even if the heaters stayed on 24/7, I doubt the MK2B heated bed would rise above 110. Hardly a dangerous situation, and not worth the ruined prints.
December 15, 2015 10:43AM
elkayem
sonnylowe
Thanks,
Sonny
Thanks for the info. With that said I'll assume it's a hardware issue for now...I'll change the thermistor and go from there...
