Folger Tech 2020 i3 Printer Kit (Official Thread)
Posted by Dan_FolgerTech
Re: Folger Tech 2020 i3 Printer Kit (Official Thread)
February 06, 2016 12:27AM
I finally got around to installing Sonny's v-slot Y axis. I would defiantly recommend doing this as your first upgrade. It is only slightly quieter than what I had but I spent a lot of time and went through many iterations to get it as quiet as it was. Installing this was so much easier than the rods and bearings you don't really need to worry about getting anything lined up like with the stock setup. I want to switch to the v-slot X axis too but first I think I will do something about the power supply. I am thinking about modding an ATX one because I can't find and LED strip type with enough power that doesn't have a fan so I doubt they would be quieter than what I have now.
Here's a pic and video of my Sonnytech printer [goo.gl]
Thanks Sonny!
Newbie with Folgertech 2020 i3.
February 06, 2016 08:10AM
Need help diagnosing the problem shown in the photo. Seems that anytime I print a relatively large rectangular object 1/2" thick or more, the corners peel up. I'm printing ABS, extruder at 220 and bed at 100 with 25% infiill. Printing directly to the glass with good adhesion on the first layer. I have run autotune on the bed and was hoping that would fix it but it didn't. Maybe I need to try increasing the bed to 110?
February 06, 2016 08:15AM
Anyone mess with the swap filament command? M600
Edited 1 time(s). Last edit at 02/06/2016 08:16AM by jabu32.
February 06, 2016 08:18AM
UltiFix
Can anybody reccomend if the hatchbox glow in the dark is any good?
[www.amazon.com]
Hey Ultifix! I have had great success with Hatchbox glow-in-the-dark. I printed the MakerBot T-Rex skull with it. It's one of the most fun filaments to play with. Keep in mind that it has to be "charged" first under a light to glow, the more intense the better, but the effect is very cool.
February 06, 2016 08:20AM
jabu32
I usually just pause and swap out the filaments.
February 06, 2016 08:23AM
msaeger
Thanks Sonny!
"Sonnytech"...I love it. Printer looks great, glad you like the upgrade smiling smiley
My Stuff on Thingi
FolgerTech Wikia Page
Custom Search by Animoose
MakerSL.com
February 06, 2016 10:55AM
LancelotL
[attachment 71927 IMG_1870.JPG]Need help diagnosing the problem shown in the photo. Seems that anytime I print a relatively large rectangular object 1/2" thick or more, the corners peel up. I'm printing ABS, extruder at 220 and bed at 100 with 25% infiill. Printing directly to the glass with good adhesion on the first layer. I have run autotune on the bed and was hoping that would fix it but it didn't. Maybe I need to try increasing the bed to 110?
What are you putting on the glass to make it stick? I have found just coating the glass with white elmers glue and letting the heated bed dry it to be the best. It's hard to get stuff off sometimes but it's not warping.
February 06, 2016 11:05AM
jabu32
I've not used the M600 command...I use this code to swap filament:
G0 Y150 Z10 F600 (Z height changes dependent on swap height)
M0
G92 E0
Octprint pauses, I swap filament, purge filament using manual controls and hit resume...
Edit:
Here's and example at layer 20, the added G-Code is red...
G1 X102.725 Y90.940 E7.2535
G1 X105.082 Y90.940 E7.3319
G1 X109.060 Y94.918 E7.5190
G1 X109.060 Y92.561 E7.5974
G1 X107.439 Y90.940 E7.6736
G92 E0
G1 E-1.0000 F1800
G1 Z3.830 F1002
G0 Y150 Z10 F600
M0
G92 E0
; layer 20, Z = 3.98
; inner perimeter
G1 X109.400 Y90.600 F4800
G1 Z3.630 F1002
G1 E0.0000 F1800
G92 E0
G1 X109.400 Y109.400 E0.6253 F1463
G1 X90.600 Y109.400 E1.2506
G1 X90.600 Y90.600 E1.8759
Edited 1 time(s). Last edit at 02/06/2016 11:11AM by sonnylowe.
My Stuff on Thingi
MakerSL.com
February 06, 2016 11:38AM
msaeger
LancelotL
I don't put anything on the bed as I like the mirror polish I get from direct contact as well as the constant gap. I may have to try that though if the higher temp doesn't work. I am also going to use a skirt net time to see if that helps. Thanks!
February 06, 2016 11:40AM
LancelotL
msaeger
LancelotL
You can try a brim but from what I have seen with something that large it will still warp. If I mix some glue with a few drops of water and painting it on with a brush I still get a smooth bottom. I was sick of messing with the brush so I have started just smearing on the straight glue which ends up not being as smooth.
Edited 1 time(s). Last edit at 02/06/2016 11:46AM by msaeger.
February 06, 2016 11:49AM
LancelotL
msaeger
LancelotL
You can use hair spray, mega hold or extreme hold(pink can #10 for hold factor). Still get the glass finish. Just coat the glass with it.
February 06, 2016 12:14PM
So I just got done trying out craftware, and....I am disappointed. It is missing so many features that using it right this point would be too inconvenient. One thing that I really was surprised to find is that you cannot even connect to and manually control the printer other than the temperature. I do not know if it is because it is still in development, or if it was made more for their printer but it definitely has a ways to go.
Folger Tech I3 2020 Wikia page: [folgertech.wikia.com]
Custom Folger Tech I3 2020 custom search
February 06, 2016 02:44PM
My printer is printing anymore, it just leaves white lines on the glass and I can hear a clicking sound from the extruder, ideas?
EDIT:
Somehow I think my extruder got to close to the bed... Not sure how?
Edited 1 time(s). Last edit at 02/06/2016 02:49PM by UltiFix.
February 06, 2016 02:50PM
So when I print 2 objects like one has a piece that fit's into another piece, male and female the female piece is to small, maybe the male end is to big to. How do I get my printer to print the scale right?
February 06, 2016 02:54PM
UltiFix
The two options are to scale it, or to modify it in a cad program. The downside of simply scaling it is that features that you do not want to scale will scale in addition to the improperly sized features.
UltiFix
At this time what have you tried? Tuning your printer is a time consuming process which leaves a slightly different printer for everyone. Did you tune your x, y and z axis, and if yes how so? How precise was your tuning? Did you tune your extruder? Have you tried different slicer settings? Different extruder and bed temperatures? Just posting questions like above really make it difficult to help you without knowing if you've done anything to help yourself.
February 06, 2016 03:02PM
marc2912
UltiFix
Good point, I have calibrated the extruder and that's it... Should I start off by printing a cube and seeing where im at?
Im printing PLA at 210 and bed at 75
I calibrated the extruder by marking the PLA at 150mm and then extruded 100mm and checked the mark to see how far off my printer was.
Thanks!
-Sam
Edited 3 time(s). Last edit at 02/06/2016 03:17PM by UltiFix.
February 06, 2016 03:17PM
Mach
UltiFix
Alright thanks!
For all I know the person that made the .stl file has there printer off, so maybe ill just learn how to modify it in the cad program, thanks!
February 06, 2016 03:25PM
UltiFix
One option which sometimes works is to print either of both parts with reduced extrusion. In Slic3r, you do this by changing extrusion multiplier in the filament settings. 0.9 or 0.85 are typically good values. Cura uses the flow value in the filament settings for the same thing, though I've not always found it to work well. I reported on some experiments I did at [moosteria.blogspot.com].
See my blog at [moosteria.blogspot.com].
February 06, 2016 04:09PM
UltiFix
I have a 12mm proximity sensor coming, how do you reccomend I mount it to the stock folgertech 2020 extruder? I looked on thingiverse and didn't find anything for the folger tech...
[www.thingiverse.com]
I'm partial to this one I designed: [www.thingiverse.com]
It's based off another I found for the folger combined with a print cooling fan mount I use. I have both a 12mm and a 18mm version uploaded now. The 18mm version is a bit more fine tuned than the 12mm since I'm now using the 18mm sensor as it's improved sensing really makes a big difference for me.
February 06, 2016 04:24PM
UltiFix
marc2912
UltiFix
Thanks!
-Sam
That seems really hot for pla but if you're sure you've calibrated it right then yes, I'd move on to calibrating your axis. If you start changing extrusion multiplier or changing the size in the FTL you might be masking issues with your setup that will creep up and mess you up later.
February 06, 2016 04:56PM
marc2912
UltiFix
marc2912
UltiFix
Thanks!
-Sam
Well I am currently using some PLA I got off of ebay, I ordered some plastic from hatchbox so maybe that will be higher quality.
Edited 1 time(s). Last edit at 02/06/2016 05:01PM by UltiFix.
February 06, 2016 10:48PM
jhitesma
UltiFix
I may just print that one and use it even though I don't have a fan mount, this is the sensor i ordered, im assuming im going to need to give it a 12v PSU? If so not a big deal...
February 07, 2016 01:15AM
So I made this in google sketchup, but when I put the file in rep host it looks like it should. But when I slice it, it no longer has the hole in it?
Why?
February 07, 2016 01:23AM
UltiFix
Why?
Might be the normals pointing the wrong way. That is, the faces of the inset portion might be pointing inwards rather than outwards. The fact that the faces are colored differently and you can see the grid showing through suggests something like this is wrong. I don't know sketchup, so I don't know if you can check and fix this (you can in Blender, which is what I usually use). Also try putting it through netfabb.azurewebsites.net to see if that fixes it.
Edited 1 time(s). Last edit at 02/07/2016 01:24AM by animoose.
February 07, 2016 01:32AM
animoose
UltiFix
Why?
Animoose is correct. In sketchup, faces will appear gray when they are backward and white when they are the correct way. You can reverse the face by right clicking on it and selecting "reverse face". Also, all of the faces need to have depth to them, or else they will just be 2D, which cannot actually exist. The face on the bottom and sides of your model is perpetually flat.
February 07, 2016 01:55AM
Mach
animoose
UltiFix
Why?
I reversed the face so it's white now, but im not sure how to add depth to my faces? Using the push pull tool it just expends my entire model
[prntscr.com]
February 07, 2016 01:58AM
animoose
UltiFix
Why?
I did try going through netfabb grinning smiley How did you learn to use blender? Can you reccomend a good youtube series on learning it?
It seems to have a huge learning curve..
Edited 1 time(s). Last edit at 02/07/2016 01:58AM by UltiFix.
February 07, 2016 08:26AM
msaeger
LancelotL
msaeger
LancelotL
Thanks msaeger, and Mopar99! I solved the problem, but changed three variables in the process so I'm not really sure which one fixed it. I upped the bed temp to 110, moved to the center, and added a 5 mm brim. I have tried adhesives like hairspray before but found that they make the build surface irregular very quickly and the glass needs to be cleaned constantly. I have had much better luck with consistency printing straight to glass and spend a lot less time cleaning and resetting the end stop.
February 07, 2016 11:36AM
UltiFix
Mach
animoose
UltiFix
Why?
[prntscr.com]
Sent you a PM
