Folger Tech 2020 i3 Printer Kit (Official Thread)
Posted by Dan_FolgerTech
Re: Folger Tech 2020 i3 Printer Kit (Official Thread)
February 01, 2016 05:36PM
UltiFix
Mach
UltiFix
Im confused about how to calibrate my extruder, when I measure 150mm is that before I even insert any plastic into the extruder? Or do I have some inserted then measure from the top of the extruder.
Thanks!
Sam
EDIT:
Im assuming the second from looking at the video a second time.
Now I have a new question.. If I re upload the firmware do I need to add the folgertech setting's again?
As long as you are using the same file from before, everything will stay the same as the last time you saved it. Control + S is a helpful shortcut for saving things in files smiling smiley
Thank you for your help and quick responses! Sorry if I sound like a idiot confused smiley Once my dolphin is done printing im going to calibrate it.
Thanks!
Sam
No problem. everyone has to be new to something every once in a while.
Folger Tech I3 2020 Wikia page: [folgertech.wikia.com]
Custom Folger Tech I3 2020 custom search
February 01, 2016 05:48PM
Mach
UltiFix
Mach
UltiFix
Thanks!
Sam
EDIT:
Thanks!
Sam
Well that was easy, i'm going to try printing another double helix, hopefully it will help grinning smiley If I like the results im gonna run a "huge" 5 hour print.
I was off by abuot 13mm, is that significant?
Edited 2 time(s). Last edit at 02/01/2016 05:52PM by UltiFix.
February 01, 2016 06:01PM
UltiFix
Mach
UltiFix
Mach
UltiFix
Thanks!
Sam
EDIT:
Thanks!
Sam
Not sure I understand the question..
February 01, 2016 06:09PM
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Thanks!
Sam
EDIT:
Thanks!
Sam
Sorry, it wasn't well typed out.
I mean my extruder was off by 13mm, I changed the value from 90 to 103, is that a big change? So far my print still has some gaps in it, what else should i calibrate? The x y and z steps?
February 01, 2016 06:20PM
UltiFix
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Thanks!
Sam
EDIT:
Thanks!
Sam
That is a huge difference. As for your X, Y and Z, the X and Y should be at 80, and the Z should be at 4000. Also make sure your belt are fairly taught, but not to much. It make have a dull "twung" sound when you shrum it. Make sure the set screws on the pulleys are tight too.
February 01, 2016 06:29PM
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Thanks!
Sam
EDIT:
Thanks!
Sam
My z is at 3840, not sure why? Will change it now.
Also added a spring tensionor to my loose belt. And im trying this to.
EDIT: Pretty much everything i have done hasn't made a difference in my print quality. What else can I do? Tried letting the printer do the autospeed, tried calibrating exturder, and added spring's to the belt. Im printing pla at 190c with bed at 70c
Edited 2 time(s). Last edit at 02/01/2016 07:01PM by UltiFix.
February 01, 2016 07:15PM
UltiFix
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Thanks!
Sam
EDIT:
Thanks!
Sam
Did you level your bed? If you did, the only other thing I could think of could be your loose extruder. If the nozzle has to much play to it, that will mess up the precision of the generated tool path.
February 01, 2016 07:26PM
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
Thanks!
Sam
EDIT:
Thanks!
Sam
I have leveled my bed multiple times, im printing that double helix as my test... Maybe that's a bad one because I was printing it at half of it's original size.. Probably causing to it print badly because it was designed to be twice as big.
February 01, 2016 07:40PM
The size of the print in relation to the original size should not affect the quality of the print other than any small details in the object. It would probably be better to do test prints with smaller object, so that less time would be spent on each test, and so that there are less possible variables to deal with. I would suggest a something simple like a small cube or cylinder.
Edited 1 time(s). Last edit at 02/01/2016 07:44PM by Mach.
February 01, 2016 08:05PM
So I have a weird question. How do I use the springs they provided as belt tensioners? I understand how the cylindrical "bedsprings" work for leveling the bed, I'm more wondering how to tighten the belt with the clip-like springs.
ETA: Do any of you have pictures of how you used them?
Edited 1 time(s). Last edit at 02/01/2016 08:08PM by bstern.
February 01, 2016 08:16PM
bstern
Here is a pic. They may be a royal pain in the butt to put on. I remember I spent about forth mins putting one on my Y belt. tongue sticking out smiley was easier the second time I putting one on though
February 01, 2016 08:32PM
For the LED screen issue I tried switching the two cables around but that had no effect.
For the end stop issue, I ran the M119 command and received the results below. Why would the endstops that don't have a switches connected to them show a TRIGGERED status?
19:28:36.536 : Reporting endstop status
19:28:36.536 : x_min: open
19:28:36.536 : x_max: open
19:28:36.536 : y_min: open
19:28:36.540 : y_max: TRIGGERED
19:28:36.540 : z_min: open
19:28:36.540 : z_max: TRIGGERED
19:28:36.540 : ok
February 01, 2016 08:40PM
chking
19:28:36.540 : ok
You have to enable the pullup resistors for the endstop positions in your firmware that you are not using, else the controller will think they are activated.
February 01, 2016 09:21PM
bstern
Roll the belt off of the motor and THEN put the spring on. Then roll the belt back on.
Folger Tech 2020 i3 and FT-5 as well as modified JGAurora A5 with direct drive E3D/Titan. All running the BLTOUCH.
Great kits. Having fun and running the heck out of them.
Running Marlin 1.1.0 RC8 on the i3 and FT5. Custom firmware on A5.
Folger Tech Wiki board >[folgertech.wikia.com]
February 01, 2016 10:03PM
Mach
bstern
I would reccomend using needle nosed pliers, go on not to bad grinning smiley
February 01, 2016 10:29PM
Have any of you used cura over slicer? from some posts on the interwebs it looks like it does a finer job. I can obviously believe everything I read lol
February 01, 2016 10:43PM
UltiFix
I use it. I have never used slic3r so I cannot really say, but I believe it is better. Completely my personal opinion though. I have heard that a new slicer call craftware is better than cura, so I may have to try that out one day...
February 01, 2016 10:44PM
Iv been printing everything on %10 infill, is that to low? What about for the double helix thingy? Im assuming 10 is way to low
On slicer in the override section even if I move my infill really high the estimated print time isn't changed?
What?
Edited 1 time(s). Last edit at 02/01/2016 10:47PM by UltiFix.
February 01, 2016 10:48PM
Mach
UltiFix
Mind sharing your setup file for pla? I would like to try it out.
Edited 1 time(s). Last edit at 02/01/2016 10:48PM by UltiFix.
February 01, 2016 10:51PM
UltiFix
Mach
UltiFix
For cura?
February 01, 2016 10:53PM
Mach
UltiFix
Mach
UltiFix
For cura?
Yea, your using this folger tech printer right? Assuming you do hopefully the file will work decen't without a ton of tuning grinning smiley
February 01, 2016 10:57PM
UltiFix
Mach
UltiFix
Mach
UltiFix
For cura?
Yes I am using the FT. I am using bowden though, so some of the settings may be abit uh...interestting grinning smiley. 10% infill is fine for that type of print btw.
February 01, 2016 11:01PM
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
For cura?
Ah, ok. Did you find something wrong with the stock extruder?
February 01, 2016 11:06PM
UltiFix
Mach
UltiFix
Mach
UltiFix
Mach
UltiFix
For cura?
The extruder hanging 4 inches off of the X carriage was driving my nuts, plus I wanted to be able to get faster speeds without sacrificing quality, or shaking apart the printer. tongue sticking out smiley
February 01, 2016 11:12PM
Here is my cura config. You may have to change alot of the values and setting, special the speed setting.
open | download - Current cura config.rcp (3.1 KB)
February 01, 2016 11:19PM
Im printing at 15mm/s instead of 30mm/s, I want to see if it increases the print quality. Will report back!
How slow do you guys print?
February 02, 2016 12:34AM
UltiFix
marc2912
iamquestar
iamquestar
UltiFix
I want to print multiple objects at once, some taller than others.. will the extruder "forget" one of the objects are there and hit it? Like at the end when it resets to default position?
Nevermind, the extruder will end up at the highest point of the print, duh eye popping smiley
On a side note, would you guys let your printer run overnight?
I'm letting mine run right now. I'm about to go to bed, and it has another 7 hours to go on this print. The first time I did an all nighter, I woke up several times and each time went to check progress. I've had such great adhesion that I don't worry much any more. BUT I think it wise to have Thermal Runaway protection enabled. No sense tempting fate.
So I had to open my big mouth about "good adhesion..." I woke up this morning to this:
[attachment 71376 goof.jpg]
There were 4 other items on the build plate that, thankfully, stayed stuck AND didn't get killed by this wandering piece. Note to self, on things without a lot of contact area at the base... Use a brim!
I'd recommend not running your printer overnight until you're sure it's stable and even then I'd recommend some safety features. 3d printers are a potential fire hazard and until you have them, for certain, dialed in properly I'd always run it supervised.
+1, all it takes is a loose wire by the extruder and boom, cable management is VERY important on these things!!
I completely agree! But that's not what happened here. I have good cable management, although when I rebuild my X axis I'm installing a couple cable chains. The issue with this one was just too little surface area contacting the bed. That cylinder was hollow, with no bottom, and was just 2 passes thick. On top of that, I am having an issue with sag on the extruder, so at times, it can bump the top of a piece. I think that's what dislodged this.
February 02, 2016 12:46AM
iamquestar
therippa
iamquestar
Hello fellow FT2020ers! Let me start of by saying a huge THANK YOU to all of you who have contributed to the thread over the past several months. It has been an invaluable resource to me these past couple weeks since I received my FT 2020. (I'm reading through it, but am still back at page 92 - I'm getting caught up!)
I had a couple issues out of the gate (the same things as many of you). I also had a bad hot-end termistor which prevented me doing anything until I diagnosed that. I pulled the one off the bed to get things going, and have stuck with PLA for now.(The good folks at FT have taken good care of me, and sent out replacement parts immediately.)
So when I got things up and running, I ran my first print (without doing any other extruder calibration or anything) and it came out beautifully (I turned down the temp to 195c from the default 219). From that cube, I did some calibration to the XYZ steppers, and have calibrated the extruder to accurate 100mm runs.
Attached is a pic of my 6th or 7th print, and I think Benchy came out great.(.2mm, 30% Infill)
I'm having a couple issues that I can' figure out. First, the middle of my print bed is higher than the corners.It doesn't matter what I do, but I can get the corners all the same height, but I can't print anything in the middle unless my first layer is set to .4mm, as at .2, the nozzle touches hard, and can't extrude anything. I have checked the heat bed with a straight edge, and it looks good and flat. I've used multiple sheets of glass, and all have the same issue. Anyone else deal with something like this?
The second problem I'm having is with object scale. I printed out a set of the Z motor standoffs, to raise them up and reclaim my height, but they came out small. I couldn't insert the 608 bearings for the life of me, so I pulled out the calipers and sure enough, they measured small. I had to upscale them to 1.024 for them to print the right size. Now before you yell Calibrate! I have. When I print a 20mm cube, it comes right in at 20x20x20mm. I have a number things I want to print, but I need accurate dimensions, and I can't print each thing a second time (after seeing the results, then scaling up to compensate). So do any of you have any recommendations?
For your first problem, sounds like a rod may be bent, there's no reason it shouldn't be perfectly flat if you're printing on glass
For the second problem, a lot of people have problems with holes being too small (I'm in that camp, by like a fraction of a millimeter, I just design around it). Try googling for potential solutions (there's a bunch)
Thanks for the quick reply. You have provided many words of advice I have benefited from.
The first issue may be caused by the build plate. When I received it from FT, it was bent. I *thought* I had been able to bend it back to OK flatness (not perfect, but I figured if the heat bead was "floating" above it, it should be good enough.
The second issue us not just holes being too small. (although I realize my mention of the bearing made it sound like that.) I can deal with that. It's the whole part that is printing small. For example, on the z motor standoffs, they measure 39mm in the software. When I first printed them, the result was about 38.05 wide. Almost a full mm off for the screw hole alignment (at the base). Up-scaling by 2.4% got me to the proper size. If that was required for everything, I would expect the 20mm cube to print out at about 19.5mm but its printing right at 20. That's what has me so puzzled.
Just in case this helps any others out there that run into similar issues... I've resolved the sizing problem, and have discovered what is going on with the bed leveling challenges.
First, the scaling/size issue resolved itself after I updated to the latest Marlin firmware (thank you therippa!). After doing that and re-calibrating the extruder, things started printing accurately.
Now for the issue with the tip of the nozzle hitting the bed hard in the middle, I first upgraded my build glass to 3mm tempered. It was much stiffer than the cheap picture frame glass I was using (which could bend a little). My new glass looks very flat, when checked with a straight edge, and is strong to the point where I cannot deflect it with my hands, So once I started leveling the bed with this, I found that even across the surface from front to back, the middle of the bed appeared higher than the edges (even when rotating the glass). So I believe that the extruder is sagging just a bit (.1-.2mm in the middle of the rails, but closer to the sides, the shorter distance from the end pieces doesn't allow the weight of the extruder to make as big of a difference.
So that's what it looks like to me so I am planning on installing sonnylowe's v-slot x axis upgrade. I think it will solve that problem.
February 02, 2016 01:13AM
UltiFix
I usually print between 50-60 mm./sec @ .2mm layers - If I'm going to .1, I slow that down to more like 30-40,
I just printed this small box (50mmx50mmx25mm) and lid for my son at .2mm layers, 50mm/sec. for inner perimeters, 40mm/sec outer perimeters, and, 75mm for infill (not that there was much)
I used Cura. I have found that it seems to be a cleaner job than Slic3r. Since Slic3r was the default, I used that a lot in the beginning, but have been very pleased with results from Cura, once I got used to the different settings.
--Andrew
February 02, 2016 01:25AM
iamquestar
UltiFix
[attachment 71458 box.jpg]
--Andrew
Can you recommend me good cura setting's for a stock folgertech 2020 printing pla? Or a good 3D printer youtube channel?
Btw - Nice print!
Edited 1 time(s). Last edit at 02/02/2016 01:35AM by UltiFix.
