Axis not moving after triggering endswitch? July 30, 2015 11:44PM |
Re: Axis not moving after triggering endswitch? July 31, 2015 03:40AM |
Re: Axis not moving after triggering endswitch? July 31, 2015 11:16AM |
Re: Axis not moving after triggering endswitch? July 31, 2015 11:31AM |
Re: Axis not moving after triggering endswitch? July 31, 2015 02:31PM |
Will arrive in a few days so I can do some real printing) and about halfway through I touched the X axis stepper motor, and it extremely hot, to the point where I couldn’t hold on for more than 5 seconds. I keep adjusting the pot counter-clockwise every few minutes o see if the temperature will go down, but no luck so far.|
Re: Axis not moving after triggering endswitch? August 01, 2015 01:47AM |
Re: Axis not moving after triggering endswitch? August 01, 2015 10:07AM |
You mean another stepper driver? I did. Same effects. What I did was turn the pot down all the way, and then keep adding little by little until it had just enough torque for me to not be able to easily stop it.Quote
sarf2k4
This is quite weird, I wonder if using other board would be okay?
Re: Axis not moving after triggering endswitch? August 02, 2015 07:04AM |
Re: Axis not moving after triggering endswitch? August 02, 2015 09:28AM |
sarf2k4
Manually move as in from reptier/pronterface or by hand?
Re: Axis not moving after triggering endswitch? August 02, 2015 10:26AM |
Re: Axis not moving after triggering endswitch? August 04, 2015 01:43PM |
Re: Axis not moving after triggering endswitch? August 04, 2015 02:24PM |
