Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 03:55PM |
Thanks!Quote
Bert3D
UltiFix
So the last number (90) is the extrusion multiplier?Quote
marc2912
Bert3D
marc2912
UltiFix
What about 90 vs 100Quote
marc2912
jag
My FolgerTech 2020 i3 printer was working great except for 2 issues. Prints were 4% short on the Z-axis, and on some prints it was clear that filament volume was too low. I fixed both my changing DEFAULT_AXIS_STEPS_PER_UNIT in configuration.h
Here's my question: Why does the firmware on the FolgerTech Google drive have these settings: {80,80,3840,90} ? My printer works much better with what seems to be 'normal' settings {80,80,4000,100} for this printer design.
I have this resolved, just curious about the settings published on the Google Drive
It seems that FT had a bad value for the threaded rods hence the issue there, it's been a reoccurring topic on this thread. 4K is correct.
If you really tune everything the numbers won't be 80, 80 4000, 90 anyways, it could be he actually tuned his printer accordingly.
Actually after tuning my extruder the E steps was 100.89, so it is pretty close to the calculated 100 steps. I'm not sure why 90 either.
I'm closer to 110 but I think my extruder gear has a low spot in and it skips a tiny bit every revolution. looking to change it out.
Not the extrusion multiplier, but the extruder steps per mm. The extrusion multiplier is something you set in the slicer, and increases or decreases the amount it tells the extruder to extrude.
The steps in the firmware tell it how many steps your extruder stepper motor requires to extrude 1mm of filament.
The steps in the firmware configure the hardware. The extrusion multiplier is for tweaking specific prints that may need more or less extrusion, or for compensating for filament that is thinner or wider than 1.75, etc.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 04:24PM |
UltiFix
Thanks!Quote
Bert3D
UltiFix
marc2912
Bert3D
marc2912
UltiFix
marc2912
jag
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 05:00PM |
I change the firmware with every new roll of filament. There's no way to tell how much an individual roll is going to be crushed by the feed gear, therefore changing the effective radius, and feed length.Quote
jag
Thanks Everyone. I figured this had been covered before, but apparently my search and Google-Fu skills are lacking. Overall I'm pleased with FolgerTech product and support (they quickly sent a replacement for broken part), but I agree that it would save a lot of time to have the correct configuration.h settings and a single google drive.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 06:42PM |
flatlander
jag
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 08:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 08:14PM |
marc2912
flatlander
jag
Wouldn't it be easier to use the multiplier in this case, I change rolls pretty often depending what I print, flashing the firmware every time seems a hassle. I just write the multiplier on every roll after I check it.
Do all the maths follow if you change the multiplier? If I change the filament diameter to 1.778 is that part of the equation if I just change the multiplier? Or ask yourself what would Thomas Sanladerer do? ha, ha, ha. |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 08:43PM |
UltiFix
I have my bed running at 100c, my printer is fully enclosed, and my hotend is at 240. and im STILL experiencing corner warping! That is annoying.
1. Could printing at 60mm/s cause it?
2. Could not high enough bed temp cause it?
3. Should I print with a brim? I just hate to print with a brim because then it takes me like 2 minutes to clean it up.
4. Maybe I should recheck my z offset.
5. Is there any way to verify that auto level is working?
6. Should I still have my bed somewhat level even with auto level?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 08:49PM |
Mach
UltiFix
I am guessing you are printing with abs? If you are printing your first layer at 60mm/s, that is kinda fast (for the first layer). Is the nozzle at the proper height when it prints the first layer? If it is too far away, you will have adhesion issues. What are you coating your bed with? What works for pla may not work for abs.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 09:01PM |
Marked up your postQuote
Mach
UltiFix
1. I am guessing you are printing with abs?
2. If you are printing your first layer at 60mm/s, that is kinda fast (for the first layer).
3. Is the nozzle at the proper height when it prints the first layer? If it is too far away, you will have adhesion issues.
4. What are you coating your bed with? What works for pla may not work for abs.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 11:59AM |
UltiFix
Mach
UltiFix
1. Yup! Printing with abs
2. No, the first layer prints at 30mm/s. I only tried one or two print's at 60mm (not the first layer) Im back down to 47mm/s
3. Im not sure, should I check that by running G28, then m114 and lowering my nozzle down untill it says zero and seeing if a piece of paper causes friction sliding it under neath?
4. Im not coating my bed with anything... Never have. I really really would prefer not to, IMO i also don't think it's necessary as in the past I have been fine.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 01:12PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 03:41PM |
flatlander
Does anyone think the Harbor Freight IR thermometers are good enough to detect bed temp irregularities and temp of hotend? I have coupon for this one: [www.harborfreight.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 03:45PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 03:57PM |
iamquestar
Keary123
Quick question for anyone using S3D and an auto leveling probe.
I have my probe working perfectly with Cura/Slicer but since switching over to S3D my prints are off centered. Lets say I place an item in the middle of my bed and slice it, it appears to be in the center on S3D but when the print actually starts it is around 40mm to the right of the center mark. I was wondering if it has something to do with the extruder/probe offsets in the Marlin configuration.h code. I haven't had time to mess with offset settings in the software yet so I figured I would see if anyone has had a similar problem.
Also TheRippa, I finally scrapped my bowden extruder and switched over to your TinyFlex Extruder, it is working amazing to say the least. I also remixed your design to fit a 18mm OD capacitance sensor. If anyone wants the files let me know, the sensor is working great with my glass/pei print bed, it is linked below.
Thanks for the help.
[www.amazon.com]
I'd love to get those files. I've been very frustrated with the bowden (I just can't get the right retraction settings). I'm ready to go back to direct, and have a 18mm sensor.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 04:03PM |
iamquestar
UltiFix
Mach
UltiFix
The method you describe in # 3 did not provide reliable results for me, even though all logic told me it would. I still regularly had the nozzle too close (too far could happen too). I dialed in the perfect offset by starting a print, then measuring the thickness of the skirt (I just got some good calipers with .01mm resolution - you can't do this with a cheap one from Harbor freight). If it came in less (or more) than the initial layer height was supposed to be, then I would adjust the offset, and do it again. Once I was getting accurate first layer height, bottom surface quality was fantastic, and adhesion issues disappeared.
On the other hand, of all the reading I've done, I have not seen anyone recommend abs on bare glass. I had very good luck with a glue stick (although not every glue stick gave good results. We had 3-4 different ones around the house, and the Staples one was terrible)
The other issue could be your bed temp. If the surface is not getting up to temp, but just the area around the thermistor, you may need to bump that setting up.
It may come down to a brim and/or coating the glass...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 05:41PM |
marc2912
Am i the only one that finds the FT belt idler bearing to be utter crap. Mine have split open and spewed grease everywhere, broke and overall are terrible. Going to switch to idler pulley soon, just wanted to get everyone else's opinion on them.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 19, 2016 09:57PM |
flatlander
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 20, 2016 05:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 20, 2016 06:24PM |
marc2912
I'd like to run an informal poll here. I wish the forum had an easy way to run a poll within a thread... Are you running a bed leveling system and if so which?
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 20, 2016 06:59PM |
marc2912
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 20, 2016 07:10PM |
animoose
marc2912
Thanks
Not running a bed levelling system. I slightly changed to bed adjustment screws to make them easier to adjust and added a bolt to the X motor carrier to adjust the Z height. Happy with this.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 21, 2016 07:39AM |
marc2912
animoose
marc2912
Thanks
I find that whenever I remove the glass and clamp it back on I have to relevel, even removing a print of the glass changed my level so that I have to readjust between prints.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 21, 2016 08:28AM |
Thanks and thanks to @ msaegerQuote
tjnamtiw
flatlander
No, IR thermometers are notoriously inaccurate on different surfaces and at different angles. They are OK to measure DIFFERENCES over time when measuring the same EXACT SPOT. That's why they can be used in a factory to check bearings on motors. We put black spots of paint on each bearing and then once a month, shot those spots and plotted the changes. Shooting shiny spots won't work well. More expensive ones will have a switch to go between white and black but still they are not accurate. Look for a surface probe that is either stand alone or can be hooked to a multimeter. Ebay......
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 21, 2016 10:51PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 22, 2016 04:25AM |
DaveA
Has anyone else had issues with the stock Folger extruder drive gear becoming worn? I've had my printer for about 2+ months and have run maybe 21/2 spools through. 1 spool PLA, 1 spool PETG and a bit of ABS. In the last week or so I've noticed a lot of clicking from the extruder and the prints are becoming pretty bad. Examining the gear shows there is hardly any "tooth" left. They are all worn down to the point the gear almost feels smooth. Are these gears considered expendable items? They are advertised as being made from copper which doesn't seem be a good gear material for long term use.
marc2912
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 22, 2016 07:34AM |
DaveA
Any recommendations on a good replacement direct drive extruder that supports mounting the BLTouch sensor?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 22, 2016 08:38AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 22, 2016 08:46AM |
flatlander
Is there any reason not to use a stainless feed gear as a replacement? By the way, thanks for the heads-up.
[www.amazon.com]
Folger Tech sells a replacement described as steel.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 22, 2016 09:23AM |
marc2912
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 22, 2016 10:03AM |
marc2912
flatlander
[www.amazon.com]
Personally I wouldn't order anything other than the printer on FT's site. They're a great starting point but past that their prices and quality are not really competitive.
As for getting a new one look at products with reviews and remember to re run calibration on your extruder after. Also make sure you get the right gear for the right extruder.
