Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 06:04PM |
JoeH
The guide doesn't talk about doubling the voltage for the Z motors. But from what I understand, the voltage that you set is not the voltage that drives the motors, but it corolates with the max current to the motor. The tuning doccument gives you the formula to calculate it. If you look at the motor specs, one said its rated at 12V and the other at 3V. I think the 3V is per coil? But regardless, I don't think these motors would run at 0.16V!
As far as the Z motors, they are running in parallel, so they run at the same voltage, but require twice the current coming into the circuit so each one can draw its required 0.4A... They are essensially set up as a current devider circuit. Another way to think about it is if 1 motot requires X watts to run, then 2 motors will require 2X watts to run off of the same wires.
JoeH
And Power = Volts * Amps, you're going to have to double something.Since the only thing we can adjust is the max current, then thats the one thats getting doubled. If the motors were in series, then this would not work since they would need twice the voltage (voltage devider circuit)
That's why I think the voltage (max current) needs to be doubled.
JoeH
But then again, I'm not and electrical engineer, so I could be wrong!
though I haven't gone through the tuning info and formulas you posted. Can you post a link to the original doc?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 11:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 12:32AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 01:52AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 11:41AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 01:48PM |
Nuk3d
So I found this kit the other day and I've been curious if it's any good. Like, are the quality of prints good for it being sub $300?
I've been wanting to get a printer and this sounds like it's a decent choice..
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 06:20PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 08:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 08:29PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 09:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 11:08PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 11:20PM |
I switched over the stepper driver but somehow in adjusting it, I shorted something. There was a short "crack" and Repetier no longer talks the board. Not sure if I blew the RAMPS or the Mega, or maybe the regulator on the Mega, which I've heard is a common failure mode. So now I need to put things on hold for a while, until I get a replacement or figure out of there is something fixable.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 13, 2015 11:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 12:34AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 12:45AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 01:05AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 10:27AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 10:37AM |
RRuser
Question about the Folger and other kits: It seems the most common initial problem is endstops being backwards, etc. If the kit is pre-packaged with the initial settings, why does everyone (on every kit, not just Folger) always have to figure out which way things go?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 02:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 04:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 04:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 05:41PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 07:12PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 07:25PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 14, 2015 07:43PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 12:25AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 09:41AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 02:00PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 02:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 15, 2015 08:30PM |
