Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 12:55PM |
elkayem
sonnylowe
therippa
tjnamtiw
sonnylowe
Thanks for the heads up, I think I'll merge my current RC2 into RC3 and see what happens
EDIT: Just merged RC2 into RC3, all went well...I was printing again in less than ten minutes
Might I be missing something? When you say 'merge' the current RC2 into RC3, is there a magic way of doing this besides opening the two up side by side in Arduino and go down line by line making changes to the new one to reflect what's in the old one? That's what I've been doing.
That's part of the magic of git. You can tell it to grab the latest changes from the RC3 branch, and automatically merge them into the branch you are using. I prefer using Sourcetree to git command line, here are some instructions to get you started - [confluence.atlassian.com]
Since you probably didn't use git to pull the initial project, you should do this:
1. Install/open Sourcetree
2. File -> New/Clone -> Clone from URL. Use this URL: [github.com] . Clone it to a new folder somewhere on your computer.
3. You will now have the "RC" branch checked out. On the left nav, expand the Tags section, and right-click the 1.1.0-RC3 branch, and click checkout. Your project is now updated to the latest tagged RC
4. Use something like beyondcompare to compare your configuration.h to the one in the project. If I remember correctly, there were no changes made that I needed to port over.
5. Upload the project to the Arduino
6. Next time a marlin version is released, you can just check that version out and merge it automatically into what you're using.
Make sure you backup your current marlin folder in case you make any mistakes, but once you get the hang of git, you'll realize if you make any mistakes you can revert the changes easilyGit is DEFINITELY worth learning, you can version control pretty much anything with it, and you can host your projects for free on github or bitbucket, so in case your hard drive dies you won't lose any work.
Great explanation rippa, thanks.
This would be good info to add to the Wikia page for those that have slightly different printer setups, it's great for transferring settings like E-steps, PID, Etc.
I merged the RC2/RC3 config-h files using Beyond Compare, although it may not be the best way to do it, up to this point it was the only way I knew how ;-)
However, after reading this post I will definitely try it through Git next time...I'd love to understand it a little better
I use TortoiseGit, which includes its own merge tool. It includes a lot of nice context menus, and is useful for visualizing development log including all branches and commits. However, for someone who is simply modifying the configuration file, I think downloading the latest version off github and merging in your own changes to configuration.h using beyondcompare is a great solution. There is a bit of a learning curve to git that might be difficult for those who don't use it on a regular basis. On the plus side, for those who do use it, git will allow you to track all the changes you make to the files, so you can easily go back to an earlier version of configuration,h, for example, when something breaks. And it does make pulling and merging the latest versions of Marlin with your own mods a snap.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 01:19PM |
rollinns
XChris
I'm having problems with my extruder motor. The filament isn't being feed through properly, it just oscillates up and down, ie the motor moves forward a step then back as step. Problem remains with various Vref (from 0.1 - 0.6 V). When switching the wires for the x- driver, it feeds filament fine. When I switched the actual drivers on the board, nothing changes so it doesn't seem to be the driver. When I try to drive the x-motor, using the original extruder cables, same motor performance is seen.
Is this a firmware issue? Anyone have solutions or troubleshooting ideas?
I had similar issues a while back. I checked the same things you have.
To be clear on this "When switching the wires for the x- driver, it feeds filament fine." Do you mean the extruder is now plugged into the X-axis stepper pins? Meaning the extruder motor is now receiving power from a different driver and a different set of pins (both the x stepper driver and the x-stepper pins)?
if so then: different driver + different pins = success
And when you plugged a different driver into the extruder position and plugged the extruder into the extruder pins, it didn't work?
if so then: different driver + same pins = fail
I know some people here don't like when people blame the RAMPS board, but a new ramps fixed mine. I originally inspected my RAMPS before installation and found a stray solder blob, which I removed, at this point I knew my RAMPS was one of the poor RAMPS boards FT is known for. It worked for a while, but after the problems you've described came up later, I did the same tests and a new RAMPS fixed it. I didn't suspect firmware since I'd not changed it at all. There may be a component that could be replaced on the RAMPS to fix it (I'm not sure), but if it's a RAMPS that came from FT, my opinion is that it's not worth fixing. If you ever need to fix a RAMPS that way, spend the time and money repairing a higher quality board.
Later, similar problems returned, but I was able to confirm it was a bad driver the second time, so I swapped in dirt cheap DVR8825 drivers from aliexpress and it's a lot quieter.
I really like my FT 2020 i3, it's a lot of kit and education for the money, but I won't stand behind the RAMPS boards they ship at all. Maybe they've recently changed suppliers (again), but it doesn't appear that way.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 01:40PM |
therippa
tjnamtiw
sonnylowe
Pretty confusing to this old brain and that Sourcetree tutorial with the example is awfully strange and off-topic.|
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 04:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 10:45PM |
peeejayz
I got my leadscrews through today, the nuts have a bit of play in them is this normal?
Do I need to antibacklash them? I havn't needed it on the m5 rods yet.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 10:49PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 10:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 26, 2016 10:57PM |
chking
My kit arrived today but I've run into a snag. The printed parts that hold the LM8UU bearings are too tight. I've been able to get two bearings in so far. Should I look at dremeling the printed parts so I can get the bearings to fit? Has anyone else run into this issue?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 12:07AM |
That's a good idea. I've been holding off the lead screw because I don't want a shitty product. Might as well make my own. I'd imagine nylon would work better though? If so, might be able to print one.Quote
sonnylowe
peeejayz
I've seen the same issues with all the LS nuts I've bought so far, my guess is they are cheap and out of tolerance, or I've just been unlucky...three times in a row ;-) It's the reason I made the anti-backlash setup I'm currently running. I like it, however I can tell the Brass Nuts are degrading already, so I made these today...
They are a perfect fit with the threaded robs, no play at all. I hope they will be a better alternative to the brass nut!?!? I'll finish polishing the threaded rod this weekend and hopefully have them shortly after...
I am also in contact with my Igus rep trying to get him to send me a sample of their Drylin round stock so I can machine some out of that
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 12:27AM |
DaveA
I just installed a BLTouch sensor but I'm a little unsure how to set up the Z axis offsets. I'm running on Marlin RC3 with the changes from the Wiki merged in. I just need a little help in getting the vertical position set right.
I'm using [www.thingiverse.com] as the BLTouch mount on the stock FT extruder head. Anyone recently done this?
#define X_PROBE_OFFSET_FROM_EXTRUDER -31 // Z probe to nozzle X offset: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0 // Z probe to nozzle Y offset: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -4.3 // -3.8 // Z probe to nozzle Z offset: -below (always!)
#define Z_RAISE_BEFORE_HOMING 7 // (in mm) Raise Z axis before homing (G28) for Z probe clearance.
// Be sure you have this distance over your Z_MAX_POS in case.
#define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min.
#define Z_RAISE_BEFORE_PROBING 9 // How much the Z axis will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 9 // How much the Z axis will be raised when traveling from between next probing points.
#define Z_RAISE_AFTER_PROBING 9 // How much the Z axis will be raised after the last probing point.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 03:47AM |
sonnylowe
peeejayz
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 09:11AM |
Bert3D
DaveA
With that mount, assuming yours extruder is just like mine, it will be 31mm offset to the left on x, and 0 offset Y. The Z will vary, depending on the adjustment of your BLTouch. I raised mine up a bit to give the probe more clearance. That is a 2mm hex adjustment socket in the top of the BLTouch, which raises and lowers the pin.
Here are my settings, but yours could be different, so consider them just an example:
#define X_PROBE_OFFSET_FROM_EXTRUDER -31 // Z probe to nozzle X offset: -left +right #define Y_PROBE_OFFSET_FROM_EXTRUDER 0 // Z probe to nozzle Y offset: -front +behind #define Z_PROBE_OFFSET_FROM_EXTRUDER -4.3 // -3.8 // Z probe to nozzle Z offset: -below (always!) #define Z_RAISE_BEFORE_HOMING 7 // (in mm) Raise Z axis before homing (G28) for Z probe clearance. // Be sure you have this distance over your Z_MAX_POS in case. #define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min. #define Z_RAISE_BEFORE_PROBING 9 // How much the Z axis will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 9 // How much the Z axis will be raised when traveling from between next probing points. #define Z_RAISE_AFTER_PROBING 9 // How much the Z axis will be raised after the last probing point.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 09:39AM |
DaveA
Bert3D
DaveA
Thanks Bert3D. How did you arrive at the -4.3 offset for Z. Did you just sneak up on the trip point of the BLTouch with the probe extended and record the position and then sneak up on the nozzle just slightly above the bed and recording that point and then do the arithmetic?
Using that method I came up with -3.9 so maybe that's the correct approach.
I'm going to revert to RC2 and my original Z stop for a test after work. With my current setup the prints are awlful - just a ball of filament. So I'm not sure if it's the bed leveling or something else I missed in RC3
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 10:15AM |
peeejayz
sonnylowe
peeejayz
How long did your setup with 2 brass ones and springs last?
Just wondering what my best option is.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 10:23AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 10:44AM |
DaveA
Bert3D
DaveA
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 01:24PM |
mindstormmaster1
I need to calibrate my printer, but before I do I wanted to I wanted to upgrade my firmware from the stock firmware. I keep seeing talks about a new version (Merging RC2 and RC3) so I am wondering should I wait?
Also since my printer is running well what is the best process for upgrading without messing up all my settings?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 01:32PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 01:51PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 02:04PM |
sonnylowe
mindstormmaster1
You want therippa's version of Marlin (it's in his sig or the Wikia page), it is already RC3. The talk about merging RC2/RC3 was between a few select people. You will most likely still need to merge your current version of marlin with RC3 as there are a few setting that will need to translate over (E-Steps, PID if you ran autotune, Etc.).
As far as waiting to calibrate, it doesn't really matter if you do it now or later, either way those setting (mentioned above) will need to be transferred.
Hmmm, now that I think about it a bit more, I guess if you did it before you calibrated and missed an e-step setting (or got it wrong) it wouldn't matte as much since you'd be calibrating it after anyway...so now might actually be better in the long run!?!?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 02:48PM |
therippa
sonnylowe
The firmware in my sig isn't RC3, it's the latest stable release.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 03:17PM |
DaveA
Bert3D
DaveA
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 06:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 06:27PM |
UltiFix
Yay, printer just showed up! After being delayed in the awful snow storms. Oh well it's here! Nothing more, nothing less! They didn't forget anything
Gosh, they just take ALL of the hardware and chuck it in a bag LOL
Sorry I can't attach pics, there prob to big...
[imgur.com]
[imgur.com]
[imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 07:13PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 07:14PM |
Bert3D
DaveA
Bert3D
DaveA
I just homed using G28, then started lowering the printhead using negative Z movements, like G1 Z-0.5 then G1 Z-1, etc., until I got the nozzle to just touch the bed. Then I noted the distance that made it just barely make contact, which was G1 Z-4.3. To insure accuracy, I raised the head to 2mm using G1 Z2, then lowered it again, verifying he nozzle stopped just where I wanted it. Tweak the number until it goes down to the exact right height, and that number is your z offset.
If you can't get it to move to negative coordinates, you can compare with my config here https://github.com/AlwaysTinkering/Marlin to see what's different.
My other code changes are for my hardware setup with the Graphic controller, Z Lead Screws, and X endstop on the left. I'm using the stock extruder and hot end setup.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 07:19PM |
UltiFix
Anybody elses printer come with L brackets that had huge holes? And the Bolts nearly fall through? Nice way to start off the build -_- They keep falling out on me.. I might need some washers for it. The L brackets are differen't than in the picture..
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 07:24PM |
Thanks, I was super ticked, like I can't even complete step 2 -_- I was wondering if I was using the wrong bolts or what... Whatever. Washers to the rescue!Quote
GrouchoDuke
UltiFix
Yeah, I put M4 washers on mine then pushed them to the end of the hole. Seems to work fine...messy, but fine.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 07:53PM |
therippa
sonnylowe
mindstormmaster1
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 27, 2016 07:57PM |
