Folger Tech 2020 question August 01, 2015 05:29PM |
Re: Folger Tech 2020 question August 04, 2015 12:18AM |
Re: Folger Tech 2020 question August 04, 2015 07:24AM |
gmckee
It sounds like you're describing the heatbreak. Teflon are lined on the inside with Teflon tubing which can break down at around 250c I believe. All metal aka stainless steal doesn't include Teflon lining. The specific type used in your printer should be replaced with the same. Look for a plastic tube inside to see if its lined or not.
Re: Folger Tech 2020 question August 04, 2015 08:28AM |
Re: Folger Tech 2020 question August 04, 2015 12:46PM |
mike3
Hello on the Folger 2020 Extruder part M6x26 Stainless Steel Nozzle Throat I want to buy some replacements .. are there 2 different kinds.. I see some that says just Stainless steel and I see others that say it teflon lined? or all they all the same with teflon? thanks
