Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 10:04AM |
flatlander
SgtRauksauff
Hmm.. looks like I got one SK10
SK10??? Is there anything on our machines at 10mm? Beer can shim? Assuming that rail support, center point, is at the same height, probably not.
tjnamtiw
It seems in the last six months since I got my 2020 that no one at FT has figured out how to properly calibrate their printers and print the bearing holders to the correct dimensions! NONE of my bearings fit the supplied parts and a lot of grinding, cutting and cussing was needed. This week after cutting my teeth on a roll of black PETG, I set the extrusion mulitplier to get the width called for in the GCode, printed the FT .stl files and the bearings snapped easily into place. If I wanted or needed another 2020, I wouldn't hesitate to buy an FT but I'd print my own printed parts since FT seems incapable of doing it. Sorry but the truth sucks sometimes.
PETG is cheating a little, less shrinkage Call it as you see it. I can't wait to test out PETG.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 11:15AM |
tjnamtiw
flatlander
SgtRauksauff
tjnamtiw
I
True, but why wouldn't FT know the shrinkage of ABS and compensate? No excuse from a manufacturer of the product! My guess is that they intended to print the parts in PLA but then got some experience with ABS and just printed them without compensating for the shrinkage factor.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 12:27PM |
flatlander
tjnamtiw
I imagine that they had someone, barely competent, print piles of parts and they are stuck getting rid of "printer kits" at $280 that they wanted to sell closer to $500. I can't even get Lowes to cut glass within 1/4" of the proper dimensions. It's hard to take for someone who thinks 0.003" is too far off I rarely purchase anything, anywhere, that doesn't require some type of modification. The inflation in prices would be too great if, I wanted things made right. So, I go to big box store and purchase low quality junk. If I want it done right I do it myself.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 05:20PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 05:49PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 08:37PM |
marc2912
Anyone else having issues with their display...
This will happen during a print, I'm normally printing from SD card and that doesn't interrupt anything, just lose functionality of the display. When the print is done removing the SD card will reset the issue. It's not the card itself as it happens even when I print via USB....
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 08:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 09:07PM |
Fiddleback
Hi, first-time poster here.
Finished assembly of my 2020 i3 yesterday, and I'm trying to put plastic down. My hotend has no problem getting up to temp, but my glass plate won't go above 108.5 C. I do see the heat board slightly bowed, so I do plan on remedying that tomorrow. In the meantime, would a 7 degree heat deficit be enough to prevent a print from starting? I have successfully tested X, Y, and Z through their full ranges, and I have successfully pushed PLA through the hotend through manual settings. Would anything else obvious prevent a print from starting? I'm guessing these questions have been answered a hundred times here, so linking the pertinent threads would be fine with me.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 01, 2016 09:10PM |
Fiddleback
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 02, 2016 09:10AM |
Fiddleback
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 02, 2016 12:44PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 02, 2016 01:43PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 02, 2016 06:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 02, 2016 06:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 06:01AM |
Fiddleback
Anyway...
I've managed to get a first layer down on glass, but it seem that my Z axis isn't moving, and extrusion stops after the first layer. What should I be looking at to remedy this?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 12:16PM |
SgtRauksauff
Well, the electronics side of things seems to be going ok so far. changed a couple lines here and there, and the RepRapDiscount 2004 LCD controller seems to be working. I connected the thermo sensors for both the extruder and the bed. I have the extruder assembly on my desk right next to the coiled up bed sensor wires, and the bed sensor is reading 2-5°C more than the extruder. Is it normal that they would be a little different, and is there a correction to apply in the firmware?
#define TEMP_SENSOR_0 1 // tried 8 beta; 1 was used in theRippa/Marlin V 1.0.2 stock; 6 was Folger Tech Stock #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1
SgtRauksauff
I looked around, an maybe I'm just blind, but is there documentation showing What information is being displayed?
I assume the first line when it says 20/0° it means that it's currently 20° and the setting is 0° (because I haven't loaded anything)
xyz coordinates are a no-brainer.
FR 100% - not sure what they mean by FR. SDCard percentage full? is that a 'clock' symbol, so time elapsed or remaining of the job?
SgtRauksauff
And yet another question.. Is there a documented limit to SDcard size anywhere? I see some places say to use a 1GB or less with FAT16 format, and others using more.. I know with cameras, there was a speed class associated with cards, and certain cameras would only work reliably with a class 10 card, does that play into it at all? Has anyone used microSD cards inside an SD card adapter? I've got a bunch of 16/32/64 GB micro SD cards that I'd prefer to use, since I have them, and know where they are. I think i have a couple 1GB/2GB cards somewhere, but they're really not so common anymore.
replacement SK8 should be here Monday, I might be able to start getting calibrated next week!!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 12:32PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 12:39PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 05:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 05:51PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 09:49PM |
Fiddleback
Okay, having removed the hotend, I can send a manual extrude command, but the motor just turns a fraction of a rotation and then goes back to where it was. Which, I would guess, means that I need a new motor. But the issue of the z-axis still remains.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 10:04PM |
Do you reccomend I buy new belts in advance? Just GT2 off of ebay or amazon?Quote
flatlander
Too soon to tell, but at some point the belt length will be too stretched and the belt teeth won't align with the pulley teeth.Quote
UltiFix
How many spring tensioners do you guys add to your belt before you re tighten it manually?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2016 10:46PM |
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 04, 2016 09:15AM |
UltiFix
flatlander
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 04, 2016 09:40AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 04, 2016 02:15PM |
Fiddleback
All three jumpers are installed on each set. My kit came with all the PCBs pre-installed, but then again, my hotend assembly came mounted upside-down on its motor, so it's probably good that I checked. I haven't checked vref yet, but hardware-wise, everything seems to be kosher. Just got off the horn with Folgertech, so perhaps I will be swapping in a new motor before long.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 04, 2016 05:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 04, 2016 07:12PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 04, 2016 07:22PM |
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1 // needed to switch this from 1 for my setup.
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define INVERT_X_DIR false // changed this // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false // I changed this to true, was false in theRippa
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 04, 2016 07:35PM |
SgtRauksauff
I wonder if it's not the plastics themselves that are off, as they seem to have a closer grouping of measurements overall than the bearings. makes me wish metal filings weren't bad for bearings, otherwise I'd just file down the end of the bearing, it's easier than finding something to trim the plastic...
Anyone know what the tolerance between the plastic and the bearing, as far as how much smaller the plastic can be before it just wont' fit anymore?
