Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 09:24AM |
GrouchoDuke
My BLTouch is finally working. Short story is that I had to power it with something other than the RAMPS board's Vcc pin.
I've been chasing my tail on this for a while. At first, I didn't know that the RAMPS board requires a jumper between the Vcc & 5V pins to provide power to the positive voltage servo pins (near the reset button by the servo connectors). After figuring that out I still couldn't get it to work. My BLTouch's pin would randomly not drop when doing Z homing. I later noticed that the BLTouch would redo its startup checks (the 3 cycles of the pin thing it does) sometimes when multiple axis motors were moving quickly.
So, I wired up a 5V/3A regulator and powered it from the main power supply. I used a servo connector to connect the 5V output of the regulator to the 5V pin on the RAMPS. After that, the BLTouch has been running perfectly. G28 & G29 commands now work and the results from G29 seems to be pretty consistent. I added G29 to my custom G code list in the slicer and also added a z axis move after the print's over to make sure the BLTouch pin clears (because it appears to drop the pin when a print is over for some reason). I adjusted the Z offset (which took a few test prints to get right) and now the printer seems to be working well.
It's time to print some stuff!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 10:28AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 10:56AM |
marc2912
GrouchoDuke
If you have time you should put detailed instructions on the wiki
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 11:01AM |
GrouchoDuke
marc2912
GrouchoDuke
My prints are still mirrored in X. I'd rather not share config steps until I figure that out. I guess adding some info on porky entail BLTouch powering issues wouldn't hurt though.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 12:29PM |
GrouchoDuke
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 01:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 01:41PM |
markts
I finally stared the E3D-Lite6 assembly. It includes "ferrules" for "solder-free" assembly. That's a convenience thing, right? I'm comfortable soldering so there's downside soldering vs crimping with the ferrules, correct?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 02:49PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 02:58PM |
UltiFix
So in the rep host software how do I change my "default folgertech pla" temps? I see I can change default extruder temp but when I print using slic3r (Built into rep host) I have to choose a set parameters. So basically im asking how do I change that? Im print pla at 219 and i think it's to hot, I want to try 180.
Thanks!
Sam
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 03:18PM |
Thanks!Quote
animoose
UltiFix
Thanks!
Sam
In Repetier's Slicer tab, click the Configuration button. After a while the configuration window for Slic3r should appear. Then you can click the Filament Settings tab and change or add profiles. Click the disc icon to save them.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 03:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 03:27PM |
So far my print is going pretty good! Next print I can always bump it up and experiment! Im so glad plastic is DIRT cheapQuote
animoose
It's best to experiment, in my view. The ideal temperature varies with the filament (even amongst different suppliers of PLA) and the speed you print at. Based on my experience, I would say that 180 is a little low. These days I mostly use 190 or 195 with a bed temperature of 50.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 03:34PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 03:52PM |
animoose
I thought you might like to see a moment of pure awesomeness. I am printing a large spiral spring. Cura tries to avoid travel moves which cross the perimeters of the object, unlike Slic3r which takes straight lines and so gives more spider's webs. And it does travel moves as fast as possible. Wait until about 1:10 in the video. [youtu.be]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 04:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 04:52PM |
MuckYu
Hi, I just finished building the printer following the guide. I double and triple checked everything. I then started Repetier-Host to calibrate the X/Y/Z-axis. Then I got some problems
1) I realized that the heat bed is not working. How can I test if it is broken? Any ideas?
2) The PCB is sometimes blinking red. Any reason why?
3) Printing does not work at all. I import a model to Repetier-Host. I then slice it and press print. Nothing happens. When I want to "stop" the print nothing happens again. Trying to move the extruder or bed with the manual control is also not working then. I am also unable to close the program "extruder" still heating ..
The only reason to get back to the beginning is to kill the process in the task manager.
Long story short. So far I can only move the X/Y/Z axis with the manual control. Nothing else seems to work.
Can anyone help me with these problems? I was not able to find any good instructions for that
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 05:05PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 05:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 05:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 07:53PM |
tjnamtiw
GrouchoDuke
This comes straight from the arduino.cc website >> ''Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.'' so supplying an external source for the 5V may not be the safest thing to do in this case although I know several people who are. So you put the +5V on the 5V pin where the jumper used to be. Where did you put the negative lead?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 08:29PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 08:40PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 08:49PM |
thebabymaker
Lookong for any recommendations on hardware (screws, bolts,etc) kits that I can buy to have a good stock of hardware for upgrades. Or, which sizes should I get to cover 90% of my needs? Nothing worse than realizing you are missing something in the middle of a project!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 09:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 10:13PM |
chking
I finished building my printer today and I set up Repitier to test manual control of it. So far the X-axis is working well but the other two axes will only go in one direction. For instance, the Z-axis will only go down, when I tell it to go up it says "endstops hit" but none of the end stops have been triggered. The Y-axis will only go towards the back of the printer and gives the same message if I tell it to go forward. I'm using the newest version of Marlin from Github (https://github.com/therippa/Marlin) and I've moved the X-endstop one to the right.
One other issue, I've installed the 2004 LCD display controller with adapter for RAMPS 1.4 but I'm not getting any display. Is there something else I need to do to enable the LCD screen?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 10:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 11:41PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 11:51PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 31, 2016 11:59PM |
I did that, and im doing a test print now. Hopefully it goes well! I don't have to do anything to enable auto do i?Quote
msaeger
Set perimeters, small perimeters, external perimeters, infill, solid infill, and top solid infill to 0 then set auto speed max print speed to 50 (or whatever you want to try) and see what that looks like. I have gotten the best results using the auto speed. I also set non print move speed to the same as the max print speed because it made the printer much quieter and didn't really add much to the overall time.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 01, 2016 01:39AM |
iamquestar
UltiFix
I want to print multiple objects at once, some taller than others.. will the extruder "forget" one of the objects are there and hit it? Like at the end when it resets to default position?
Nevermind, the extruder will end up at the highest point of the print, duh
On a side note, would you guys let your printer run overnight?
I'm letting mine run right now. I'm about to go to bed, and it has another 7 hours to go on this print. The first time I did an all nighter, I woke up several times and each time went to check progress. I've had such great adhesion that I don't worry much any more. BUT I think it wise to have Thermal Runaway protection enabled. No sense tempting fate.
