Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 16, 2016 07:30PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 16, 2016 08:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 17, 2016 08:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 17, 2016 11:23PM |
iamquestar
OK, so this has been a long-time promised and an long-time coming. Here's an overview of my most recent work/changes to the printer...
It never ends...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 17, 2016 11:54PM |
pizzachef
iamquestar
Great work! I like the motor/extruder mount. The stock cantilevered motor setup always bothered me, having it over the x-rail seems more balanced.
FYI, your amazon link to the sensor goes to the RaspPi kit instead.
Funny, my longer term plans are also the start building a corexy printer....AFTER I get this one set up the way I like itIt never ends...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2016 01:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2016 02:03PM |
animoose
I moved on from the Folger to an Eclips3D CoreXY. It's better and faster, but it still makes me aware of what a good printer the Folger 2020 is. The key, as with the Eclips3D, is a really rigid frame - get that right and many other things become easier.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2016 02:23PM |
pizzachef
animoose
You're only encouraging me more! But good to know the Folger 2020 has a good standing, I need it to make all my new printer parts
I've got my eye on the d-bot http://www.thingiverse.com/thing:1001065. After changing the Folger 2020 to v-slot rails for the x and y axes, I like the idea of the v-slots over the smooth rods. Although the oil-free bushings for the linear bearings are probably much better than the roller ball linear bearings in the Folger kits, so my hangup might be a bit unfounded.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2016 02:55PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 18, 2016 04:49PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 12:31AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 10:03AM |
av8r1
jabu32
How do I get rid of the waves in the outside layers?
Looks like your extruder driver current is a little high. Check the Vref. You probably want to reduce the current on all of the steppers, they tend to run a little hot.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 10:38AM |
WilberMaker
@ iamquestar - While back do I remember correctly you were waiting on a 120V heated bed, or was that someone else? Jbed?ust ordered parts to go up to a 200mm x 300m bed. With the parts I take out of the FT I also want to increase Z as much as I can. Any recommendations on a bed?
WilberMaker
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 11:19AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 12:45PM |
animoose
pizzachef
animoose
The Dbot is definitely worth thinking about. The designer of the Eclips3D also has a new design he is working on which will use linear guides.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 01:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 01:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 04:25PM |
WilberMaker
I am printing blue PLA. nozzle 210deg Bed 70deg and no cooling fan on the part. The bottom couple mm of the part is darker than the rest and is squeezed out like the part is melting. Printing on blue tape and it is almost impossible to get the part off the bed when complete. Is it a bed temp problem, nozzle offset or first layer settings? Can not seem to find the right combination. Rest of the part looks fine and the dimensions are good.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 19, 2016 09:33PM |
WilberMaker
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 20, 2016 10:24AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2016 02:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2016 02:55PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2016 05:57PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 21, 2016 10:46PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 22, 2016 05:34AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 22, 2016 05:35AM |
UltiFix
My cooling fan doesnt spin up at 50% (It does if I manually spart spinning it). Is there any way in the firmware to peg it at 100% 24/7?
This is a print cooling fan - Not the extruder hetsink fan.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 22, 2016 06:57AM |
ACoffin
Hey, is anyone else having problems with the FT 2004 LCD display? Mine just shows gibberish (I have attached a picture), and I can't figure out if the display is defective, if it's a problem with my firmware, or if it's something completely different.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 25, 2016 09:13AM |
WilberMaker
Did you load the U8glib library? I had a couple versions of Marlin do this on me. When I found the correct version the display worked without having to make any setting changes or turning anything on.
ACoffin
