Re: BLTouch sensor Marlin configuration for the 2020 i3 Folger Tech June 15, 2016 12:45PM |
Bert3D
The BLTouch setup is documented in the wiki that is maintained by some of us in this forum.
Scroll down, and you'll find all the necessary config file changes included. You should be able to just post them into your config.
Folger Tech i3 Wiki
If you have specific questions, I can help.
Re: BLTouch sensor Marlin configuration for the 2020 i3 Folger Tech June 15, 2016 05:32PM |
3333dddd
Bert3D
Folger Tech i3 Wiki
Thanks- I am running very stock hardware - only mods have be add-ons like spool holder, better endstops, etc.
Wil ping you if i run into trouble
Re: BLTouch sensor Marlin configuration for the 2020 i3 Folger Tech June 15, 2016 06:28PM |
WilberMaker
I starting this tonight. How far along are you? What holder did you use to get the correct height?
Re: BLTouch sensor Marlin configuration for the 2020 i3 Folger Tech June 15, 2016 06:32PM |
3333dddd
WilberMaker
I am going to be printing both this one
[www.thingiverse.com]
and the source of it
and will see which one fits....but I need to score some ABS, as I only have PLA right now
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2016 07:50PM |
Re: Filament jaming June 15, 2016 09:12PM |
Thanks! I spun the threaded rod up a bit above the head block, then tightened the set screw up good. Then brought it to tempature and tightened the heating element block thing itself.Quote
tjnamtiw
UltiFix
This doesnt happen very often, but lately its happend twice in a row. My filament will jam in the middle of a print, and I can hear clicking noises coming out of the extruder... I noticed filament was jammed inside my hotend, so I just heated the hotend up really hot and pushed out the plastic.
1. Im wondering what causes this to happen randomely?
2. Is it time for me to get a new hotend?
3.A few things I noticed, my hotend seeps plastic, especially when im extruding really fast. When I heat up my hotend to say, 250C its loose, it can be turned both directions easily. Should it be tightened all the way to the right?
I just want to say this printer has been a workhorse for me for awhile now, it prints just fine and has required low maintence. Its probably time to give it an upgrade
The stock hot end will serve you well for quite a while. If it's spinning, the set screw holding the threaded tube is loose or the nozzle/threaded tube junction isn't correct. That tube should be run up several turns above the heat break block so it's closer to the extruder gear and prevent jams. Then it should be run far enough down into the hot end so that when you screw in the nozzle, the nozzle hits it before it bottoms out. You should have a thread or two showing on the nozzle, Tighten the nozzle against the threaded tube, which gives you the seal to prevent any leakage. Retighten when it's way up in temperature again. NO LEAKS and no need for a new hot end yet! Just get it set up correctly.
Re: Filament jaming June 15, 2016 09:13PM |
I went ahead and fixed the stock one, I might upgrade in the future though... Thanks for the advice!Quote
msaeger
UltiFix
I would just get the e3d. You could probably fix old one by replacing the threaded tube with the liner if you want to stay with the stock one. That liner breaks down and you start getting jams especially if you are running at 250c.
For leaking you should heat up the hotend then tighten the nozzle with it hot.
I would actually get the e3d and the titan extruder then you won't get anymore extruder clicking. I think there needs to be some gearing in the extruder to make it work with the motor they are using.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 17, 2016 06:48PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 18, 2016 11:25AM |
Devil Inc
Dan/John. I'm having issues with the side mounted spool. The extruder is 'slipping' trying to pull the filament once it gets tight with the spool. I had a jam because of it. If I can source a piece of 20/20 quickly, I'm going to relocate the spool up top similar to the OG i3 users to see if removing the side load helps. Just an observation I'm noticing. A 6" long piece and a few mounts would work, if my measurements are correct.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 18, 2016 11:42AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 18, 2016 02:38PM |
When I hit the home all button on rep host it homes x and y then does the safehome thing where x and y center then z homes, here is my configuration.h to compare to yours. PLEASE do not just copy mine, its setup specifically for my printer.Quote
Keary123
I finally found some more time to work on my printer. I just switched my autoleveling sensor from the right side of the extruder to the left side. Since the endstop is on the left I can get closer to the left edge of the bed with the sensor hanging off of the bed. But now i am having issues getting G28/G29 to work correctly. Before this autobed leveling had been working for the past three months.
First a G28 X0 Y0 is sent, the extruder moves to the front left position of the bed (this works correctly).
Second G28 Z0 is sent (printer head crash because the probe is not on the bed).
I have safe homing enabled and entered correct probe offset values but this doesn't seem to help.
I am wondering if anyone has figured out how to home X/Y and then move the probe to the right so it can home Z.
Thanks.
Re: Filament jaming June 18, 2016 03:25PM |
What I ended up doing was switching the stripped extruder motor with one of the non stripped z axis motors, then got new bolts to attach the motor to the x carriage, then I used some red loctite and put a bit on the end of the bolts that go into the motor, then tightened it! Lets just say its never gonna come offQuote
UltiFix
tjnamtiw
UltiFix
Here are before and after pics...
Before:
[imgur.com]
After:
[imgur.com]
Unfortanetly mid print (Right after I was excited the extruder was fixed!) my entire extruder fell off of the x carriage. IMO how its mounted is a bad design.
I have had problems with this in the past, the first time I tried to install my extruder the bolt holes were not properly lined up in the 3d printed part and I stripped the motor threads trying to get the bolts in. I swapped the motor with the bad threads to the z axis motor since it mounts with the front holes not the back.(I drilled out the holes abit in the x axis 3d printed piece so I could get the bolts into the motor) So this is the second time my extruder has fallen off! What am I doing wrong? Should I switch this motor with the other z axis motor?
I shouldn't have said this printer has been running reliably for me and I haven't had to work on it. It now wants my attention
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 18, 2016 05:35PM |
UltiFix
Keary123
Thanks.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 18, 2016 06:34PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2016 01:21PM |
Trilithon
Hello all,
I want to setup auto leveling using the stock/factory endstop. My Folger Tech 2020 i3 is bone stock in hardware and software.
I have read 60 - 70 posts in this thread and now I am more confused than ever.
Is there a step-by-step wiki or post I can follow to get auto leveling up and running with what I stated above?
Any help would be much appreciated!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2016 02:16PM |
tjnamtiw
UltiFix
Keary123
Thanks.
Yea, you're missing something in the Safe Homing routine. It should go into the center to home Z, like UltiFix said.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2016 06:20PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2016 06:38PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2016 06:40PM |
msaeger
Matter control has a autolevel thing that doesn't need more hardware. They have you set the hotend to bed gap in a few places then during the print they move the z to make up for your bed being out of level. It would work best if you had the z end stop at the top but it will work at the bottom you just need the end stop set at the lowest point on the bed.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 19, 2016 10:57PM |
Keary123
msaeger
Im using S3D but the issue isnt in the software its in the firmware. marlin 1.6.5 has new code for defining a fixed probe but I am using the probe as my z endstop and autoleveling probe so I am having issues getting the new firmware to work correctly.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2016 10:31AM |
msaeger
Keary123
msaeger
Sorry I should have used quote I was responding to someone saying you needed to add hardware to do auto level. All these problems getting it going is why I have just not tried auto level and I don't really think I need it now anyway. What I would love to have is the feature Prusa was showing on his printer where you can change the Z height during a print.
[www.youtube.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2016 09:49PM |
diegzumillo
Hi all
I have my printer working for a few months already and there is one thing that I could never get rid of. Initially I thought it was z banding so I did all those things people do about z wobble and such. But here is the thing, it's not z banding! I can change the horizontal pattern to different inclinations by varying stuff like extrusion multiplier or the extruder voltage. I came to the conclusion that my extruder oscillates and I have no idea how to fix that. It makes a sound hard to describe; it's very "musical" like a high pitch arpeggio. I would think it to be normal as these motors do make these sounds, but in the case of the extruder the sound's frequency matches the pattern on the surface. Could this be a problem with the gears? or voltage?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2016 09:58PM |
Re: BLTouch sensor Marlin configuration for the 2020 i3 Folger Tech June 20, 2016 10:39PM |
3333dddd
WilberMaker
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2016 07:46AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2016 08:14AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2016 08:22AM |
WilberMaker
I ask the question before and I think I got buried so I will try again. My bed is taking and unusal amount of time to heat up. Around 5 min or so. Tip is heating at the normal rate. I'm running a different Marlin than before, what settings would control this?
// type 8 alternative // NTC 3950 Thermistor parameters // beta:3950 thermistor table for marlin // from: [microfabricator.com] #if (THERMISTORHEATER_0 == 8) || (THERMISTORHEATER_1 == 8) || (THERMISTORHEATER_2 == 8) || (THERMISTORBED == 8) // QU-BD silicone bed QWG-104F-3950 thermistor const short temptable_8[][2] PROGMEM = { {1*OVERSAMPLENR, 938}, {31*OVERSAMPLENR, 314}, {41*OVERSAMPLENR, 290}, {51*OVERSAMPLENR, 272}, {61*OVERSAMPLENR, 258}, {71*OVERSAMPLENR, 247}, {81*OVERSAMPLENR, 237}, {91*OVERSAMPLENR, 229}, {101*OVERSAMPLENR, 221}, {111*OVERSAMPLENR, 215}, {121*OVERSAMPLENR, 209}, {131*OVERSAMPLENR, 204}, {141*OVERSAMPLENR, 199}, {151*OVERSAMPLENR, 195}, {161*OVERSAMPLENR, 190}, {171*OVERSAMPLENR, 187}, {181*OVERSAMPLENR, 183}, {191*OVERSAMPLENR, 179}, {201*OVERSAMPLENR, 176}, {221*OVERSAMPLENR, 170}, {241*OVERSAMPLENR, 165}, {261*OVERSAMPLENR, 160}, {281*OVERSAMPLENR, 155}, {301*OVERSAMPLENR, 150}, {331*OVERSAMPLENR, 144}, {361*OVERSAMPLENR, 139}, {391*OVERSAMPLENR, 133}, {421*OVERSAMPLENR, 128}, {451*OVERSAMPLENR, 123}, {491*OVERSAMPLENR, 117}, {531*OVERSAMPLENR, 111}, {571*OVERSAMPLENR, 105}, {611*OVERSAMPLENR, 100}, {641*OVERSAMPLENR, 95}, {681*OVERSAMPLENR, 90}, {711*OVERSAMPLENR, 85}, {751*OVERSAMPLENR, 79}, {791*OVERSAMPLENR, 72}, {811*OVERSAMPLENR, 69}, {831*OVERSAMPLENR, 65}, {871*OVERSAMPLENR, 57}, {881*OVERSAMPLENR, 55}, {901*OVERSAMPLENR, 51}, {921*OVERSAMPLENR, 45}, {941*OVERSAMPLENR, 39}, {971*OVERSAMPLENR, 28}, {981*OVERSAMPLENR, 23}, {991*OVERSAMPLENR, 17}, {1001*OVERSAMPLENR, 9}, {1021*OVERSAMPLENR, -27} }; #endif
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2016 12:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2016 11:37PM |
WilberMaker
I'm using 1/2" PVC and made a stand behind the printer. Will something like that work for you to you can find some 2020?
Devil Inc
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2016 11:39PM |
WilberMaker
