Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 21, 2016 01:48PM |
animoose
Check in case the gear on the extruder is slipping. Sometimes the grub screws can work loose.
Check whether the V-grooved bearing in the extruder is rotating freely. These are quite cheap bearings and can wear out.
Check whether the nozzle is blocked (partly in your case as some filament is getting through). This is a bit harder to see directly, but maybe you can drive some filament through by hand. If you have some fine stiff wire such as welding wire or a guitar string, you may be able to run it through, but be careful to avoid damaging the liner.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 21, 2016 10:47PM |
We need to address the X-endstop problems here, and probably recommend putting it on the left
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 10:07AM |
DaveA
BLTouch Users:
Has anyone else had an issue where the pin will remain retracted after a print is finished and the printer is turned off over night? I've had this happen several times and if I forget about pulling down on the pin the next G28 will crash the nozzle into the glass. I've cleaned the pin several times but I really assume the issue is inside the touch. Once I pull the pin down first thing in the morning it seems OK for the rest of the day so I can't make it happen on demand. Does the hex adjust on the top have any relation to this issue?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 11:54AM |
Cyril
The 156 pages of this thread make me order it as my first 3d Printer
It should arrive next week, hopping that custom fees - I'm in Canada - won't be too much (not idea how much that will be ).
I'm not afraid to tinkle to make it works the right way.
Thanks to [folgertech.wikia.com] it looks like a good start.
There is also some nice stuff here: [www.reddit.com]
But I still have one quesiton:
Is there some details about the left mount of this endstop, I would prefer to mount everything the right way (then print parts to upgrade it).
I also starts to dig around OctoPi that looks gorgeous (and as the printer will be in the garage downstairs, its a must have to check the printing progress IMO).
I hope my kit will arrive with all the pieces and in good shape!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 11:57AM |
Boffster
If you use the google docs build guide linked in the wiki (alongside the original guide or Cyberkni guide) that will tell you to mount the x endstop on the left hand side of the printer instead of the right hand side like in the FolgerTech guide (so it's a 'min' endstop (same as Y and Z) and not a 'max' endstop). You will also need to connect it to the RAMPS board one set of pins over from what the original guide says. This will make a lot more sense when you actually get to this stage during the build procedure. Also make sure to use therippa's Marlin firmware instead of the one FolgerTech provide. You'll also need to change a line in one of the Marlin files. If you go to therippa's github to download his Marlin version you will see the info at the top of the page.
Hope this helps
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 02:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 02:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 02:23PM |
DaveA
BLTouch Users:
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 03:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 08:44PM |
diegzumillo
Hi all.
I read a few pages and did a few forum searches (would really help to search inside specific topics) but I can't find if this has been asked before. I just finished assembling the basic structure (next step would be soldering the heated bed) and I'm feeling a little unsure about the position of the SK8s specifically. The rods and aluminum bed are already in place, should I use that to eye their right position? The manual in more than one stance says "this will be adjusted later" and never really does, from what I saw ahead. I would really appreciate precise measurements of the pieces' positions. The only time there was one it was ill defined; "the vertical 2020s' back have to be 90 mm from the back of the printer." If I use the actual back of the printer it gets way too far when comparing to the pictures, so it means 90 of space between this 2020 and the back 2020.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 09:12PM |
diegzumillo
Hi all.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 10:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 22, 2016 10:28PM |
Cyril
Going through the instructions I notice some stuff:
Same thing with Aluminum heat bed plate [github.com], I think we can attach the LM8UU Bearings under the place and them just slide the all thing when we are attaching the rails [github.com]
Those are tiny things but I think this could make it easier and quicker.
What do you think about?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 23, 2016 06:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 23, 2016 09:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 24, 2016 02:58AM |
flatlander
That's the way I did it too. I also changed the stepper bracket to the opposite side, compared to the build photos.Quote
diegzumillo
edit: For now I just rotated the motor so the wires come through the front.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 25, 2016 07:09AM |
tjnamtiw
DaveA
BLTouch Users:
Don't mess with the hex adjust. Just go into your Starting GCode in your slicer and put the following at the very beginning and it will reset any alarms and put the pin in the proper position.>>>
M280 P0 S160
G4 P5000 : wait for alarm reset to clear
M280 P0 S90 ;pin up
If you are using SLIC3R, you only have to do it once. For Cura, you have to put it in each version of the print setting that you created.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 25, 2016 11:10AM |
DaveA
tjnamtiw
DaveA
BLTouch Users:
M280 P0 S160
M280 P0 S90 ;pin up
Thanks for the tip. I'm using Octoprint so I added the following to the "run after printer connected" script:
M280 P0 S160 ; Reset BLTouch sensor
G4 P1000 ; Wait for alarm reset to clear
M280 P0 S120 ; self test BL Touch
G4 P3000 ; Let self test run a few seconds
M280 P0 S160 ; Reset BLTouch sensor - stop self test
M280 P0 S90 ; Pin up
Every time I turn on the printer and connect through Octoprint the BL Touch will get exercised. Unfortunately there doesn't seem to be a way to test that the pin is actually down before the carriage starts moving down.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 25, 2016 09:52PM |
18:00:42.106 : No start signal detected - forcing start 18:00:44.592 : Jo6?F?J??%?M?y?K?f?*kX?H.,?P|fN?H7obvHa&??'Z]h.?g:}M?VS? 18:05:45.419 : ??
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 25, 2016 10:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 25, 2016 11:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 07:37AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 10:40AM |
jhitesma
Anyone know what could cause my RAMPS to start messing up arduinos?
I use a $9 C.H.I.P (www.getchip.com) as a printer server running repetier-server to control my 2020 i3. Had been working flawlessly for a month, then suddenly last Thursday it shut down with no warning with 10 minutes to go in a print. Since then I've had a pile of problems. I reflashed the OS on the C.H.I.P re-installed rep-server and couldn't get it to talk to my printer. It would appear to connect - but couldn't actually send any commands. I can still print from SD but over USB things are really messed up.
When I connect by USB right to my desktop repetier-host just shows garbage coming from the arduino/RAMPS:
I happened to have a spare RAMPS/Arduino set on hand that I was going to use for the MPCNC I'm printing...and it worked just fine when I hooked it up to the C.H.I.P or straight to my computer.
So I figured it had to be something with my Arduino or Marlin. I reflashed Marlin and still had the same problems. So apparently that wasn't it. Then I swapped the arduino on my printer for the one from the other set (which was working fine) and it's now doing the same thing just giving garbage. I moved it back to the RAMPS it came with and it's giving garbage there now as well, even after reflashing.
So it seems any arduino I connect to the RAMPS on my printer develops some kind of problem with it's USB converter (remember it still prints from SD so the main processor seems to be working ok.)
I still have another spare arduino mega from other projects on hand...but I'm not about to subject it to the kiss of death from my Printer now
Looks like I'll need to order a new RAMPS/Mega combo...but I'm at a loss as to what could be causing this. It doesn't seem likely that anything is physically wrong since I can still reflash the arduinos so the USB-Serial bridge is still seems to be working.
Ok...it gets harder to understand....I'm still getting garbage if I connect the arduinos right to my PC and talk to them with rep-host...but connected to the CHIP rep-server can now connect and talk to my spare test board and the board for my MPCNC...but my original board still won't talk after connecting. And now my RAMPS is acting like it's not getting power but still has 12v on the inputs and the fuses show continuity...but no lights.
This is not my day apparently....
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 12:06PM |
flatlander
It sounds like the mega has some power issue, maybe a faulty voltage regulator on the mega. I have a bad regulator right now and my temp fix is a powered USB 2.0 hub. Is the amperage for the C.H.I.P. power supply up to the task, or does it derive power from the Ramps through the mega board? Some of my old USB chargers are rated way too low in amperage.
Are the MOSFETS on the Ramps Board touching each other?
Anonymous User
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 01:38PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 02:15PM |
awmyhr
animoose
Awesome, thank you very much, I will look into all that.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 04:35PM |
MKSA
I went through quite some pages here and the "building instructions".
I have one question. Is Folgertech a sponsor of this forum ?
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 04:42PM |
animoose
MKSA
Thanks
They are not an official sponsor. The forum thread was started by someone from Folger, but he has not been involved since the very early posts on it, and I think no longer works there.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 06:21PM |
Attach the black wire the remaining – screw/socket on the power supply (the 6th from the side of the power supply closest to the back of the printer assembly). Note: This will cause the extruder fan to run constantly, which will reduce clogs and jams in the extruder.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 26, 2016 09:54PM |
Cyril
From the manual to deal with the fan extruder:
I think the first attempt was to plug the hot end fan to the D9 Connector. Looks like it was an issue (maybe the fan stopped to early when the hot end stopped heating I don't know). But it could be great to turn on the fan only when required (and keep it running for a certain amount of time.
From Polulu schematic [reprap.org] we can see the D8 to D10 connector and on Marlin Firmware [github.com] we can see some variant of the RAMP Board (like EEB or EFB an so on).
And this is actually a feature of the Marlin firmware: [github.com]
So I was wondering if there is a way to plug the FAN to the D9 Connector and let Marlin deal with the FAN power on / off depending on the hot end temperature. If any one already tried this please share your thought.
If the manual state otherwise then, there should be a reason I'd like to hear
