Folger Tech 2020 i3 Printer Kit (Official Thread)
Posted by Dan_FolgerTech
Re: Folger Tech 2020 i3 Printer Kit (Official Thread)
January 03, 2016 02:11PM
Im having problems with the manual control. Whenever i click "Home" on the X axis, the extruder moves all the way to the left until it hits the side of the printer and it tries to keep going unless i stop it. Also, I tried just to print a cube, and it did the same thing. Any pointers?
January 03, 2016 04:14PM
cookg
Does it stop when you home and then manually press the endstop? If it does, does it move in the right direction when you manually move it in repetier after you have homed it?
January 03, 2016 10:46PM
I got that sorta straightened out. Now I have some new problems. First, my print came out squished lengthwise (I was printing a cube but the raft started like a rectangle) AND when I stopped it, I noticed some red LEDs flashing on my ramps board. When inspected closer, I noticed that one (only one) of the transistors (I think it was a transistors) was almost too hot to touch. If the board is messed up, I can always buy a new one. What's wrong with it now?
January 04, 2016 05:47AM
cookg
Red LEDs flashing on the ramp board is normal and some components will get hot, sounds like your configuration might be messed up and it's not taking as many steps as it should on one of the axis.
January 04, 2016 12:57PM
FT Upgrades...What's Next!?!?
With my Y and X Axis upgraded, E3D hotend, and Bowden Extruder (my preferred extruder), I honestly believe my printer is about as good as it's going to get mechanically. I am running S3D so the slicing software is good to go as well. So I'm assuming the next logical upgrade would be the Electronics - Control System!?!?
Is anyone running an alternative control system on their FT printer?
Smoothieboard, Duet, Rambo, it's a long list so I'll stop there...
What do you guys think...is a control system upgrade worth while!?!?
January 04, 2016 02:18PM
sonnylowe
I thought a bit about going to Smoothieboard. I like that you can adjust the motor setting in the config - no more messing around with the pots on the drivers. I've heard that the printing is sometimes smoother as the CPU on the board is much more powerful so it can go better conversion of the gcode into the specific signals sent to the motors, but I don't know if this is true. Most people who advocate for Smoothieboards and other controllers are using Delta printers where you have a lot more on-the-fly computation to do.
Is it worthwhile? I don't know. I couldn't quite convince myself, as my printer is fine for pretty much everything I need to do with it. The same goes for your X and Y redesigns - they are great, but I've haven't had quite enough problems to make the change.
The one thing that does still bug me is that my Z axes get a bit graunchy higher up. You can hear clunking noises and the alignment starts to go off. I think this is probably due to slightly miscut acrylic mounts, as someone mentioned a few pages back.
See my blog at [moosteria.blogspot.com].
January 04, 2016 05:43PM
Ok I think I am ready to add auto bed leveling to my rig. I printed the new carriage with the servo at the bottom and have a servo to go there, where do I plug the servo on the Ramps board? I moved the endstop to the left side and got all the running the correct direction.
January 04, 2016 07:26PM
sonnylowe
Greedy noob speaking...I plan on doing several of the upgrades you've designed/done to my FT. For all us new guys, it'd be cool if you (and everyone with lots of time with these) would add a link in your signature to your current setup or a quick list of the mods you've done. Pretty please?
EDIT: Simplify3d profiles/setups would be great too! smiling smiley
Edited 1 time(s). Last edit at 01/04/2016 07:32PM by GrouchoDuke.
January 04, 2016 08:54PM
Hey. I hope this is my final question post. For some reason, my extruder won't heat up. Then, if I fiddle with the thermoresistor connection (to the ramps board) it will start heating to about 60 degrees, then cool back down again. How do I fix this?
January 04, 2016 10:18PM
cookg
Look at the log in repetier and see if it is giving you decoupling errors.
January 04, 2016 11:45PM
WOOHOO! Got my first print! But, another problem. I was looking at an instructable for calibration, and when I type M501 into the gcode bar (In Repetier), in the log it will just say "ok"
How do I get it to show the code I need?
Here's the instructable for you to look at:
[www.instructables.com]
January 05, 2016 12:13AM
If I remember correctly you have to comment eeprom chitchat in the firmware for that to work.
January 05, 2016 08:15AM
Just wanted to put a positive post up as naturally a lot of the posts here are only when there are problems...
Finished my build last night and everything seems to be working correctly!
Have checked everything using manual controls in Repetier and all seems good! As a starting point I set the X, Z, E drivers to ~0.370v and Y driver to ~0.550v. X endstop on left hand side. All axes home correctly and move in both directions. Have heated bed to 40c, extruder to 80c and both seem to be working (hot to the touch, temperature reading rising in Repetier). Extruder motor turns when instructed (enabled cold extruding to test motor). I also installed a 12864 LCD controller and it's reporting the same info as Repetier and I can navigate the menus, although I haven't tried to control the printer using the LCD yet.
VERY HAPPY!
Still have a few things to do tonight (tweak endstops, possibly tweak drivers, calibrate). Then I can try printing something....
Some things to note for others about to build/order:
I used both the FolgerTech build guide and cyberkni's build guide (from folgertech subreddit). All steps referred to below are from the FolgerTech guide.
  • There is a step missing in cyberkni's guide (Step 13 in the FolgerTech guide) which is constructing the front pulley for the Y axis belt.
  • The cyberkni guide suggests ordering M5 x 10mm bolts as the M5 x 8mm bolts supplied are too short. My order came with these already replaced (10mm bolts instead of 8mm bolts).
  • In the end I only used the top 2 bolts for attaching the Z axis motor mounts, otherwise the vertical smooth chrome rods would NOT be parallel (Step 16).
  • I attached the heated bed wires the correct way round according to the RAMPS board (the opposite of what Step 21 says) - red to positive terminal, black to negative. This shouldn't matter but it was annoying me.
  • I mounted the X Axis End Stop on the left hand side of the printer (Step 23.6) - you may need change the way the End Stop is attached to the mount so that it functions correctly.
  • My thermistor wires came with the molex connectors already crimped. (Step 22).
  • There was one step where some nylock nuts were asked for but 3 (I think) were not used.
I used therippa's Marlin firmware.
There were no missing parts and I had plenty of spare bolts/nuts/washers etc.
All electronics are working correctly (as far as I have tested). A few pins were bent on some of the boards but were easily straightened.
Ordered middle of November and received it a couple of weeks later (to the UK).
Hopefully this post will reassure anyone about to build or order this printer!
And finally a massive thanks to all the kind folk on here offering advice and assistance. All your posts have been a massive help!
January 05, 2016 08:39AM
sonnylowe
Z Axis now winking smiley
January 05, 2016 09:04AM
animoose
sonnylowe
Thanks for the input. I just upgraded my X Mounts (again ;-) and I am incorporating anti-backlash into the setup. once I get a few screws in the mail I'll post the results.
January 05, 2016 09:09AM
built350camaro
The servo plugs into the ramps board at the top (as installed-bottom in photo), just to the left of the reset button and power strips.
Make sure you add the jumper required to power the servo pins...
January 05, 2016 09:19AM
GrouchoDuke
sonnylowe
As soon as I have time (and they are finalized them) I'll be posting the X-Y upgrades on Thingi, along with a few other designs.
I think adding current mods-configurations to our signature is a great idea, and it would help people find there way much easier.
As far as S3D profiles, I change mine on the fly depending on what I'm printing...I don't save different profiles, I only have two...one for single extruder and one for duel extruders. I'd be happy to share those base profiles though.
January 05, 2016 09:39AM
peeejayz
sonnylowe
Working on it smiling bouncing smiley
January 05, 2016 10:26AM
sonnylowe
peeejayz
sonnylowe
Awesome my Y Axis parts are awaiting collection from the postoffice so I'll be installing that this week grinning smiley
January 05, 2016 12:01PM
Hi all! Just finished building this. The build was a fascinating exercise in engineering but I thoroughly enjoyed it! I'm waiting on my ABS and glass build plate to arrive but, in the meantime, couldn't help but steal a picture frame glass and print with the sample FT PLA. I'm extremely pleased with the results! I'm excited to further dial it in. In order to become more familiar with the firmware I decided to just download the vanilla latest version of Marlin and set it up myself. It wasn't terribly difficult and my first prints were well beyond my expectations.
A few notes:
  • I built it right off the bat with the x endstop on the left to be consistent with the standard Prusa i3 design.
  • I also tuned the stepper drivers by "feel", if you will. I turned them down until they were skipping and then slowly turned them back up until they worked reliably. This also quieted them down quite a bit.
  • For calibration I leveled my bed and set up the e-steps for the axes using the standard calculations. For the extruder e-steps I tested it empirically using the 100mm extrude method.
Printed at 180C and 0.2mm layer height.
[imgur.com]
[imgur.com]
Edit: Removed img tags since they weren't working (size constraints?)
Edited 1 time(s). Last edit at 01/05/2016 12:02PM by kbarnette.
January 05, 2016 12:10PM
sonnylowe
I think the control system is fine. I like the idea of the rambo, but it seems unnecessarily expensive. You know what I'd like to see? An enclosure grinning smiley
Need help? Visit the Folgertech Wikia Page
The latest Marlin firmware with Folgertech Prusa i3 settings merged in, get it here
And check out my designs on Thingiverse, and follow me if you like what you see!
January 05, 2016 01:28PM
Just printed my first two 20mm calibration cubes and I'm pretty amazed at how well it went. I did a totally stock build, using the included bearings and hot end.
For anyone as new to this as I am (read: totally new), I took my time on the build and found Charles Platt's book (Maintaining and Troubleshooting You 3D Printer) as well as this forum to be great resources. I followed Platt's calibration advice, and mostly the settings in the files on the Folger Prusa drive were good, though I had to alter the extruder steps/mm a bit.
One question: My cubes are about 5% small in the Z direction, and the roofs tend to sink down a bit using a 10% honeycomb fill. Folger blue PLA at 220 degrees. Is the sinking something that would be helped by a cooling fan on the PLA, or maybe a slightly lower extrusion temperature?
thanks
January 05, 2016 02:02PM
jcantalupo
thanks
220C is too hot for PLA. I had a similar issue. Try something more like 190, maybe 195 or 185.
January 05, 2016 02:27PM
therippa
sonnylowe
Haha, my latest version of the X Axis mounts (which are much smaller and compact) were designed with that very thing in mind winking smiley
January 05, 2016 03:14PM
OK, I read the entire thread, for other noobs it starts getting more informative (ie. less complaining about quality and shipping) in the page 30's and beyond. However, there is good information in the first 30 pages as well. There is one thing I do not recall seeing mentioned. If one plans to use the LCD, is it better for any reason to consider power up and downloading the programs in the configuration section before attaching the LCD? As opposed to connecting the LCD and then doing the SD card to get started? I have the build completed and have x end stop on the left, so left front corner is home. The build was very fun. Still need to get glass plate and sd card then on to configuration and power up.
Thanks
Jim
January 05, 2016 04:17PM
sonnylowe
built350camaro
What he said! Are you using the carriage that I put on thingiverse?
I had a 5v regulator around - I powered the '5V' pin pictured with its output, it's the 5v pin next to the PS_ON pin, that powers the servos. The 5v bus as-is won't be able to handle the Servo if you try to power it without help.
Edited 1 time(s). Last edit at 01/05/2016 04:18PM by srcga.
January 05, 2016 05:29PM
jcantalupo
thanks
Yea, 220 is way to hot for PLA unless you are REALLY moving fast. Set 190 for the first layer and 185 for the rest with speeds around 40mm/sec. First layer at 1/2 speed and 150% extrusion. Use 15 or 20% infill and it will support the top better. Put 3 layers on the top.
January 05, 2016 07:51PM
sonnylowe
Awesome, that sounds great. I'll watch for your stuff on Thingiverse.
Since I don't have a printer yet, I'm going to start with just getting the stock printer going. Hopefully mod-time will come quickly.
Thanks!
January 06, 2016 03:13AM
So I took a nice benchmark tonight before I start my Y axis upgrade. I think it came our pretty well and is my first attempt at my Marvin.
January 06, 2016 07:08AM
Jim72
Thanks
Jim
Hi Jim, I have the LCD and connected it to the printer first, then I connected to the printer/Arduino via USB (with the printer powered off) and flashed the firmware. Then I powered up the printer after the firmware had finished uploading and connected with Repetier to test the axes. I haven't tried to print from the SD Card yet, but the menus work fine and the main LCD info screen is updating and displaying the same info as Repetier.
Hope this helps.
