You often find thermistor "13" = 3950 in asian hotends. At least it is a starting point.
Autotuning PID will help you later to improve temperature stability. ( see M303 command )
The temperature, you´ll get the best results with, will vary on Filament and printspeed. You´ll have to experiement with temps alot, so the actual reading is less important than gaining experience.
-Olaf
