Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 07:39AM |
GrouchoDuke
sonnylowe
As soon as I have time (and they are finalized them) I'll be posting the X-Y upgrades on Thingi, along with a few other designs.
I think adding current mods-configurations to our signature is a great idea, and it would help people find there way much easier.
As far as S3D profiles, I change mine on the fly depending on what I'm printing...I don't save different profiles, I only have two...one for single extruder and one for duel extruders. I'd be happy to share those base profiles though.
Awesome, that sounds great. I'll watch for your stuff on Thingiverse.
Since I don't have a printer yet, I'm going to start with just getting the stock printer going. Hopefully mod-time will come quickly.
Thanks!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 08:40AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 09:28AM |
Boffster
Jim72
OK, I read the entire thread, for other noobs it starts getting more informative (ie. less complaining about quality and shipping) in the page 30's and beyond. However, there is good information in the first 30 pages as well. There is one thing I do not recall seeing mentioned. If one plans to use the LCD, is it better for any reason to consider power up and downloading the programs in the configuration section before attaching the LCD? As opposed to connecting the LCD and then doing the SD card to get started? I have the build completed and have x end stop on the left, so left front corner is home. The build was very fun. Still need to get glass plate and sd card then on to configuration and power up.
Thanks
Jim
Hi Jim, I have the LCD and connected it to the printer first, then I connected to the printer/Arduino via USB (with the printer powered off) and flashed the firmware. Then I powered up the printer after the firmware had finished uploading and connected with Repetier to test the axes. I haven't tried to print from the SD Card yet, but the menus work fine and the main LCD info screen is updating and displaying the same info as Repetier.
Hope this helps.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 10:17AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 10:44AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 11:44AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 12:55PM |
sonnylowe
With my printer down awaiting hardware to arrive (to complete yet another verison of my X Carriage upgrade) I've moved my thoughts elsewhere...wire management is one. I've relocated the Arduino/Ramps Board (enclosure is in mind) and started looming and rerouting all the wiring. I hope to have that done tonight. I have also moved to the hotter side of things, yup, the Hotend.
I am currently running the E3D Legends Pack. I like both the Chimera and Cyclops Heater Blocks for different reasons.
The Cyclops with it's one nozzle and heater block is really easy to setup, but limits you to using the same type filament while dual extruding. You could (in theory) run PLA and ABS at the same time, but they require different heat ranges to work properly and the current single heater block does not accommodate that. So you are stuck with ABS or PLA, or whatever.
The Chimera is quite a bit more difficult to setup as you have two independent heater blocks that both have the be set to the correct Z height. E3D did a great job providing a means to do this, but it's pretty time consuming and requires a lot of trial and error (and is quite unattractive in general). I can't ever seem to got it perfect!!! The great thing about the Chimera is you can run PLA and ABS at the same time with two different heat profiles, and extruder multipliers. You can even combined a flexible filament & Nylon for example, hell you can pretty much combined whatever you want.
With that said...I decided to take a shot at combining the one piece ease of the Cyclops with the independent flexibility of the Chimera. I came up with the Chimera 1 Piece Heater Block.
This will make setup as easy as the Cyclops, yet the undercut midsection should allow both sides of the heater block to reach independent temperatures (within reason). I know there will be heat soak between the two main sections, how much I don't know!?!? That will come to light as soon as testing starts. The main section should be out of the Wire EDM today (see sample cut below). If so I'll get the final machining done this week, and if my other parts come in Friday it will get installed this weekend
The heater block also takes advantage of the far less expensive V6 Nozzles (a third the cost of Cyclops Nozzles)...dirt cheap if you went with a Chinese knockoff (I wouldn't suggest it, I've gone that route, it's not worth it). The heat breaks are standard Chimera or Cyclops...either should work. I'll use the screw in Thermistors for ease of installation, and the fact I simply like them
I attached a 3D PDF of the assembly, you can zoom in, spin it around, and check it out...I love these 3D DPF's!!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 01:12PM |
sonnylowe
built350camaro
Ok I think I am ready to add auto bed leveling to my rig. I printed the new carriage with the servo at the bottom and have a servo to go there, where do I plug the servo on the Ramps board? I moved the endstop to the left side and got all the running the correct direction.
The servo plugs into the ramps board at the top (as installed-bottom in photo), just to the left of the reset button and power strips.
Make sure you add the jumper required to power the servo pins...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 01:18PM |
srcga
sonnylowe
built350camaro
What he said! Are you using the carriage that I put on thingiverse?
I had a 5v regulator around - I powered the '5V' pin pictured with its output, it's the 5v pin next to the PS_ON pin, that powers the servos. The 5v bus as-is won't be able to handle the Servo if you try to power it without help.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 01:47PM |
Boffster
Just checked out the chimera hotend, from the pics it looks like the nozzles are at the same height so why would you need different Z heights?
I really like the look of your design, can't wait to see how it performs! Hopefully there won't be too much heat seeping between the main blocks - if it does turn out to be a problem maybe a fin or two on the neck might help? I was going to suggest a heatsink between the two main blocks, but then you'd end up with 3 separate pieces and after I've looked at the chimera I'm sure you're trying to keep it as one piece.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 01:51PM |
built350camaro
sonnylowe
built350camaro
Where do I need to add this jumper? Any good write ups on how to do this?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 02:01PM |
Bert3D
sonnylowe
I'm curious, would you still be able to use different materials at different temperatures with this? Also both nozzles would have to be exactly identical.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 02:17PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 02:28PM |
For giggles, I guessed at a few dimensions on your part from the drawing you posted earlier, and for the solid portions of the finned area estimated it to be about 16mm wide and 3.6mm tall (1/3 overall height) and 9mm long. A quick back of the envelope calc of the heat conduction shows that with a 45 deg C difference (180 vs 225) you could move about 55-60 watts between the two sides, assuming no convective losses. You may have a hard time maintaining a large difference between the two sides. Of course, I hope I am wrong.Quote
sonnylowe
Okay, while I was waiting for our slow ass internet connection to catch up I whipped this out...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 03:14PM |
kebauc
sonnylowe
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 03:45PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 05:57PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 06, 2016 11:45PM |
peeejayz
got my bits for my Y axis upgrade.
Need to order some extra hardware before installation.
Sonny and theRipper. Can you show me how you spaced your wheels out from the plate? Currently I can't get the tensioner not a belt to fit as its a tight fit. I got the wheel kit. so bearings, spacers and nuts + bolts.
Pics of what I am upto currently are: [imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 03:24AM |
Mopar99
peeejayz
your screws should be inserted from the other side.
see drawing from open build
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 04:36AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 07:29AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 07:30AM |
peeejayz
Pics of what I am up to currently are: [imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 07:59AM |
sonnylowe
peeejayz
Other than the direction of the screws I'm pretty sure you got it right. I only ordered 6mm and 1mm spacers, so I know I used the 6mm, maybe I added one or two 1mm spacers as well, sorry I can't recall!?!? I'll check tonight when I get home, if there is extra hardware I'll let you know and I'll add it to the BOM. Either way everything is a pretty tight fit ;-)
BTW: Feel free to PM me anytime!!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 09:21AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 10:09AM |
peeejayz
Mopar99
peeejayz
I did see that, and have swapped mine over, but that still doesn't raise the platform any higher, so I'm wondering if they had to add extra spacers?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 10:21AM |
Mopar99
peeejayz
Mopar99
peeejayz
ok, after seeing there is more than one photo, one thing i see is the washer should be the wheel and spacer. if you made changes you might want to post new photos of your changes. i would make sure you assemble it as per the drawing posted above. i had problems with the wheels not spinning freely until i figure out the washer was needed between the wheel and spacer.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 10:48AM |
peeejayz
Mopar99
peeejayz
Mopar99
peeejayz
First of all I didn't put the one between the bearings but I'll put one between teh bearing and spacer too, shouldn't make much differance to how it spins but mihgt give me that extra 1mm gap.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 02:36PM |
sethmo
I am trying to improve my print quality and am not sure where to start. I have calibrated my e-steps for my filament(Inland White PETG). I have printed a .4mm single wall calibration print and it is close to .4mm. I have messed with my stepper driver pots and I think they are turned up high enough, I do not get missed steps and they do not overheat.
My setup is below:
-Stock M5 threaded rod with dual nut anti-backlash trap
-Extended Z motor mounts
-Genuine E3DV6 w/.4mm nozzle with TheRippas mount
-X-Axis tensioner
Slic3r
-.3mm layers
-1.72mm filament
-98% flow
-2 Perimeters
-25% Infill
-235C hot end / 100C bed
The print is pretty smooth to the touch, but has some visible "edges"
Any suggestions?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 04:06PM |
sonnylowe
sethmo
My setup is below:
-X-Axis tensioner
Slic3r
-.3mm layers
-1.72mm filament
-98% flow
-2 Perimeters
-25% Infill
Any suggestions?
That's not a bad looking print at all...but I understand, we all want perfection. Try this guide from our friends over at S3D...Print Quality Troubleshooting Guide
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 07, 2016 04:36PM |
sethmo
My setup is below:
-X-Axis tensioner
Slic3r
-.3mm layers
-1.72mm filament
-98% flow
-2 Perimeters
-25% Infill
Any suggestions?
