Re: Folger Tech 2020 i3 Printer Kit (Official Thread)
November 10, 2015 09:24AM
msaeger
[The E3D Lite6 I upgraded to does not leak at all not yet anyway smiling smiley It actually will start putting down material right when the print starts because it all didn't leak out while heating up like the Folger one would. Defiantly was a good upgrade.
What modifications are required to switch over to this hot end?
Does the extra length of the heat sink take away from the vertical printing area?
Edited 2 time(s). Last edit at 11/10/2015 10:52AM by TollBoothWilly.
November 10, 2015 11:58AM
So.... what a night.
[imgur.com]
I made it all pretty to only plug it back in and 1 Z motor not work. Ordered new parts only to wake up and check the wires on the cable were cut. All fixed.
Auto leveling question.
My bed is 220 x 220 b/c i can use the full bed. (No glass)
I run G0 X0 Y0. I then run G29 for auto leveling. Then sensor goes straight down no matter what I put in
#define LEFT_PROBE_BED_POSITION 33
If I run G28 the sensor is in the middle of the bed. G29 after and it does not go to the corner.
Do you run X0 Y0 or G28 before G29?
hmmmm
November 10, 2015 12:11PM
TollBoothWilly
msaeger
You just need to print the new mounting block. Make sure the mounting block is mode for your extruder version or you will be taking it apart again like me.
I didn't lose any height because I mounted the motor to the Y carriage into the lower holes like animoose suggested.
[moosteria.blogspot.com]
Newbie with Folgertech 2020 i3.
November 10, 2015 01:59PM
Yelloow-Snow
[imgur.com]
hmmmm
What does it do after you run G29?
Need help? Visit the Folgertech Wikia Page
The latest Marlin firmware with Folgertech Prusa i3 settings merged in, get it here
And check out my designs on Thingiverse, and follow me if you like what you see!
November 10, 2015 06:21PM
Yelloow-Snow
[imgur.com]
hmmmm
Any link to the bracket you used for the sensor and also any problems heating a alu bed, I guess your running the stock heater?
November 10, 2015 06:33PM
Slaghton
Ah thanks, not sure how I missed those stl's. I downloaded some other batch. I saw your modification thumbs up. I might have to look into it if it reduces vibration/increases print quality =).
P.S. For people talking about Y axis vibration sound. My plastic bearing holders having their screw holes getting stripped so the bed isn't fastened securely is causing a loud vibration sound. Printing 3 new ones since I can still print pretty good.
The bearing holders take bolts and nuts, not screws. They should have through holes, not threaded holes. There shouldn't be any stripped screw holes.
I found that I had to enlarge the holes in the aluminum plate so that the bearing holders would be in alignment with the chrome rods and not cause binding and premature death to the bearings.
Edited 1 time(s). Last edit at 11/10/2015 06:41PM by tjnamtiw.
November 10, 2015 06:37PM
Slaghton
Here's my most recent print even with my heavy vibration for my bearing holders being loose.
(the band artifact was caused by me pressing my finger lightly against a rattling bearing)
Nice print!!! I just order two spools of Hatchbox on different colors so I can split my prints on multiple parts and colors!
November 10, 2015 07:22PM
I feel like I have my prints mirrored. My Y-endstop is a "max" and it is located at 200mm at the back of the printer.
I have found this drawing online, do people agree with this? [www.lincade.org]
Also could you post your lines from Configuration.h where the endstops, direction and invert are defined?
Thanks
November 11, 2015 06:08AM
Uncertainty
Thanks
The drawing is correct as far as showing the coordinate system, it is not intended (or at least I don't think so) to show travel direction. It does not appear to show the Y endstop correctly. Keep in mind that when the bed is all the way back (hitting the endstop like the drawing) the hotend is actually at the front of the bed, the Y-0 position...so your Y-enstop needs to be set to "min". The arrows are there to show coordinate directions, not travel directions, although they coincidentally show the correct travel direction for both X & Z, that is not the travel direction for Y, it is the Y coordinate direction.
As far as Confg.h, check out "therippa" sig for his Marlin link, he's got it going on and most of us are running some variation of his confg.h setup...
Hope this helps :-)
Edited 1 time(s). Last edit at 11/11/2015 08:27AM by sonnylowe.
November 11, 2015 04:20PM
Uncertainty
Thanks
If your Y endstop is at the back of your kit then it is in the "min" position. This is because the software is using the position of the hot end as it's reference, not the position of the bed itself (aka moving the bed to the back of the frame brings the hot end to the front of the print area or the min position in this case).
Change your configuration.h file to match below and see if it fixes the mirroring issue:
#define INVERT_Y_DIR true
#define Y_HOME_DIR -1
Also, make sure that your Y endstop is plugged into the correct set of pins for the min position (5th from the left)
In Repetier set your Y home position as min
If your prints are still mirrored after making that change then it is likely the X axis that is inverted. In this case make the following changes:
#define INVERT_X_DIR false
#define X_HOME_DIR 1
Connect the X endstop to the pins for max position (6th from the left)
In Repetier set you X home position as max
I had an issue with inverted prints and the above setup took care of it for me, so let me know if it doesn't work smiling smiley
Edited because I should probably read the post directly above mine before replying (sorry for the duplicate Sonnylowe)
Edited 2 time(s). Last edit at 11/11/2015 04:33PM by Smuggler17.
November 11, 2015 05:22PM
Is anyone else starting to have problem printing now that the weather is getting colder? It doesn't get very cold in San Francisco, but my printer is right next to a window and I've been having warping/layer separation issues. It may be time to resurrect the idea of building an enclosure...
November 11, 2015 05:28PM
therippa
Nope tho its still warm in Louisiana. that and my large reef tank in the room keeps it hot.
Maybe PID Tuning again when the weather changes?
November 11, 2015 05:31PM
therippa
Oddly enough, I have noticed this recently, though I also started a new roll of filament which seems to have some different characteristics to the previous one. I'm in LA and we're definitely starting to feel the brutal Southern California winter kicking in this week.
See my blog at [moosteria.blogspot.com].
November 11, 2015 07:27PM
I am trying to print this thing.
Turtle
On the first layer, there are 14 little circular contact points. I can't seem to get them all to stick to the bed.
I have tried turning up the bed temp and the extruder temp as well as increasing the first layer thickness and width and printing the first layer slower.
I just can't seem to get them to all stick.
Any ideas?
November 11, 2015 07:49PM
animoose
therippa
Another potential theory is that this spool has been sitting out for a while and it has picked up quite a bit of humidity.
November 11, 2015 11:01PM
Smuggler17
Uncertainty
Thanks
Thank you Smuggler17 & sonnylowe
My problem was that I was so focused on the software that I forgot to change the connector on the RAMPS board lol...
November 12, 2015 10:35AM
Uncertainty
Smuggler17
Uncertainty
Thanks
Haha, it's always the simple stuff that gets us ;-)
November 12, 2015 10:45AM
Yelloow-Snow
therippa
That was a good idea my stuff wasn't sticking as good so I ran auto tune on the bed again and it's sticking much better.
November 12, 2015 11:57AM
msaeger
Yelloow-Snow
therippa
Awesome! Maybe run it on the extruder also? :: shrug :: I'm still a noob.
I ordered a new hot end. Going to do Bowden but i want to do something different. I want to mount the extruder right above the hot end on the top rail. Reduce the distance and keep the weight low on the X axis. It will feed it straight down.
hmmm Why hasent anyone else done this?
Also... after hours and hours of work here is my S3D starting script.
I unchecked "Wait for temp to stablize before beginning build" This allows me to auto level with 16 points while the bed is heating up.
Also things to note: I disabled the checkbox "Relative extrusion distances" and "Update firmware configuration"
Still confused why I have to G92 after G29. At the end of G29 it says X is -36 which is the distance of the probe.
G21 ; Units to mm
G90 ; Absolute positioning
M82 ; Use absolute distances for extruder
G92 E0 ; Zero the extruder position
G28 ; Center all Axis
G0 X0 Y13 ; Move to start of auto leveling
G29 ; Auto Leveling
G92 X0 Y210 ;Set the extruder to the actually coordinates. Back left.
M105 ; Read current temp
M190 S110 ; Set bed temp and wait to be reached
M109 S230 ; Set extruder temp and wait to be reached
November 12, 2015 12:40PM
Finally I'm done with the cooling fan!
Not sure if it helps or not but it blows a stream of air to the extruder nozzle, in a theoretical way should help to cool down the PLA that it's just extruded and help to stop the sagging on areas where there is overhanging...
If you are interested I will link the STL file, I tried to print it as one single object but there was too much interference of material support in the inside and was impossible to remove it all clean. So I decide to cut it on half and use some superglue to join it at the end, the screw holes are a little bit small for #4-40 bolts, but with some elbow grease and patience will work (better than loose holes where screws come loose constantly).
ExtruderPLAFan
November 12, 2015 12:57PM
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
G21 ; Units to mm
G29 ; Auto Leveling
Thanks for the S3D info, I am about to make that purchase so any and all advice is welcome :-)
As far as the Bowden directly above the hotend on the rail, I've actually thought of that as well, but I'm not sure it will work. It works with the filament roll there because the filament can lengthen and shorten as the X-Axis raises and the hotend move left to right. The Bowden tube will not do that and would most likely bind as the X-Axis moves. Maybe if you built a loop into the tube it would allow for the flexibility required to move with the X carriage, but that seems to defeat the purpose of that location!?!?
I'd like to hear more about this...like I said, I thought about it but quickly dismissed it...
Sonny
November 12, 2015 01:02PM
sonnylowe
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
G21 ; Units to mm
G29 ; Auto Leveling
Sonny
I have been told to check out Meshmixer and Mattercontrol. Those 2 combined can work just as good as S3D. Thats just what I was told. Might as well check it out b/c its free.
Also S3D allows you to install it on 2 computers so you can find someone to split the cost. My dad bought it so I used his other licenses.
There are still a few features in S3D I wish it had. Its ok to me. Sure everyone says it slices perfectly and fast but im a noob and haven't really tested it.
Edited 1 time(s). Last edit at 11/12/2015 01:03PM by Yelloow-Snow.
November 12, 2015 01:07PM
Yelloow-Snow
sonnylowe
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
G21 ; Units to mm
G29 ; Auto Leveling
Sonny
Yeah, I thought about sharing it as well, I have a coworker that has a printer but can't seem to get him on board ;-) It would definitely be worth looking at the other software's as well...free is always good!!!
November 12, 2015 01:48PM
Yelloow-Snow
You want the bowden cable to be long enough to comfortable flex as it goes side-to-side. I think mounting it on the top rail would cause feeding/buckling issues.
...and I like this temp stabilization change you've made, but my immediate though would be that the bed expands a little heating up, so the autolevel might be a little off by the time it's ready to go.
November 12, 2015 02:24PM
therippa
Yelloow-Snow
I'll start off like this. I'll make something where I can keep rotating the angle of it until its vertically over the hot end.
November 12, 2015 02:46PM
I set current limits to max. the stepper motors supplied by folgertech are 12 V so they cannot be overpowered by the 12V supply
November 12, 2015 07:36PM
Anyone that is using S3D mind uploading your configuration so I can use it as a starting point as they don't have any presets?
Cheers
November 12, 2015 09:47PM
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
G21 ; Units to mm
G29 ; Auto Leveling
I got that aluminum bed plate like you have in the pictures but haven't installed it yet. Are you putting anything on it to get the print to stick? I was planning to still have the glass on there because I am thinking it would be hard to clean the glue or whatever off with it attached to the printer.
November 12, 2015 10:26PM
msaeger
Glass is best if you dont have an inductive sensor. If you use the sensor for auto leveling you cant use glass.
I use gluestick. I don't wipe it off. it sticks so crazy I have issues removing it.
November 12, 2015 10:49PM
Yelloow-Snow
msaeger
I am using watered down elmers applied with a brush and I take the glass to the sink to wash it off once and a while. I think after I put on a few layers it starts to get uneven. So the inductive sensor won't read through the glass?
