Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 02, 2016 10:59PM |
iamquestar
Hmm, I forgot that you had mentioned this was only a problem with PETG. So I assume you do not hear the extruder skipping? Unfortunately with the stock hot end, you can't really see the extruder in action. I designed my own mount for the stock extruder and the E3D lite6 for the v-Slot X axis Gantry plate, and the front of the extruder is now open and visible. It's great to be able to see the motor turning, and be able to see if it skips or grinds against the filament. If there was some way to see that, it could help you troubleshoot further...
What about this: Can you manually push the filament through the hot end at the end of the print? It is harder to do this, than at the beginning? If so, it's definitely a nozzle problem. If not, it's got to be something with the electronics, or possibly gcode...
What about your filament path... is there anything that would cause it be harder to feed, as the Z axis raises up? Might it catch on anything, or kink, or bind?
I'm just tossing out anything that occurs to me here...
To be honest I have yet to print with PETG... I do have a roll, so I'll try to break that out this week and see how it prints for me.
I really like the cooler you posted a link to. I've been looking for something to replace my old setup with. I don't have a print cooling fan running right now, because my old one doesn't fit the new hotend setup I'm using. I think I can adapt that one, and I love that it blows from all directions. Maybe I'll try printing that with PETG.
--Andrew
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 03, 2016 12:52AM |
pizzachef
iamquestar
--Andrew
Sorry, you did ask this before and I forgot to answer. I DO hear the extruder motor skipping steps. It makes a clicking noise, maybe one every 0.5 - 0.75 secs. It doesn't do this at the beginning of the print, but when I catch it underextruding, its skipping steps. So this makes me think something is making the filament difficult to push through the nozzle. I don't think its a printer arrangement problem (like filament getting caught), since PLA and ABS print fine. I think its something wrong I have in the slic3r settings, like temperature, speed, or something like that, which is making this particular type of model not print well. I think I'm just going to have to keep trying different settings.
Can I ask, how do you like the E3D Lite6? I've also done the X and Y axis OpenBuild v-slot upgrades and was considering trying a new hot end next. But I wasn't sure how much benefit you get.
The DiiiCooler is pretty good, the guy did a nice job of shaping the internal fins so the air is directed inward and downward, right on the print without cooling the nozzle too much. And there are several adapter plates that people have made for it. There's one for the stock FolgerTech hot end. Mine is printed with PETG and is holding up ok next to the heater block. There are some discolored areas and a little deformation from the nearby heat, but its still good. Easy enough to print a new one when this one melts too much.
Thanks again for all the help.
-Geoff
Re: counterfeit Arduinos August 03, 2016 09:38AM |
av8r1
Arduino publishes an identification guide here: [www.arduino.cc]
The silk screening on the boards received from FT doesn't hold up to scrutiny.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 03, 2016 12:34PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 03, 2016 07:08PM |
mrbill
Bit the bullet, ordered the kit, the 2004 LCD, and the extension cable for the LCD.
I'll either buy a better Arduino and RAMPS (links/suggestions encouraged) before I build it, or expect to have to do that at some point.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 03, 2016 08:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 03, 2016 11:37PM |
My arduino from ft has worked great! Have fun building it and dont rush through it like meQuote
mrbill
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 04, 2016 02:50PM |
UltiFix
mrbill
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 04, 2016 03:00PM |
iamquestar
Two benefits of building a kit are: 1. If somethings breaks, you'll have a good idea of how to fix it. 2. If you want to make improvements, you won't be afraid (as much) of pulling things apart to build them better.
Re: counterfeit Arduinos August 04, 2016 08:47PM |
3333dddd
av8r1
Wow - that is interesting (and helpful to know)
To be fair to Folger Tech, I went and looked at their site, and it states "Arduino Mega 2560 R3 Clone" on the product page, so they are not really hiding that fact.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 05, 2016 10:16PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 06, 2016 05:43AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2016 10:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 08, 2016 01:03AM |
av8r1
So the display works when the USB cable is plugged into your laptop, but not when unplugged. I bet the 5v regulator on your board has gone. I know I harp on that a lot, but it's been a BIG issue with me, and if you do ANYTHING wrong with the machine, that regulator will let the smoke out. There are three ways to power an Arduino: You can put up to 5.5V on the 5V pin (basically don't do that. The pin(s) marked 5V are INSIDE the regulator and meant to SUPPLY power, so if you get it wrong, you can hurt the Arduino and anything hooked to it.) You can put power on the Vin pin or the barrel jack, which then gets regulated by the regulator. Or, you can plug it in USB, which bypasses the regulator because USB is regulated to 5V. If the regulator is blown, the board will work fine when plugged into USB, but not when it's on other power. Look at the regulator and see if it looks like it blew up.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 08, 2016 01:37PM |
Im thinking about doing this, would it work ok with the cura slicer? (new version) I have the money for a Pi 3 but definetly not for the Simplify3DQuote
iamquestar
av8r1
I agree with this diagnosis. If you have a spare usb charger, you can plug the USB cable into that to provider power to the electronics HOWEVER, make sure it is a quality one. Pretty much all of the cheep ones don't have good regulated power. (also, some tablet charges put out a higher voltage (5.1-5.2v) which could cause some issues too).
There doesn't need to be anything on the SD card for it to work stand alone. Just copy your gcode files onto it, then you'll be able to select them from the LCD and print away.
Another option you may want to consider (aside from replacing the Arduino) would be to go with a Raspberry Pi and Octoprint. The printer electronics will then get its power from the RPi thru USB. A Pi 3, good powersupply and case bundle will set you back about $50 on Amazon. I am so glad I took this step. I was quite excited to start printing from an SD card, but that got old really quick. Particularly when I would start a print, and find that I needed to change some slicer settings, so it's pull the SD from the printer, stick it in the reader, save new gcode, pull it out and put it back in the printer, then repeat... Sending the gcode over to the Pi (I have a script that does it automatically as soon as I save it out of Simplify3D) and starting the print is so much easier, not to mention the easy monitoring the print with a webcam from anywhere in the house....
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 08, 2016 04:48PM |
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 08, 2016 04:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 08, 2016 05:04PM |
iamquestar
UltiFix
Octoprint will work with any slicer, you'll just need to upload the gcode generated (very easy: web interface). Further, Octoprint actually embeds Cura (I'm not sure of the version, I haven't played with this yet) and you can send your STL right to Octoprint, and it'll slice and start printing in one step. I'm not sure what options there are for multiple settings profiles, there may be only one set of settings you can use. As I said, I haven't played with this, but it looks promising.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2016 02:44PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2016 05:31PM |
jabu32
Got Octoprint working....LOVE IT!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2016 10:53PM |
iamquestar
I'm ready to share my extruder mount with the world, and will be posting it this week. I've designed it so that the motor sits ABOVE the vslot gantry (more or less), which keeps from having this big weight hanging off the front of the Xaxis, and reclaims some Z height. I have about 175mm of Z height, even with an E3D hotend.
I'm printing the DiiiCooler now, but I'm a little concerned about making it fit. I'll see how it goes. I'm printing in PLA right now, as I have tons of that. Once I confirm fit, and make any needed tweaks, I'll print it in ABS or PETG. I may need to rework the mounting scheme, and scale down the Z a little.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2016 02:01AM |
pizzachef
iamquestar
I still haven't had any improvements with PETG, although I haven't tried everything yet. I still need to try printing even more slowly and maybe turning up the extruder motor driver current. I had some other PLA prints to make, those are coming out well. Incidentally, when I was printing in PETG, I tried a lower temp, 225C, and it started skipping steps during the print. I tried 220C and it still clicked (maybe even worse). I went back up to 235C, still clicked (doesn't click at 225-235 in the first 20 or so layers of the print), so I cancelled it. Then I made it extrude 50mm and watched the filament come out. When the motor clicked, I could see the extruded filament briefly pause at each click.
Seems like the teflon tube is getting soft or sticky when it starts to warm up. Maybe a better cooling fan would help, or maybe the teflon tube is not very good. I'm going to keep trying things.
Did you publish your E3D mount yet for the v-slot gantry? I'm interested!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2016 11:46AM |
iamquestar
jabu32
Excellent! I have really appreciated the ease it gives me, not to mention, I can initiate a print from the bedroom using my phone (I did this last night when I realized I had forgotten to start it).
I also added a relay control module ($7 from amazon) and can actually control power to the printer, and turn the LED lights I added to my enclosure on/off from the octoprint interface. It rocks!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2016 11:57AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2016 01:02PM |
WilberMaker
Is there a better 8" bearing to use than the LM8UU linear bearings. The ones from Folger Tech seem cheep and are rough. When replacing the Z I lose several ball out of them and would like to go back with something better.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2016 01:13PM |
jabu32
iamquestar
jabu32
How do you wire up the relay?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2016 01:29PM |
Thats sick! I also have a led strip above my printer and would LOVE to be able to control the printers power and the led strips! Can you link me to them on amazon? Ill just buy it all together when I order the pi.Quote
iamquestar
jabu32
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 14, 2016 11:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 15, 2016 07:53PM |
WilberMaker
Got my lead screws installed. Having a problem with the steps. Seems that if I raise the x axis 40mm it is actually moving around 10mm. This would say the steps are to low, But when I level the bed and set the offset the nozzle will dig into the bed. Below is my setting for steps. Am I missing something else or is it possible I am binding on the leads and missing steps on the steppers.
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,400,89.839}
WilberMaker
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 15, 2016 08:03PM |
UltiFix
iamquestar
jabu32
