Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 09:50AM |
Cyril
Don't buy that, I ordered a bltouch for 30 bucks (that should arrive soon).
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 09:54AM |
WilberMaker
i have a Folger 20/20 i3 up and running. Wanting the add bed leveling. Found information on setting it up Marlin and the printed servo parts. I am needing some basic information from the start. Can't find an explanation of operation and parts needed. Can someone point me in the right direction?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 10:22AM |
Re: Folger Tech 2020 Auto Bed Leveling May 15, 2016 03:00PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 09:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 09:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 11:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 11:18PM |
Is that a response to my question? Not sure...Quote
Cyril
Yes.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 15, 2016 11:53PM |
UltiFix
Cyril
Yes.
Thanks!
-Ulti
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 16, 2016 08:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 16, 2016 09:04PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 16, 2016 10:10PM |
Cyril
Buy a bltouch that will act as a z stop and allow you to use auto leveling feature
Otherwise the one provided is doing the job for me (still waiting for my bltouch to arrive).
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 09:03AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 09:28AM |
WilberMaker
Working thru my problems one at a time and having fun. Can anyone recommend a good working adjustable Z end stop fpr my folger 2020 i3? Printed out two and not pleased with how they work.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 12:42PM |
WilberMaker
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 12:55PM |
New features:
New HeatBed MK42!
Hassle free PEI print surface
Integrated leadscrew Z axis
Full mesh bed auto leveling
Improved construction
Faster printing and more materials with E3D V6Full
Improved firmware and printer self test
Slicer support including Windows 10
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 02:54PM |
Boffster
WilberMaker
Similar to what Roxy suggested above, when printing a new x-carriage due to a leadscrew upgrade, I took the opportunity to add a small section to the bottom that would take an M3 bolt. Makes it much easier to fine-tune the Z stop position.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 08:13PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 08:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 10:16PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 17, 2016 10:56PM |
So im assuming I connect ground to ground and 5v to the D9 pin?Quote
Cyril
UltiFix
Cyril
Yes.
Thanks!
-Ulti
Yes I put the hotend fan on 12v with a switch this way I can enable the fan only when I'm printing. We could also use others pins to have auto fan for hotend but for now this is how I deal with. And the cooling fan is wired on d9.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 08:42AM |
Toxic0n
1) Shortening the wires. I'm not looking forward to splicing/soldering tens of wires. Is there a place to buy the connectors so I can just cut the ends and crimp the new connectors on?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 09:37AM |
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 10:25AM |
Roxy
Boffster
WilberMaker
Boffster, can you post your source and .STL files for the new x-carriage? I want to print one!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 11:24AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 11:54AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 12:10PM |
awmyhr
So I got the BLTouch and installed it on my FT 2020. Everything seems to work well except one small detail: when I run the G29 for auto level (after a successful G28 auto home), the BLTouch goes into "alert" mode immediately and from there the Z axis only goes up for each of the 9 points. Has anyone else experienced this?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 12:40PM |
Duh, its 12v not 5v.Quote
flatlander
UltiFix
check out:
[reprap.org]
Apologies, if I misread the question or missed the sarcasm.
D9, a PWM, output pin(s) has a positive pin and a negative pin. Isn't D9 12-35V? Most of us are running 12V setups. I think these 40 mm cooling fans are also rated 12V. D9 is controlled by GCode, M106 and M107.
The command M106 S255 would turn the fan on to max speed. (M106 S123 about half speed)
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 12:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 18, 2016 01:18PM |
Cyril
Lucky you I'm still waiting for mine but the tracking number is going nowhere... (it still on a plane for Korea since April 28th)... When did you ordered yours?
